Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Our Kitchenaid kscs25fkss00 is staying cold on bottom of freezer and frig but not on top - ice stays frozen on bottom but melts on top. We tried replacing the fan but that didn't work. We have been told the likely culprit is the circuit board but that it is no longer available. Ideas?
  • 2,382 Answers
Hi, when the compressor runs during the call for cooling, the evaporator (freezer section) fan must run, to force cold air in through the freezer-to-fridge section vent. And if you have a condensor fan that blows or sucks room air through the hot coils, that has to run also. If either one is not, there is your problem.
Or the freezer coils may be iced up inside, and there is so much ice (that has become an unwanted insulation) that not cold enough air is being picked up by the freezer fan. And/or that vent also got blocked with ice. When either of these happens, it still will be able to freeze in the freezer - but the low temp may only be say 20 degrees, and you might have 50-60 in the fridge section - when you want about 0 in freezer and about 35-37 in the fridge section.
The cause can be from a defrost timer not working, or the defrost thermostat strapped onto the freezer coils is shot (the electrical circuit within it should be closed, when the coils are frosted), or the defrost element itself is shot. You can test both of these with a voltmeter. If you have a newer digital fridge, you may have some more modern stuff, like a control board and a thermistor involved.
If it is the circuit board, you need to replace it as you already know......
Posted on Jan 04, 2011
How do I fix ice build up at the back of the fridge compartment?
make sure door is closing properly,and turn temp down,or should I say up,warmer
Feb 17, 2015 | Refrigerators
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
Our 14 year old KitchenAid Superba side by side refridgerator (Mondel KSRS22FGBT01) is not cooling the top half of the freezer section. Bottom half seems to be able to keep cold - but top half doesn't....
Do you see any ice build up on the back wall of the freezer compartment? You probably have one of the following problems: A failed defrost system, meaning the defrost timer and/or element has gone out and your evaporator coil is frozen over; you are low on freon and this too will cause your evap coil to freeze over until the freon drops so low all cooling stops; or there could be a clog in the capillary tube which is the very small diamiter copper tube that carries the condensed liquid freon to the evap coil. Unless you have gauges, a licence to buy freon and service valves (or a buddy with such) you are limited to what you can do. Here is my advice:1. unplug the frig and let it defrose over night, unplug the frig and empty the freezer to remove the back cover to look for ice, a frozen fan and if so get your hair dryer out and melt the ice so you can test the fan and the defrost element (you will need a volt/ohm meter to do the element check. You can do it.
Oct 13, 2013 | Refrigerators
We bought our frig exactly 6 years ago (to the date!) and suddenly the frig part is cool, but not cold, while the freezer section stay cold and ice is frozen.
Check your freezer section ! Is the coil frozen over ? If so it may have a burnt out defrost element or a bad defrost timer. When the freezer coil freezes over cold air is restricted to the refrigerator section.
Jun 03, 2011 | Refrigerators
My refrigerator isn't cold, but my freezer still works.
Put your unit on a 24 hr defrost the freezer coil is frozen and blocked with ice the fan cannot draw any chill from the freezer section.
May 17, 2010 | Maytag MFD2560HES Bottom Freezer French...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Top sections of Freezer and Fridge not Cold at all
hi!!! You seem to have a problem with your evaporator fan motor or the defrost mechanism on the frig.That the defrost timer..Listen manually turn of your refrigerature and turn it on again when all the ice melts away if the fan work or runs then its your defrost timer on the frig.Easy fix man..Good luck..
Jan 03, 2009 | KitchenAid KSRG25FKSS Side by Side...
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
Bottom freezer not staying cold
One of two things. When you open the freezer drawer, do you hear a fan running? If not, that's the problem. The Evaporator fan. Its' job is to circulate cold air throughout the entire cabinet. Without it, things get toasty. If not the Evap Fan, it'll be the sealed system... meaning that it's developed a leak and freon is escaping (not harmful for you or your Family). If it's just under 5 years old, this will be a warranty repair. Over 5? Bad news... it'll cost ALOT to have it repaired.
Jul 29, 2007 | Amana ABB1927DE Bottom Freezer...
Icemaker issue: cubes melting at the bottom causing water leak out the front
J, sounds like your dispensor flapper is not closing properly and you are drawing warm air up into the ice bucket. This model had an issue where the flapper pin holder was part of the housing and would break off. They have a kit now that fixes that problem. The only other thing it could be would be low freezer temps or it's staying in defrost too long. With out being there, I would start with the dispensor flapper. Check it out and post back.. Catriver.
Apr 21, 2007 | KitchenAid KSRS25ILSS Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
101 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
