Question about Compaq Presario 5000 PC Desktop
I installed Windows XP and then installed the video driver for the computer. Once I restart it doesn't bring up anything past the XP loading screen. It makes noise as if it is doing something and I was able to shut it down using the keyboard from memory while the screen was black. I can start it up and see something on the screen in safe mode and vga mode. Any suggestions?
    President:
  • Compaq Master
  • 2,246 Answers
Reinstall your pc, maybe your bios seting is not for xp
i hope this helpfull
please rate my answer
Posted on Jan 04, 2011
The laptop won't load past the welcome screen. I can get it to start up, and go to a start in safe mode etc. but it won't load past the welcome screen.
Your computer is experiencing a no boot problem which means that the operating system is corrupted. You can do a start up repair to fix the computer but if it won't fix it then that's the time that you need to reinstall the whole operating system.
It could have been very helpful if you provided us with your operating system so that we can provide you with the exact troubleshooting. However, I just presume that you are using windows VISTA or Windows 7. However, this troubleshooting also works with windows XP.
Before you start the start up repair. You need the Operating System Installation disc from Microsoft.
1. Insert the disc in the dvd/cd drive.
2. Restart the computer.
3. Once you see the "press any key to boot to cd" message. Press any key.
4. It will bring you to a page where it will ask you to INSTALL or to REPAIR. Just click on repair.
5. It might ask you to load the drivers. Just click ok or next.
6. Follow the on-screen instructions.
However, if start up repair won't fix the problem, Clean Reinstallation is the next step. Clean reinstallation will delete everything in your computer including the files, pictures, etc. that you have saved. But you cannot really access them anymore since the computer won't boot up.
I'm am providing you with the links to the tutorial on how to reinstall the operating system.
1. WINDOWS XP REINSTALLATION TUTORIAL
2. Windows 7 Reinstallation Tutorial
3. Windows Vista Installation Guide
I hope this helps. Thank you for using fixya.
carloadrian
Feb 03, 2011 | Gateway M-7315U Notebook
How to install windows xp in msi k8mm-v motherboard?
Hi dharmen_shah,
I see that you need to install Windows XP on you Dekstop with an MSI Motherboard k8mm-V.
I have another desktop using the same Motherboard, there are 3 options installing Windows XP on the machine.
  1. Using an IDE Optical Drive
  2. Using a SATA Optical Drive "not a common installation process on this motherboard" since you will need to install the SATA rivers first to be able to use your SATA ODD
  3. Using a USB Flash Drive
See steps below for each installation type.
*Using an IDE Optical Drive*
  • If you have your Windows XP CD insert it on the Disc Drive restart the system as soon as the system restarts keep on tapping F11 this will bring you to the Boot menu.
  • Once in the Boot Menu screen select your Optical Drive, it may say dvd/cd or ODD, select this and press enter. Note: windows may restart during the installation if it says press any key to boot to cd do not press anything anymore leave it will do everything on it's own unless prompted for any user information like a computer name date and time.
  • You will see on the screen Boot to cd: then it will show "press any key to boot to cd" press Enter or any key this will boot from your cd Windows XP.
  • Then you will see inspecting your hardware for configuration, once it boots to your Windows XP cd you will see a blue screen Loading up drivers and stuff for the installation of Windows XP.
  • Next will be the installation of Windows XP itself, just follow the prompt it is very easy to follow and it will give you all the details and what buttons to click on.
  • Note: Select Quick Format (NTFS) this will be faster reformatting your Hard Drive before installation.
*Using SATA Optical Disc Drive*
  • You will need a 1.4 floppy disc to be able to do this.
  • If you have a 1.4 Floppy Drive you will also need to download the SATA driver from the MSI website.
  • Let us disregard this option since I believe you do no have a 1.4 Floppy Disc Drive and no one uses that or has a 1.4 Floppy Drive anymore on their machines.
*Using a USB Flash Drive*
  • To be able to use a USB Flash Drive for the installation of Windows XP your USB Flash Drive should at least be 1GB or 2GB, 1GB will be enough since windows XP only uses at least 7++gb of disc space for the installer size.
  • Using you USB Flash Drive you will need to copy the whole contents of your Windows XP Cd into your USB Flash Drive, don't worry this will be bootable just make sure that you copy everything from the disc into the USB Flash Drive.
  • Once you have copied Windows XP on your USB Flash Drive insert it to one of your USB ports on the machine then restart the computer.
