Question about True Refrigerators
I have a True GDM-23 refrigerator that is not cooling properly. If I disconnect it for a night it works well the next day or two and then the temperature star rising again. What could be the problem?
todd0708
  • 247 Answers
SOURCE: Fridge not cooling. Temperature rising
most common problem is the defrost timer motor,it tells the fridge to de ice ,about every 10 hrs or so,if it gets stuck or burns out your evaporator will be a block of ice ,and the fan blowing on it wont transfer cold air,look in the bottom of the fridge by the compressor,
Posted on Sep 14, 2009
  • 24 Answers
SOURCE: Refrigerator doesn't cool/freeze - clicking, cyclying noise repeates, but doesn't cool
I've been told by a tech who repaired my MFD2560HEQ this past week that many of this model had a problem with compressor failure. Your symptoms are classic. What you are hearing is the starter relay trying to start a warm/hot compressor by supplying it with an extra jolt of electricity, but because of the faulty compressor (or if you are lucky a faulty relay) that's warm (cool ones start more easily often) is refusing to budge into motion and compress the freon. Maytag, I believe, has a five year warranty on the compressors. They did on mine, but unless you have an extended warranty the labor replacing it is not covered and that will be around 2-3 hours worth. This is the price we are paying for our quest for energy efficiency. Compressors are being built so small and light that they fail much more often than grandma's old, old refrigerator that was built like Fort Knox and ran for 45 years, remember? But we're being energy efficient! Thank you environmental extremists! I wish I could send you the repair bill.
Posted on Nov 08, 2009
  • 10 Answers
SOURCE: I have a True GDM-26. The contents get cool
I have same problem was told condensing fan not working properly. Easy to see if this is the problem, take out guard in front of machine and put a fan blowing into it. I went to home depot and bought a tornado fan and it cools again. Now if I can only figure out if its the fan or whatever contros its speed. If anyone knows how to check please respond.
Posted on Apr 17, 2010
  • 274 Answers
SOURCE: True GDM-12 - Unit runs, but won't cool below 60 degrees,
Is it very hot out side the unit.recharging may not hurt is it cleaned the lint could be trapping the radiator were the coolan goes through to cool down try cleanning underneath before recharging
Posted on Jul 26, 2010
  • 135 Answers
SOURCE: i need a wiring schematic
www.truemfg.com
Posted on Jan 09, 2011
1988 true GDM 33 its 100+deg. in my shop. Refrigerator is only cooling to @44 deg. is that about normal for the outside temp?
The unit is probably not designed to work in an ambient temp that high, probably 90-95 would be as hot as the manufacturer was thinking, however the age of this unit probably means the compressor valves are not sealing quite as well as they used to. this can cause a unit to never pull down all the way to proper temp. get as much air circulating to the unit to help draw heat away
Aug 31, 2011 | True GDM-33-C-PT-54 Refrigerator
I need to replace the door bulb and the bulb above the door in my True GDM-23. What size are the bulbs and are they available in a hardware store. Thanks
The door bulb is a standard , I believe 32" t-12 newer units may be t-8, common bulb in stores. I've got an older gdm 23 and the bulb on top is a curved one , harder to find. Also these lights have ballasts that power them, they also can fail
Jun 22, 2011 | True GDM-23 Refrigerator
I have a true upright commercial display refrigerator.I think the tempature control is faulty.It freezez everything,I use it for beer and wine.I have cleaned the condensor and still no luck.No matter what...
it is just a temp control, look real good at the control and see if you can see any holes in it that might have a small screw that can be turned. Maybe an in and out, you may be able to adjust it this way. let me know.
Mar 15, 2011 | True GDM-23 Refrigerator Commercial
My true gdm-23 will not stop cooling and freezes contents.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 26, 2011 | True Refrigerators
GDM-41 Refrigerator: True GDM-41 Refrigerator getting too cold...
good day,
hope this link below will solve your problem.
ref
May 18, 2010 | True GDM-41 Refrigerator
I have a True GDM-26. The contents get cool inside but not cold. The temperature dial is set at the coldest setting. Also, there is a lot of condensation on the bottles inside the cooler. Any...
Nov 24, 2009 | True GDM-26 Refrigerator
True gdm-33 icing up have to disconnect then works okay for acouple of days
2 things to check - Excessive moisture coming inside will cause frosting - Have it serviced and check proper door seals - the next thing to check, for frost free units, is the defrost timer and its components - no defrost cycle = frosting up.
Aug 24, 2009 | True GDM-33-SSL-54 Refrigerator
Refrigerators Logo
18 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
