Question about Panasonic PT-53WX42 53" Rear Projection Television
ATTENTION SD TECH....have a PT 53WX42 set 4 about 8 years w/ no problems, but suddenly have a vertical-line only convergence problem. Went thru the manual & did both the convergence 1 & 2 fix procedures which helped but didn't fix totally. 1 problem was no outside reference marks on screen for the convergence 1 fix. What's the next step? Thx 4 ur help.
    President:
  • Panasonic Master
  • 2,246 Answers
Change your tv mainboard with new one
Posted on Jan 04, 2011
Convergence problem Panasonic PT-53TW53G
First I know this set well, did you pull out the board or the light box to replace the chips?
Convergence problems are usually easy to see...
see attached photos and tell me as much as possible.
SD TECH
Nov 10, 2011 | Panasonic PT-53TW53 53" Rear Projection...
The colors on my tv doesn't line up right. It has a 3D look and i tried to converge it. It will not let me do it. Its a panasonic HDTV PT-47WX42, PT-47WX52, PT-53WX42, PT-53WX52, PT-56WX42, PT-56WX52
set uses two of the STK-392-110 chips for convergence.
Both will have to be replaced.
I have start to finish step by step instructions for this repair based on me doing it in hundreds of these sets.
If you want the instructions, do you have a email?
SD TECH
Jan 15, 2011 | Panasonic PT-47WX42 47" Rear Projection...
My screen is showing double vision with the second picture in red. What should I do?
This is called a convergence problem and you have 2 choices: get a estimate from a shop (250 is typical) or if you are handy do it yourself; I have available start to finish, step by step instructions for this repair in the set you have. They tell you everything you will need and exactly how to do the repair. SD TECH
Sep 07, 2010 | Panasonic PT-53WX42 53" Rear Projection...
I am having a convergence issue with my Panasonic Rear Projection Television. Is this something I can repair myself? If I did hire someone to fix this for me, about how much would this cost?
I am the right person to talk to.
If convergence problem total parts cost on EBAY would be under 25 dollars AND I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THE DO IT YOURSELF PERSON TO DO THIS REPAIR.
THE instructions tell everything you will need and the best way to get at the two STK-392-110 CHIPS THAT NEED TO BE REPLACED.
Repair involves getting at and replacing both chips, it does involve being able to solder--not hard on this set.
If you want the instructions here or provide a email I will if you rate this solution very helpful give them to you for free, they are based on my actual experience doing hundreds of these sets with this problem.
See attached photos of what the chips look like and what a typical convergence problem looks like.
SD TECH
3590cf2.jpg The black parts are the chips, this is Hitachi but EXACT SAME TWO CHIPS ARE USED.
Typical convergence problem; no two will look exactly the same.
Aug 22, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Mitsubishi WS-65809 convergence problem
I know these sets very well and have posted instructions here for the chip replacement many times.
If you really need help I am in California and will be online noon until 11 pm tomorrow- (Pacific time) if you really want help post a question in the Premium section here attention SD TECH and I will help you more.
SD TECH
Jan 28, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Green convergence on Panasonic PT-53WX42 is not ligning up...
Does not sound like the chips are bad.
What you need to adjust is "SKEW". You need to enter "service Mode" then go into "Coarse Convergence". Skew can be adjusted for all 3 colors. Unless you have the service manual, these corrections should not be attempted.
To clean the INSIDE of the screen, you really have to disassemble the TV. Remove all the screws that hold the "back" ( the piece with the mirror) to the front (screen) assembly.
The screen can be cleaned with a solution of diluted isopropyl alcohol, no more than a 50% solution. Drugstores will carry it, but it might be 70%-90%. Just dilute with distilled water (not tap water as it contains minerals). Personally I have used 70% with no ill side effects but 50% is recommended.
Dec 08, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Can't correct green convergence
need to replace both Convergence ICs number STK392-110 you can het replacements here and they provide free instalation instructions and free on line tech support so you can do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Apr 16, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42
convergence IC bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42F Picture Problem. Color Distortion.
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Dec 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Green horizontal deflection
Change both STK convergence IC's for reliability. They amplify/control both horiz and vertical. re-align after replacement.Locate them on the largest heat sink in your set!
Sep 26, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
