Question about General Electric DBSR463EGWW Dryer
How to replace a broken dryer belt - General Electric DBSR463EGWW Dryer
    New Friend:
    Problem Solver:
  • 6 Answers
Its actually really simple if you can take something apart and put it back together. If you will go to repairclinic.com they have videos that show you exacly how to do it.
Posted on May 28, 2013
How do you open the Frigidaire affinity dryer bc i think the belt is broken
If the belt is broken dryer will not tumble, you can turn drum and should be resistance to turn, if turns easy then belt is broken. This is a difficult repair. If you can't see how to open dryer you won't be able to replace belt.
Aug 30, 2014 | Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft....
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
How do you gain access to rge belt drive to replace broken belt on the LEN2000LW dryer.
you will need to open the cabinet:
http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
then replace the belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
hope the helped Tim
May 21, 2011 | Whirlpool LEN2000PW Dryer
Dryer heats but won't tumble
More than likely it is the belt. The dryer has a motor that drives the drum usind a rubber belt that has probably broken. It is fairly easy to replace. Take top off dryer by lifting up top in front, (should be hinged) then you will see if belt is on or broken. Go to local appliance store with make and model number from your dryer and then you will have to lift drum out of case and put belt around it and replace. if you cannot reach belt to put around motor from top you will have to remove back access panel. Put belt on motor and dry away. Good luck.
Feb 23, 2011 | Whirlpool Dryers
Broken belt for clothes dryer LG
Remove the front panel .. two screws probably.
Look for the belt tensioner on the floor when you get it open.
Mar 28, 2010 | Dryers
The drum has stopped turning in the dryer. How
well with no other information i would have to say its A belt
a very easy reapir
Oct 08, 2009 | Dryers
Kenmore dryer drum will not turn.
This is commonly caused by a broken dryer belt. If you post back with your model number, I can explain to you how to verify and/or replace the belt.
Aug 29, 2009 | Kenmore 63942 Dryer
Dryer runs but wont tumble
Try checking to see if the dryer belt is broken, the dryer belt wraps around the drum and goes to a motor at the bottom of the dryer that turns the drum, if so you can usually get a replacement belt from the maker of your dryer by visiting there website.
Mar 11, 2009 | Danby DCD5505W Electric Dryer
General Electric DBSR463EGWW Dryer Logo
69 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Tyler T
Level 1 Expert
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
