Question about Vulcan AUW230A Heater
I have a vulcan powerhouse ducted gas heating system The programmable thermostat will not allow any input and I think that it has died Can the item be replaced as it is a removable item and were can I get one No's on back are T8602C 1 053 9521
    Genius:
  • 1,015 Answers
Yes I would agree with you that t-stat may be gone but have you recently put new batteries in your t-stat. If you have then you can get a new stat from hvac dealer or check with your local hardware stores. I believe that is a honeywell number so should not be hard to find replacement. When you change it just make sure you get wires back on proper terminals. Thank you and have a good new year.
Posted on Jan 04, 2011
Bonaire gas ducted heating not reaching set room temperature anymore...
has the system air filters been serviced lately
is the system circulation fab been cleaned to allow full air circulation of the system
call in a technician to check for vermin infestation preventing the system from working properly
Jun 20, 2016 | Heating & Cooling
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
I have a vulcan compact 60 sn# 1744 cat# 38-05 aw 166 the problem is the gas burner shuts down periodically about every 4-5 min, leaving the fan still running for a further 3-4 min, blowing out...
Hi Dave, my neighbour has a Vulcan Compact 60 that is doing the same as yours, except the cycle time is even shorter, only four minutes total. The temperature in the house barely rises and never reaches the thermostat setting. Altering the thermostat anticipator does not alter the cycle time. Therefore, as you have found, the fault is not related to the thermostat. The gas technician who inspected the heater said he could see the unit was faulting, but didn't think he could fix it. WTH? To help my friendly neighbour, I have asked numerous experienced techs since and those few who actually seem to know anything have helped me piece together what is probably (I emphasise probably) happening. Current thinking is that the fan is not blowing enough air and the heat exchanger is overheating, which trips the over temp switch (limiter), cutting off the burner. Eventually the fan cools the unit down enough to switch itself off and reset the limiter, then the cycle repeats.
The remedy is to replace the fan or replace the fan bearings, if they have become tight, as is likely the case. It might also be necessary to replace the combination fan/limiter switch, because the contacts are probably arcing due to the extra current drain of the fan with tight bearings (I know this because the arcing causes TV and radio interference to myself and others in the vicinity, which interference ceases when the heater is turned off and resumes when the heater is turned on and had about 20 minutes to heat up). Important: If no action is taken, the heat exchanger can be damaged and/or cracked, especially if the limiter contacts weld closed, which will allow the heater to exceed the limit temperature and probably crack the heat exchanger. This in turn will allow carbon monoxide fumes to enter the house via the ducts. Therefore the problem should be fixed ASAP.
I am currently trying to find someone who understands this heater to the extent described above and therefore has some chance of repairing it correctly. No success as yet, similar to your own experience.
Dave, if you discover anything at all about this fault, please let me know, as I am not going to waste my money on gas techs who are unable to fix the problem because they don't understand the system to the required degree.
Parts can be obtained from many gas supply houses. The one I normally use quoted about $300 for a fan and $150 for a fan/limit switch. This seems too expensive to me. I could get a whole second-hand unit for about $300. Will try to let you know if I make any further discoveries. Anyway, best of luck. Regards, VC60.
Aug 17, 2010 | Vulcan Heating & Cooling
Problem with Vulcan Powerhouse 145 cental heating unit.
You should have a high limit switch possible on the bloiwer compartment may be man reset or just bad you do not say how old unit is I would temp jump out high limit to test operation then replace asap
Jun 11, 2010 | Broan-NuTone 9965 Coil / Ribbon Heater
Ive got a Vulcan Gas dusted Heating system -
Possibly a bad thermocouple or whatever is sensing the flame. If its a flame rod you can clean it with steel wool. Let me know what you find.
May 05, 2010 | Heating & Cooling
Only have two wires on old thermostat,where do i hook them up on a rth2310 thermostat
More information would help but I believe that you are trying to hook up a programmable thermostat to your old heating system which is what? Oil forced air, heat pump, gas? Give me more info and I think that I can help you.
hardrocko
Feb 07, 2010 | Honeywell Electronic Programmable...
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Forced Hot Air Heating system doesn't maintain thermostat setting
It sounds like you may have issues with the furnace. A qualified professional can go over the system and the house to let you know if the system and unit are properly sized. The poor performance of a furnace can be a sign of carbon buildup in the furnace.
Good luck, hope this helps.
Matt
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
Wiring a Honeywell Deluxe Programmable Thermonstat
did you mark which terminals you removed the wires from on the old stat? If not you will need to look on the furnace and see what letters they are connected to .. then connect to the same on the thermostat.
Feb 11, 2008 | Honeywell Programmable Thermostat Heater
Vulcan AUW230A Heater Logo
398 people viewed this question
Top Vulcan Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
