Question about Intel H55TC Motherboard Core i3 540 Processor w Fan Bundle FREE Napoleon Total War Game (BOXDH55TCWCI3540GAMEBUNDLE)
What type (atx or atx12v etc.) power supply is compatible with the intel h55tc mobo?
  • 23 Answers
A quick look at the H55TC's architecture tells me you should choose - at minimum - a power supply
that is ATX12V 2.0 compliant. This will provide you with a contiguous 24-pin connection to the CPU,
increased power on the 12V rails, and adequate power to most of the board's optional components.
That's the short answer.
From there you need to take a look at how you intend on completing your build. Are you going to use the onboard graphics or pop in a discrete video card? If the latter, then you should be looking at
PSU's that are ATX12V v2.2 compliant, to provide adequate power to the PCIe x16 slot. But keep in mind that ATX12V v2.2 revision limits 12V rails to 20A per rail, which means if you plan on building a performance machine that begs for 60A of power, you'll be limited to power supplies with split 12V rails. Multiple 12V rails introduces load-balancing issues and other concerns, if your plan is to push this system to its limits.
Moving up to the ATX12V v2.3 form factor removes the 20A per rail restriction, allowing for high-amp
single 12V rail power supplies. This revision also ensures higher efficiency ratings (80% on avg.) which means less power consumption, and less heat build-up in your case.
The optimal choice would be an EPS12V compliant power supply, a revision made specifically with multi-core processors in mind. My pick for one of the best value EPS12V power supplies would be the CORSAIR CMPSU-750TX - currently on sale at Newegg for $109.99 (30-bucks-off.)
It delivers a true 750W of power; pumps out 60A on a single 12V rail; is both SLI & Crossfire certified; 80%+ efficient; Core i7 compatible - essentially future-proof for the life of the PSU.
Finally, here's a link to a pretty decent power supply calculator by Asus. It should give you a good idea of how much juice you're gonna need once you trick out your system.
Good luck, and I hope this was useful :)
Posted on Jan 04, 2011
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
Power supply compatible for cooler master cac-t05-uw
Most brands like HEC, Gigabyte, FPS, Cooler Master, Enermax, Silver stone, Corsair, etc. Will fit in your casing but you must consider your hardware before buying a power supply.
Most power supplies that are priced below $30 generally do not meet the power requirements of the latest processors. To make matters worse, the components used in them are of inferior quality and more likely to fail over time. While they may power the computer system, inconsistencies in the power to the components will tend to cause instability and damage to the computer.
Consider the ff:
ATX12V Compliant
PC Power Supply Wattage
Silent PC Power Supplies
Power Efficiency
Having the right number of connectors
PSU Wattage Calculator Asus
PSU Wattage Calculator extreme
Hopefully this helps..
Thank you for posting..
Jul 08, 2011 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
Hp palilivon a 1100y lost all power will not come back on i checked all cords power source everything seems to be ok. but no power still?
I'm going to base this solution on two scenarios from the info you have posted.
1) The power to your home/business went out. Now it's back on.
2) The power has been on all along, and the computer quit.
Based on 1) above;
The Power On switch could be bad, or the Power Supply.
A voltage spike could have occurred, and taken out the ATX power on switch.
(A generic ATX Power On switch is around $5. Example,
http://www.axiontech.com/prdt.php?item=78201 )
A voltage spike could have taken out a power supply that is of low quality, and/or on it's last leg.
The power supply used in an HP Pavilion a1100y desktop computer is of low quality.
Low quality components are used inside.
(Bestec, and Delta are two of the low quality power supply's used by HP in this time frame)
Plus add to the fact that the computer has some age on it, (5 years old?), and could be dirty inside.
Dirt,dust, etc. 'kills' computers and power supply's.
There is a simple test to perform to see whether the problem is the Power Supply, or the Power On switch.
(The Power On switch is located within the plastic Power On button assembly)
If you wish to know how to perform this test please post in a Comment.
(Free)
Based on 2) above;
The Power Supply is bad.
The test would be either to use a multimeter, and check the three main voltages coming out of the Power Supply,
Or,
Substitute the power supply with a KNOWN to be good compatible unit.
