Question about HP Officejet Pro L7580 All-In-One InkJet Printer
I have some labels I am trying to print that contain purple in the layout. Only thing, they are printing more pink, and not so much purple.
    President:
  • HP Master
  • 2,246 Answers
Check your crtrij head setting, try to set default
Posted on Jan 04, 2011
My printer prints in pink
1)Have you tried copying the data from Internet to word application
and then print the word document.
2) Otherwise uninstall driver and re-install it from here
http://www.siliconguide.com/drivers/device/1726/
Jan 04, 2015 | Brother MFC-465CN InkJet Printer
LX810 Label Printer is printing out labels that are the wrong colour. Oranges are pink, darker colours are pink, and some are purple. I have swapped out the ink cartridges and the problem is occurring. Any...
It's time to clean the printhead. Use the procedure from the printer status monitor. Try cleaning several times but beware it will drain some extra ink from the cartridges. If the cleaning process will not increase the quality of print, probably you will need to replace the printhead. Before replacing printhead, remove all the cartridges and verify if all four gaskets (seals) are present on the inner bottom of the printhead. Also remove printhead, clean contacts both on the back of printhead and carriage with isopropyl alcohol. Put back printhead and cartridges and let the printer do its ink system initialization process. Then try to print your labels again. If all those attempts fails, replace printhead.
Apr 30, 2014 | Primera Technology Primera LX810 Color...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
I created a new label layout in Filemaker pro to print a 4" x 6" label. When I print this label on the Zebra LP 2844 printer it prints fine. If I try to print it on the Z4MPlus it enlarges the print and...
The easiest solution would be to create a new label layout in FileMaker specific for that printer that can be used when printing to that printer which would solve that problem.
The issue with the size being enlarged is most likely with the printer driver and not the FileMaker software so that is where I would look around to see if there is a scaling setting, or some other setting that needs to be corrected in the driver/page setup area for that printer.
I hope I've done a good job answering your question. I am a FileMaker 7 expert (and 8, 9, and 10 as well); if you have any additional questions I will do my best to answer them. If my answer was helpful for you I'd appreciate a 5 thumbs up rating, or a click on the yes this was helpful button. Thank you!
Aug 13, 2009 | Zebra Z4Mplus Label Printer
Do both print cartridges have to be installed?
there shouldnt be anything covering the print heads when you install them and yes both cartridges have to be installed.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00652671&cc=us&lc=en&dlc=en&product=1146331
this link contains all the information on installing an ink cartridge.
Thanks and enjoy. Pleas don't forget to rate.
Lee
Mar 01, 2009 | HP Photosmart C3180 All-In-One InkJet...
Can only print one label when I set up Avery Labels
Hi. Look at the label contents. I believe the top corners of the group is touching the header. Meaning it should only print 1 time.
Make the content smaller and be sure it is inside the body area.
Jan 23, 2009 | FileMaker Pro 7 for Mac, PC
Dymo 400 laser turbo prints the label then multiple labels after that
This is due to the print template you have chosen.
control panel > printers > right click dymo print icon > properties > press "printing prefrences" in General tab > click "Advanced" button in layout tab
Here you can choose the paper size. The dymo "shipping label" (30573) sold in most office stores is template number is "30323 Shipping".
Also these templates choices are available in the software you are using to print the labels under file -> print setup or whatever your software calls it..maybe "print setup"
Hope this helps.
Jan 21, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Cannot print lables. Other printing is okay. Everytime I put the labels in the printer,they do not print- just goes thru the motuions.
what printer? do you have labelling software installed? or are you using just standard word processing?
you may want to get avery label software. it's specifically used for those types of uses (though you don't need to use their labels as long as the labels are using a similar layout).
you can find the software at most office supplies.
if you want to use something free try
http://www.download.com/BarCode-Label-Printer/3000-2064_4-10537435.html?tag=mncol
Dec 05, 2008 | Lexmark Office Equipment & Supplies
Extra caracters on Zebra S4m
Since it happens with all your printers ,this tells me that it is not a printer problem.
SO....
Lets look at the application..
The first label sees it as PAGE 100 and if you print 50 it should count up to 150.
look at the application and edit it to turn off page numbering .
Nov 20, 2008 | Zebra Printer 140-751-00000
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
