Question about Epson Stylus DX4450 All-In-One InkJet Printer
When I change the ink cartridge on my Epson Stylus NX110 printer, it continually comes back saying the cartridge is not compatible, however, it is exactly the cartridge we have used since purchase. It is Epson #69 as instructed This happens every time a new cartridge is installed. This is the worst printer I've owned............and I've owned many since 1982.
  • 312 Answers
I also have a an Epson that takes the #69 cartridge. Whether or not I solve your issue, I suggest you call Epson and tell them about this issue. What you think and a piece of your mind. I've done it and they replaced my printer. I called their consumer relations relations and explained to them that I have owned Epson Printers for years which is true. That any time of the day or night I can find a 10 your old Epson dot matrix printer on Ebay, get it in the mail and it would work perfectly and be more dependable then what I have sitting in front of me. I would remind them that they have a great deal of experience building printers and ask them to restore my faith in them.
Now that I have soap boxed, lets get down to your printer.
The Epson has a circuit board installed in every cartridge itself. It is designed to shut down the printer when it is out of ink and to thwart any attempts to refill it. Your detection system is obviously malfunctioning.
This is what I would do, for what it is worth it sometimes works.
Using the Epson maintenance utility to change cartridges I would do the following:
1 Remove the cartridge
2 Remove all the rest of the cartridges
3 With a strong flashlight, look inside where the spring contact that the cartridges fit against in the head and brush out any possible debris you can find with an old toothbrush. You may want to put a small amount of rubbing alcohol or vodka (expensive rubbing alcohol) on the brush and wipe it over the contacts lightly. DON'T USE COTTON SWAB OR PAPER TOWEL AS PAPER WILL EASILY GET LODGED INTO THE MACHINE.
4 Use a cotton swab dipped in alcohol to remove any oily residue that may be on your four cartridges. JUST WIPE ONCE AND DRY WITH CLEAN PAPER TOWEL IMMEDIATELY.
5 INSTALL ALL FOUR CARTRIDGES INTO THE MACHINE.
6 RUN THE REST OF THE INSTALL UTILITY DOING RECHARGE AND CLEANING ACTIONS AS USUAL.
Tell me what happened.
I have had it work when I have removed all four cartridges, even though I am only changing one of them.
I hope this has helped.
Best Regards,
Mark
Posted on Jan 04, 2011
  • racheto Jan 22, 2011
    For my printer it worked like a dream. Thanks
  • 591 Answers
Make sure it's original epson cartrige some stores will sell you generic or re-filled type of cartrige...
How do I LOAD CARTRIDGES INTO MY EPSON STYLUS NX110 PRINTER
Follow the link below:
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Click "replace ink cartriges" on the left of the page
and then select "Remove and install Cartriges"
May 04, 2011 | Epson stylus nx110 All-In-One InkJet...
Put new ink cartridge in Epson NX 110
I have a epson stylus NX110 Printer the ink cartridges will not stop so that i can put in new ones.I press the stop button but the ink cartridges will not stop onthe arrow so that i can put in all new ones.
Apr 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
I don't know how to change the ink cartridge of epson tx 110
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Mar 21, 2010 | Epson Office Equipment & Supplies
Have an epson stylus nx110 printer and have to replace ink cartridge. the cartridge holder will not go into place so that i have access
Find the NX110 in the printers section of the control panel. Then right click your printer and choose "Printing Preferences" then the "Maintenance" tab. In there you will see a button for 'Replace ink cartrige'. Select that and it will take you through it step by step and even move the print heads to the correct position so you can change the ink.
Mar 13, 2010 | Epson Stylus NX400 InkJet Printer
Replaced the ink cartridge now it will not print
*** I'll be more than happy to help you on that.
there is a great possibility that the nozzles of your printer are clogged by dried inks.maybe cause by the previous inks that you just replaced. we can check that by printing a nozzle check pattern.
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX110 Series. 3. Hold down the nx110_tx110_ug.1.98.1.jpg Stop button as you press the nx110_tx110_ug.1.98.2.jpg On button to turn the Epson Stylus NX110 Series back on. When the nx110_tx110_ug.1.98.3.jpg On light begins to flash, release the nx110_tx110_ug.1.98.4.jpg Stop button. nx110_tx110_ug.1.98.5.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx110_tx110_ug.1.98.6.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Using the Control Panel 1. Load a few sheets of plain paper in the sheet feeder. 2. Make sure the Epson Stylus NX110 Series is on and the ink light is off. 3. Hold down the nx110_tx110_ug.1.99.1.jpg Stop button for three seconds to start the cleaning cycle, which lasts around one minute. The nx110_tx110_ug.1.99.2.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus NX110 Series during a cleaning cycle or you may damage it. 4. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 4 times. You can also turn off the Epson Stylus NX110 Series and wait at least 6 hours. Then try printing again.
Feb 16, 2010 | Epson Stylus NX115 All-In-One InkJet...
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
Warning:
Note:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
How to change ink cartridge in epsonnx110
Here is what I found on Epson Web site. Click on link below. IF YOU FIND THIS HELPFUL PLS RATE ME. THANKS AND GOOD LUCK......
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=128285&prodoid=63083739&category=Products
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to replace them to prevent the print head nozzles from drying out.
For best printing results, use up a cartridge within six months of opening the package. If you need to replace a cartridge when the ink light is flashing or off (before the cartridge is expended), you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
You see one of these screen SEE ATTACHMENT BELOW
2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary
Jan 01, 2010 | Epson Stylus NX115 All-In-One InkJet...
Epson Stylus DX4450 All-In-One InkJet Printer Logo
943 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