(250 to 300 Watt)
(Sometimes access to another known to be good, compatible power supply may be obtained from a computer that is no longer in use. The user has upgraded to a better computer.
Compatible being that the Power Supply has the required Wattage, and required power cables)
[The three main voltages produced by an SMPS (Switched-Mode Power Supply) used by the Pavilion a1100y desktop computer are;
A) 3.3 Volts DC (Orange wire)
B) 5 Volts DC (Red wire)
C) 12 Volts DC (Yellow wire)
In comparison two D cell flashlight batteries produce 3 Volts DC ]
This is HP Support>Pavilion a1100y desktop computer> Motherboard Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00499325&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=1118244
Looking at the motherboard illustration, and photo at the bottom of the page, we can see what power cables are needed for the motherboard;
A) 24-pin ATX main power cable
(Connector on motherboard illustration marked as ATXPWER1. In the photo it is whitish, and has two vertical columns of 12 square socket holes. It is to the Right of the Ram Memory slots)
B) 4-pin ATX main power cable.
(Connector on motherboard illustration is marked ATX12V. It is to the left of the Intel Northbridge chipset - Intel 915GV GMCH.
In the photo it is the whitish square connector with four square socket holes. It is to the Left of the
aluminum finned Heatsink, sitting on top of the Intel Northbridge chipset)
Other power cables needed are;
1) A SATA power cable for the SATA harddrive
2) One or two 4-pin Peripheral (Standard) power cables for the optical drive/s. (CD/DVD drives)
The Processor fan cable attaches to the motherboard. (CPU_FAN)
The computer case fan attaches to the motherboard. (SYS_FAN)
The ATX form factor is used primarily for describing a motherboard.
Form Factor denotes the size, and shape, and power cables for a Power Supply.
The ATX form factor for a Power Supply;
Size: Approximately 6 inches Wide, 5-1/2 inches Long, and 3-1/2 inches Tall.
A $40 ATX power supply with 300 Watts will do just fine. No need to buy an expensive Power Supply based on advertising as a direct substitute.
One example of an inexpensive reliable ATX power supply for a Pavilion a1100y desktop computer,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1389575&CatId=1078
Has all the power cables you'll need. Actual maximum wattage rating is 350 Watts.
Information,
http://www.hardwaresecrets.com/article/332
For additional questions or to clarify anything I have stated, please post in a Comment.
Regards,
joecoolvette
Jun 21, 2011 | Computers & Internet
Does the intel h55tc mobo come with sound and video cards or do I need to buy?
http://www.intel.com/products/desktop/chipsets/h55/h55-overview.htm
intel H55TC has built-in High definition audio & built-in video display..check the site above for more info.
Have a nice day..
Markus
Jan 06, 2011 | Intel H55TC Motherboard
Dg41 is the best
Please get DG41/CN/TX motherboards it the best. this is due to fact that it carries a better graphic resolution card, lates technology DDR3 SD RAM ram, etc.
Intel DG41CN Motherboard
  • Form Factor: Micro ATX
  • Compatibility: PC
  • Chipset: Intel G41 Express
  • Compatible Processors: Intel Celeron, Intel Pentium, Intel Core2 Duo, Intel Core2 Quad
  • Video Interface: PCI Express x16
  • Storage Controller Type(s): Serial ATA II x 4
  • Intel DG41TX Motherboard
    • Compatibility: PC
    • Compatible Processors: Intel Celeron, Intel Pentium, Intel Xeon, Intel Core2 Duo, Intel Core2 Quad
    • Front Side Bus Speed: 1333 MHz
    Regards,
    Pourmoi
    Dec 23, 2010 | Intel DG31PR Motherboard
    E Machine ATX 250 -12E replacement PS
    With emachine MOBO's you have to make sure you plug in the 20 pin plug from the power supply to the mobo. Also make sure all hard drives, cd/dvd roms, floppy drives, etc are turned on. Make sure the red switch on the PS is set to 115. Make sure the PS is plugged into a known working outlet. Make sure MOBO is properly in place with all grounds/screws in place and nothing metal near or touching board which may short it out.
