Question about Lionel Trains Holiday Express G Gauge Train Set
Train will not run. Starts then immediately stops. Tracks and all contacts are clean and conductive. Lights are all on. Power supply is fine. Lionel local repair shop cannot fix it. Help. How can I get plans? Replacement electronics, etc...
  • 13 Answers
SOURCE: is lionel 40 watt transformer from toy train
need a larger out put transformer 90 watt or greater....
Posted on Nov 20, 2011
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
  • 653 Answers
SOURCE: Life Like train hesitates and stops altogether.
It sounds like you have eliminated the motor as the problem. Try cleaning all of the electrical contacts including the connections between rail sections and the hot rail with fine steel wool (make sure you clean up all of the remaining steel wool bits since they are conductive). If that doesn't work, look at the transformer output.
Posted on Mar 05, 2009
  • 18 Answers
SOURCE: I have a complete Lionel Electronic Control train
Yes it can be fixed. Does the transmitter work? I am asking if other cars and the locomotive respond to the transmitter ECU-1. The dump car is a little different from the other cars as you need to hold the button down for several seconds to get it to dump momentatrily to uncouple. There is a thermostatic time delay as part of this car's receiver.<br /> Look it up in the old Lionel Service manual (original or Greenberg reprint) or the Greenberg operating guide (small thick hardbound book)<br /> <br /> Ed
Posted on Aug 21, 2010
  • 2418 Answers
SOURCE: The Cw 80 watt transformer
If you have a volt meter you can check the rails for power, Check the transformer wiring to the first rail connection and then along the rails for loss loose connection(s). If you have power to the rails it is an issue with the Engine, Check any brush or rail riders (connections) for a bent or broken tab. If for a temp fix in a broken connection tab or brush you can use Tin foil. Hope this helps.
Posted on Dec 25, 2010
I have a new 104 MTH Long Island engine and tender and I cannot get it to run.
The locomotive may be defective as received. Try applying power directly to it to confirm.
Dec 05, 2016 | Crafts & Hobbies
Lionel 6-30218 not working,The engine is making hissing sound the headlight bulb is glowing the cab cars have light ,The remote Red Light is glowing when turnig the knob of throttle to right & lef
Your best option is to contact Lionel Customer service:
598-949-4100 ext. 2
9AM - 5PM Eastern Time Zone
They will give you instructions if they think it needs to be sent in for repair.
Jun 02, 2014 | Lionel A Christmas Story Gauge Train Set...
New polar express motor wont engage
It sounds like the gears have worn out or come adrift somehow. You will be able to get replacement gears from any of the Lionel authorised dealers Lionel Authorized Dealers or their replacement parts service Replacement Parts
Dec 28, 2013 | Lionel The Polar Express Train Set
My 1941 Lionel train stops getting enough power to run all the way around the track. Voltmeter says 15 volts around all track and transformer says 15 volts. How do I test engine?
If your sure the loco contacts/wheels are clean and the track is ok then remove the loco bodywork and check the motor. You can apply a 12v supply directly to the motor contacts to test if it's running ok. If it does run ok then suspect and clean the brushes and associated connections. If it does not run try moving the motor armature manually. If it is stuck it is probably time to replace it. If it moves apply a light machine oil and test again.
Dec 16, 2013 | Lionel Trains Classic Freight Train Set
How do I clean the tracks & wheels to stop the short circuit?
Have you let the loco charge first? The instructions are a bit vague but the loco needs to charge before it runs. Not easily understood from the instructions and many have spent some frustrating minutes wondering why their train wouldn't move.
Nov 13, 2013 | Lionel Trains Holiday Express G Gauge...
How often should tracks be cleaned. Engine slows down after running for a while
It depends upon how much you run your trains. Run your finger or clean cloth on the rail. If you see a dark mark your tracks need cleaning. You can also run another set of wires from the transformer to the spot on the track furthest from the transformer. You can even run a third or fourth equally spaced apart if you have large loops and long and heavy trains.
Dec 04, 2011 | Lionel 40 Watt Transformer Train Set Track...
&#921;'ve just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
Mar 05, 2009 | Life Like Collectible Train Set
Are the tracks new?
Is the lockon new?
Dec 14, 2008 | Lionel Cw 80 Transformer
Lionel Trains Holiday Express G Gauge Train Set Logo
470 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
ray gallant
Traindoc
Level 1 Expert
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
