Question about DeLonghi MG15T SafeHeat Oil Filled Radiator Heater
The heater is making a popping noise. how do i get it to stop?
My water heater makes a loud popping noise. I drained the heater & it stopped for two days but has again started popping. It seems to pop when the hot water is turned on.
Sounds like an old water heater, full of rust at bottom. maybe coming to end of its life. Think new if over 7 years old. Did you replace anode rod? Probably shot also. Good Luck...
Aug 30, 2011 | Whirlpool Water Heaters
I have a cs1205 electralog heater. after 5 minutes we hear a pop and the heater stops working. we shut it off and will hear a pop then turn it back on. it will work again for about 5 minutes. what is wrong...
I have an electralog cs1205, when i turn it on, although it works , after about 10 seconds it makes a strange noise. It never did this before. Any ideas on whats wrong?
Nov 27, 2010 | Dimplex Compact Electric Flame Stove...
MTB2456DEW makes a popping noise every hour or so
thats nothing to worry about,its just the defrost cycle and its drippingwater on the defrost heater and sizzling as it evaporates,this sound is normal
Jan 07, 2010 | Maytag Refrigerators
Water heater makes a constant hissing noise with power on or off?
You have a water leak under the house, but need to know if it's a gas heater or electric. check the Pop off valve on top of the tank it has a short handle and should go threw the floor pull up on the valve and let it sit back down, if it stops the high pressure pop off valve is leaking, you can buy it and replace it for 5 or 10 bucks, if that does not stop it look under the house. Also use a broom stick and put the round end at the wall and the other end near your ear and check the wall and floor for the noise the closer you get the louder the sound. Hope this helps. If you look under the house and see water you know you got a leak in the pipes or the tank itself.
Jan 05, 2010 | RELIANCE ELECTRIC WATER HEATER
My electric reliance water heater is making a constant noise
it might be hard water in the heater. the hard water flakes and when your water heater turns on it creates some movement in those hard water flakes and makes a popping and hissing noise then when it comes to temperature it should stop. the temperature and pressure relief valve shouldn't make this noise. but if you stick your finger in the pipe and it is wet then you might have problems some where else. let me know if it is
Jul 29, 2009 | RELIANCE ELECTRIC WATER HEATER
Loud noises, shaking, visible white powder in chlorinator
Stop using the heater immediately. You are boiling the water inside and this can lead to a dangerous situation if a limit switch fails to act in time.
You will likely find the diverter in the inlet side of the heater is broken. You are looking for a stainless steel plate in the water path. If you can move it by hand, it is broke. It is not replaceable and requires a new heat exchanger assembly to repair it.
Your part number is IDXHXA1101. We sell it as will most pool dealers. If you would like a quote, contact us at www.arrowmotor.net
Jun 16, 2009 | Hayward H Series Induced Draft Abg 100,000...
Fahrenheat baseboard heater
no this is normal for this type of heater during its run time,I hope this makes you feek a little better!
Oct 24, 2008 | Fahrenheat Built-In Baseboard Thermostat...
Noise
When the freezer goes into defrost mode, some thumping/popping noises can sometimes be heard as the defrost heater melts the ice built up on the evaporator. Quite normal.
Nov 01, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
DeLonghi MG15T SafeHeat Oil Filled Radiator Heater Logo
579 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
