Question about Maytag Neptune MDE5500AY Electric Dryer
I had to switch out the electronic control board now it takes forever for the clothes to dry is the a calibration procedure i need to do.
  • Maytag Master
  • 3,053 Answers
Hello, bike I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
Try to program and it comes error L5
PAGE 63-64 in link Describe "LS" error.
7
Belts stop turning and "err
LS" or "err OS" is displayed
Calibration
Re-calibrate machine. (See Calibration Procedures, Pg 26)
SPEED
SENSOR
1. Cycle power off and on
2. Put the machine in calibration mode (see Calibration
procedures, Pg 26) but do not start the calibration routine.
3. Remove right rear base plastic cover to allow access to
LED board. Caution: Machine is on. Current is active!!
4. Locate LED D on the motor controller board. LED may
be lit or unlit.
5. Manually advance the treadle with your foot, and check
if LED D is blinking.
6. If LED D is not blinking, then the speed sensor is not sup
plying a signal. Check that the speed sensor is connected
securely to P1 on the motor controller. If sensor is con
nected and LED D still does not flash replace sensor.
I/O cables
If LED D is flashing when the belts are turning but err LS
or OS persists, check for signs of visible damage to any of
the three I/O calbes and connections. If no visible damage
check continuity using a multi-meter. If a multi-meter is
not available replace all three cables.
Electronics
If all I/O cables are functioning properly, LED D indicates
speed sensor is functioning, and err LS or OS persists
problem is in either the upper electronics board or the
motor controller board. With machine on check LED A
on the controller board. If it is dimly lit replace upper
electronics (000-4430). If it is not lit at all replace motor
controller.
http://download.nautilus.com/supportdocs/AM_OM/Bowflex/BFX_TC5300_6000_OM_AM_RevA_web.pdf
Jun 04, 2014 | Bowflex Treadclimber TC5300
Kenmore Electric Dryer Model 110-C62662101. Dryer won't stop running. Will run all day long until door is open.
Problem with the timer control unit as it is not switching off until reset with the door latch.
it is possible that the dryer control relay or driver is short and giving power continuously.
Sep 30, 2010 | Kenmore 62622 Electric Dryer
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
NO HEAT ON ANY HEAT SETTING
use a flamethrower.
Oct 24, 2009 | Dryers
Clothes not being washed
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 01, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Wont dry very fast
Nope change the control thermostat mounted beside the skinny white fuse on the blower housing.
Jan 30, 2009 | Kenmore 62602 Electric Dryer
Dryer takes forever to dry clothes
firstoff, youll need to check for a clean not kinked vent, mosttproblemswith "too long to dry are genrelly tracedback to innadequate/poor venting"
Jan 26, 2009 | Whirlpool Dryers
F 1 code - clothes take forever to dry
It probably is the thermistor. I used to work for Sears and that code means that something is wrong with the thermistor or the thermostat. It is located on the heating element housing. If you remove the lower panel by taking out the two screws that keep it in place you will see the lint screen housing. Remove that and you will see the heating element. The thermistor is located on the heating element housing somewhere. It's hard to say exactly where as it varies by model. There are three things on it though, the thermal fuse which is small and has two wires coming from it. The thermostat which is a bit bigger and the thermistor. The easiest way to find which one it is is by hooking up a volt meter to each one to see which is not getting the proper voltage. The Sears guy should have fixed it when he was out there, it's not an expensive repair. The part is only around 15 dollars and the labor is cheap. Let me know though if you have any other questions and if this was helpful. Good luck and have a good weekend.
Jan 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryer
things to take into account- are all the filters/ customer cleaning service parts clear?
is there good airflow and are you overloading the unit? there should only be 1 heater element controlled by a reduced heat switch.
Mar 16, 2008 | LG DLE5932W Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