    You can review the E Machines PS replacement guide here for further instruction.
    Good Luck,
    Jesse
    Jan 11, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
    The pc wont power up and the green led on the PSU is just flashing, is the bestec atx 250 12z broken?
    Most likely yes.
    I would also reccomend an upgrade to that PSU when replacing it.
    Something in the 450-Watt neighborhood is usually a bit more robust.
    Oct 15, 2009 | HP ATX-250-12Z, ATX-250-12Z REV.: D2, HP...
    Intel D945GCLF - No post, No video Signal
    Sounds like your wiring isnt right on the on off power. Make sure your power supply can handle this MotherboardAdapter cables are available that allow the incorrect use of older ATX or SFX power supplies in place of an ATX12V or SFX12V power supply. Intel does not recommend the use of these cables. These cables convert a standard 1x4 peripheral connector to the ATX12V 2x2 connector. An ATX12V or SFX12V with the 2x2 connector is required for all Pentium® 4 processor based Intel® Desktop Boards. Using the 1x4 converter cables can lead to system component or power supply damage and/or boot failures. The ATX12V and SFX12V power supply design guides (http://www.formfactors.org/)* recommend a minimum of 8A at 12Volts to properly power any Pentium 4 processor based Intel® Desktop Board. Standard ATX and SFX power supplies typically provide approximately 5A of current, which is not capable of reliably powering the Pentium 4 processor based Intel® Desktop Board. And I think the motherboards going to look for a formatted hard drive wired to the motherboard It wont boot off that USB stick.
    Sep 22, 2009 | Intel D945GCLF Motherboard
    I need a power supply compatible with Cooler Master CAC-T05-UW. Features are ATX Mid Tower, ATX, Micro ATX compatible form factor, 2 External 5.25'' drive bays, 2 External 3.5'' drive bay, 2 Internal...
    The Cooler Master RS-600-AMBA-D3 600W ATX12V V2.3 SLI Certified Crossfire ready 80 PLUS certified modular active PFC.
    Cooler Master eXtreme power RS550-PCARE3-US 550W ATX12V V2.3 SLI ready CrossFire ready power supply.
    Two models that should fit with that tower. Cheers!
    Aug 19, 2009 | Computers & Internet
    T2893 desktop did not power on when I hit the power button
    If you can find someone that has the same model, that is the best way to make sure it fits. Some other motherboards will fit, but you may have to do some work to get them to fit. The best way would be to try to do some research on your particular motherboard (mobo) on the internet. Sometimes it will have a manufacture’s name and model on it, try googling it and see what type it says it is (ATX, mini-ATX, AT, etc). One problem you may have is the power button connectors may not be compatible with your new motherboard if you get something besides an emachine mobo. If you are good at electronics it will not be much of a problem for you.
    Unless you get an exact e-machines mobo, your OS will most likely not work at startup. Windows XP does not like wholesale changes like a mobo. When it sees that a major configuration change has happened it sometimes freaks out. Sometimes it will just ask you to re-activate windows other times it gets stuck in a reboot loop. Hard rive and CD rom should still work, provide you do not get too new of a mobo. Older HDD and CD drives were IDE connectors, newer ones have SATA connectors. Unless your mobo and power supply unit (PSU) have the correct connectors you will not be able to use them.
    To the poster who asked if it could be anything else besides bad mobo. Yes it can occasionally be a bad power supply unit (PSU). A bad PSU does not necessarily mean no power, just not enough power to run the computer. You can try swapping it out with another one of equal or greater output watts. You can try removing the power connectors from the drives and then remove the memory and see if it changes the boot up procedure of your machine. More beeps, different beeps, no beeps, etc. Add one component back at a time to test. Make sure you get the same results and not just a one-time fluke start up. If a memory stick is bad, it usually is bad. A power supply or mobo can be flaky and fail some times and not others.
    Jan 25, 2009 | E-Machines eMachines T3830 PC Desktop
    Intel H55TC Motherboard   Core i3 540 Processor w Fan Bundle  FREE Napoleon Total War Game (BOXDH55TCWCI3540GAMEBUNDLE) Logo
    145 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    David
    David
    vsri9
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
