Question about DEI Python 1400XP Remote Start/Keyless Entry System
Why is it that in the last 2 weeks, sometimes the car starter works and sometimes it doesn't?? It cant be the battery cuz it shows a green light PLUS I tried using my 2nd one (extra remote) and I have the same problem, only starts once in a while. Help??
  • 42 Answers
The problem sounds like it is how the starter works. It starts and afte a few seconds it does a system check to see if the car started and if works right it will continue to leave the car on and if not it trys 2 more times to start and stay on. Most techs use voltage sense or a virtual tach signal to do the system check. I have found that the best way to have the starter work and stay on is by hooking up the tach signal and making sure the options are set for system check ON and Tach signal check on.
Posted on Feb 02, 2011
2004 Chevy Cavalier - car cranks over but doesn't start
Ignition module or crankshaft postion sensor . Test it in the vehicle , test light , volt meter . Videos on youtube .
2004 Saturn Ion 2 2 Misfire Case Study P0300
Mar 25, 2017 | 2004 Chevrolet Cavalier
Replaced the starter as the car was not turning over. The old starter tested good but still replaced. Ran fine after installation. Sitting overnight, not starting once again this morning. Turns but...
I would be looking for the following: If it'an automatic, while it is acting up put it in neutral and see if the starter works? If so, either poor connections to or bad neutral safety switch.
This car also uses a starter relay. According to my data base, it is located foreward of the right front shock tower and the second one in from the engine side.
Check for solid grounds from the battery to the engine. Corroded connections will peform worse when they are cold, sometimes, even causing an open circuit.
I hope this has pointed you somewhere in the direction you need to be looking
Aug 16, 2011 | 1993 Eagle Talon
03 aprilia Mille doesn't start. Sometimes it turns
Hi, Aleksandr and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
DOWNLOAD 2003 Aprilia Rsv Mille
Aug 15, 2011 | 2003 Aprilia RSV Mille
I have a 2006 pt cruiser sometimes it has a hard start and can / doesn't want to start and other times it will go for weeks without any problems i had a mechanic look at it and he said he thought it...
Look at your battery terminals and see if there is corrosion. I had the same problem with my 06 pt. It turned out that the positive cable going to the starter was corroded internally. was replaced and now no more hard starting.
Jun 15, 2011 | Chrysler PT Cruiser Cars & Trucks
2004 Range Rover HSE won't start. Last week i had problem starting the rover. I checked the starter and the relay and was hoping that it could be one or the other. But this week i noticed that the...
Sounds more like a low voltage current flow in the ground circuit(harness).
Or the voltage output from ignition switch.
If No check engine light ever came on, or is not on, then the PCM/ECM is telling us there is No fault anywhere,
TCM-automatic transmission computer- uses VSS- vehicle speed sensor, to know when to shift gears.
A low input power to any of these control modules would result in lack of performance
Rough shifting could be caused by low fluid level
1. Check all fuses
2. ensure the battery cables are tight.
3. Check negative from battery has ground to frame rail
4. Check Transmission Fluid Level.
If you notice other symtoms, or situation continues, please post back
Mar 02, 2017 | 2004 Land Rover Range Rover
Hi, I am having intermittent starting issues with my 2004 SAAB 9-5 2.3T(4 cylinder). When it doesn't start there is clicking sound from under the hood. Sometimes it feels it is almost about to start....
steering lock malfunction sign shows up on my screen with a picture of a steering wheel and a lock on it appears as well. they want a 110.00 just to tell me what is wrong. sometimes it will not start or will not go in gear. what could this be?
Sep 15, 2010 | 2002 Saab 9-5
My 2004 330ci won't start, does not turn over. The battery is fine, all electrical in the car work fine, plus trying to jump car does not work & a green light is showing on the battery in the truck....
If the battery is fine, why jump it? Faulty thinking to state or think: all electrical in the car work fine. If it did the starter motor would be turning the engine over. The starter motor work on electrical...not all is fine.
check: 1) 60a starter fuse/relay. 2) voltage to starter when turning key to activate starter motor, this will rule out ignition switch or relay. 3) apply direct voltage to starter motor to detect bad starter motor.
Jul 02, 2010 | 2003 BMW 330
My 2008 1100 silverado will not start all lights work it has been sitting a week
Howdy: I have a Vstar and I use a ticklier battery charger if my bike will set for a week or longer. The lights will work but just not enough juice to turn over. Once started the bike will recharde at a high idle. Be sure to only use a 1.5 to 2 amp charger. Sometimes Harbor Freight will have chargers cheap. Your battery should last 3 or more years. For a new battery go to Battery Plus. Ride safe- Doug
Dec 09, 2009 | 2004 Yamaha V Star 1100 Silverado
Haven't used mouse in a while. Green light on
Yes, new batteries should correct this problem for you. It's recommended if you will not use the mouse for more than 2 weeks, take the batteries out.
Good luck
C2Solutions
Oct 19, 2009 | Logitech Cordless Click! Plus Optical...
Open Questions:
See all DEI Python 1400XP Remote Start/Keyless Entry Questions
DEI Python 1400XP Remote Start/Keyless Entry System Logo
144 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