  • Restart the system as soon as the system restarts keep on tapping F11 this will bring you to the Boot menu.
  • This will be the same as using your Windows XP cd but instead you will need to select USB in the Boot Menu then press enter. on the installation steps it will be the same as installing using a disc.
  • Windows may restart during the installation and using a USB Flash Drive will be different at this point because it will boot directly to the USB, Once it restarts and may repeat the installation all over, to prevent this as soon as the system begins to restart from the installation go and keep on tapping "Delete" once it restarts this will bring you to the BIOS screen press F9 to set it to defaults then press F10 to save and exit this will restart again.
  • Once it restarts after setting the BIOS to defaults let the system boot on its own it will then show you a screen asking what windows to install the first thing highlighted will be the installation that was halted earlier just press enter then it will show you the windows installation page and will continue on it's own.
This is based on my own experience since I have an older Desktop that has the same Motherboard, I hope that I have given you all the options possible to installing your windows XP on your Motherboard k8mm-v.
Have a nice day,
mvincentc
Feb 02, 2011 | MSI K8MM-V Motherboard
Ati radeon 9550 agp 256 xp driver
Hello gran_capricc, you must remove Ati old video driver from your computer, before installing latest driver, go to Start> Control Panel > Uninstall a program > ATI Video Driver Remove, Restart Computer, i found latest driver for your Ati radeon 9550 agp video card fully compatible with Windows Vista, Xp. Click save driver to your computer, install the driver, don't forget to restart the computer. Here is the link.
Copy and paste link into your browser and press enter.
1. For Windows Vista
http://support.amd.com/us/gpudownload/windows/Legacy/Pages/radeonaiw_vista32.aspx?type=2.4.1&product=2.4.1.3.13&lang=English
2. For Windows XP Professional, Home Edition
http://support.amd.com/us/gpudownload/windows/Legacy/Pages/radeonaiw_xp.aspx?type=2.4.1&product=2.4.1.3.13&lang=English
Good Luck!
Nov 15, 2010 | ATI RADEON 9550 Graphic Card
Computer restarts on the loading screen.
ITs the problem with the video card and memory, try reseting the memory and install direct X controller and update the video card drivers and then try to install it
Sep 16, 2009 | Computers & Internet
SERVER RESTARTS AT BOOT UP AFTER INSTALLING PCIE GF8600GT DRIVERS
Load the computer in safe mode by pressing F8 before windows loads up. Once in safe mode, uninstall the drivers that you installed, reboot and download the latest ones from the manufacturers website.
May 04, 2009 | AOpen Computers & Internet
How to restart hp pavillion 7965 desktop
Hi there. Try these steps:
1. On restart, press F8. This should bring you to a screen with various boot options.
2. Select "Last known good configuration". Windows then may load correctly.
3. If this doesn;t work, try the same thing. This time select "boot in Safe Mode". If Windows now loads in Safe Mode you should be able to restart and Windows may load correctly after this.
4. If these two both fail, you may have to repair Windows...
Jan 09, 2009 | HP Pavilion 7965 PC Desktop
Hp compaq d220 MT loading screen freeze up
only thing I can see is for you to re-install WIndows xp. seems like the operating system having a porblem loading.
Oct 13, 2008 | Computers & Internet
Windows Xp SP2 prpgress bar freezing
You must uninstall the drivers of your old card before installing the new card and drivers.
Also make sure the BIOS is set to automatically check what you are using, onboard video (if available) or graphics card.
Jul 24, 2008 | ATI RADEON 9250, (256 MB) PCI Graphic...
Presario v4000 will not boot up
hi,, this compaq is fucking,,,,,,,, even i got the same problem
Oct 31, 2007 | Compaq Presario V4000 Notebook
Motherboard upgrade
The different hardware components on the new motherboard require different drivers that what are already loaded on your installation of Windows. My guess is something requires a driver that the base Windows driver install will not cover and as a result errors out and restarts. I too have tried this trick on several occasions, sometimes it work and sometimes it doesn?t; however, the key is similar hardware. My guess would be IDE controller, video, chipset or perhaps USB 2.0 is causing your problem. What you can do perhaps is boot into Windows safe mode and try to figure out what is causing the problem. In the long run it may save time and aggravation by just reinstalling Windows ?? Let us know how it turns out.
Jan 02, 2007 | MSI RX480 Neo2-F Motherboard
Compaq Presario 5000 PC Desktop Logo
32 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
