Question about AudioBahn A1504DP Car Audio Amplifier
Spilt a lil **** jucie on it. some smoke came out. i want audiobahn to fix it. will they?
  • 88 Answers
If it isn't fried too bad they should but its gonna cost you
Posted on Jan 04, 2011
1984 honda big red smoking out the exhaust littel oil coming out tho also it has the wrong carb on it the carb come off a honda atc 200x
If it is black smoke, it could be running rich and the correct carb will fix that. If it is blue smoke, then it is burning oil.
Apr 10, 2014 | Honda 84 Atc200 Big Red 200 Engine Stator...
Smoking white
Probably going to need new piston rings. Pretty sure your burning a little oil.
Feb 10, 2014 | Suzuki Motorcycles
Bike release black smoke
black smoke means to much fuel in the combustion chamber, the black smoke is the excess fuel that not get burned on the compression stroke, adjust the air/fuel mixture, dial fuel back lil by lil til no more smoke
Sep 26, 2013 | 2007 Hero Honda Passion Plus
1996 chrysler town and country lxi
Can't tell you what is leaking or the fix,
without seeing the car
Nov 22, 2012 | Chrysler Cars & Trucks
I change oil in my nissan titan v8 and after the engine started smokeing what do we do to stop the smoke.
if the smoke is coming from the engine bay, check for spilt oil or an oil leak, especially on the exhaust. clean/fix this and the smoke should stop.
if it is coming from the exhaust, check you have used the correct grade of oil (too thin oil may bypass oil seals slightly) and you have not overfilled the engine and this can cause internal pressure, causing oil to bypass the seals, or even blow oil seals completely. overfilling will also damage the catalytic converter.
Feb 23, 2011 | 2004 Nissan Titan
A2300HCT Car Audio Amplifier: i have a audiobahn a 2300 hct amp and it has stopp...
Well, sounds like you have an internal damage since it smokes, if it smokes as soon as it kicks on, and blowing the fuse right away, I would have it fixed. But my guess would be something with the ground that is making this happen, or some how your power is grounding on the amp. When ever smoke comes into play, thats never good any way at this point you gotta admitt that thiers internal damage.. blowing fuses can also be cause by over working your amp. along with the sub load at 1 ohm make sure your amp can do the same.. hope this was helpful in some way
May 16, 2010 | AudioBahn A2300HCT Car Audio Amplifier
It wont hold fuse blow evertime
if the fuses are blowing as soon as it comes on the amp is bad, if the amp is actually playing but popping the fuses after a lil bit of playing make sure your subs are wired to the proper impedence for the amplifier if the amp is pulling too much current due to the subs being wired at too low of a ohm rating for the amp.
May 03, 2009 | AudioBahn A2801T Car Audio Amplifier
Amp wont come on
you might have blown a mosfet transistor or resistor inside the amp
Jan 19, 2009 | AudioBahn A4004T Car Audio Amplifier
AudioBahn A2300HCT no sound
Generally, if the amplifier smokes, the power supply FETs have failed.
Many times, the output transistors fail and that causes the power supply FETs to fail.
Audiobahn won't release schematics. The amplifiers are relatively simple and a schematic isn't generally required.
If you know how to check the transistors, check them to determine the severity of the damage. If you don't know how to check them, read through the following page following all links provided.
Basic Amplifier Repair
Let me know if you have any other questions.
Sep 04, 2008 | AudioBahn A2300HCT Car Audio Amplifier
AudioBahn A1504DP Car Audio Amplifier Logo
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
