Question about Magimix Cuisine 5200 1522 Cups Food Processor
We were making pasta dough in our Magimix Cuisine 5100. After we finished, we notice that the blade was stuck, and the plastic stalk holding the blade had twisted in such a way that the blade was jammed in the stalk. We managed to pull it out, but now both the stalk and the blade are misshapen and impossible to use. Is it possible to get replacement parts for the blade and also for the stalk?
    Top Expert:
  • Magimix Master
  • 43,997 Answers
Fixya does not sell Magimix replacement parts and does not know of any sources.
Posted on Aug 13, 2017
4 Suggested Answers
SOURCE: Magimix blade is stuck
You need to replace the spindle i'm afraid which gets worn after a time. There a UK company that sells replacements and tells you how to replace it. Not a big job though a bit tricky. magimixspares.com
Posted on Jul 04, 2009
co7196
  • 3433 Answers
SOURCE: need bowl and lid for 5100
Go to this site. or type magicmix in the search bar at the top of the screen, Good Luck
http://www.magimix-spares.co.uk/Parts-for-Magimix-5100-lid,-...
Posted on Oct 31, 2009
caroldon
  • 17130 Answers
SOURCE: dead motor in Magimix Cuisine 5100
Remove and check if there is any fault of a brush contact or switch contact or if the load trip switch had reset.
If the power is coming to the motor and is not running you need to confirm fully if the windings are open , if so replace motor.
if not remove and reset the setting of the brush/commutator.
Posted on Sep 24, 2010
Testimonial: "A good simple test to perform, and optimism about a solution either way - thanks very much!"
Kitchen aid food processors 's chopping blade gets stuck . Very hard to take it out
The shaft sleeve (the one on the motor shaft) is likely damaged. The correct solution is a new shaft sleeve and chopping blade. If you do not replace them both together the one you do not replace will damage the other one again.
Aug 23, 2013 | Magimix 5100 Cuisine Systeme Food...
Need a manual for cuisine 4200
Magimix makes the Instructions for Use for the Cuisine 5200 available on their website:
http://www.magimix.com/upload/notice_d_utilisation/ma_cuisine/download_usa.pdf
If you don't mind paying a small fee there is also an Instruction Book available here that may also be applicable to the 4200:
http://www.magimix-spares.co.uk/Magimix-le-micro-instruction-book-and-le-micro-recipe-book/product/54138/54138/
Nov 01, 2011 | Magimix 5100 Cuisine Systeme Food...
Need bowl and lid for 5100
Oct 30, 2009 | Magimix 5100 Cuisine Systeme Food...
Jun 28, 2009 | Magimix 5100 Cuisine Systeme Food...
Where can I buy a 4mm and 6mm grater for Magimix 5100
HI! magimix-spares.co.uk seems to do quite a lot of spare parts for a range of models. Here's the web address for the 5100 model: http://www.magimix-spares.co.uk/Magimix-5100-blades-and-all-discs-/products/1060/
Not sure if they'll have the blades in stock.... Hope this helps!
Jan 31, 2009 | Magimix 5100 Cuisine Systeme Food...
I require a manual for the 5100 please
i have found it with alot of digging about. go to....
http://www.magimix.fr/upload/notice_d_utilisation/ma_cuisine/download.pdf
to download it from the magimix web site.
and rangerbob, dont have a go at other people having the same problem as you, this is how this website works!
Dec 05, 2008 | Magimix 5100 Cuisine Systeme Food...
Dough hook stuck
New shaft cover req about £10.00 you will proberly have to replace any damaged blades aswell.
Sep 05, 2008 | Magimix 5100 Cuisine Systeme Food...
Magimix sytem cuisine
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Jul 02, 2008 | Magimix 5100 Cuisine Systeme Food...
Magimix Cuisine 5200 1522 Cups Food Processor Logo
418 people viewed this question
Top Magimix Food Processors Experts
Oloyede Monsuru
ray gallant
Are you a Magimix Food Processor Expert? Answer questions, earn points and help others
