Question about LG LRFD25850 French Door Refrigerator
LG french door fridge - makes hideous noise - loose bearings? - whenever fan is running, which is several times an hour. Any idea what is causing it? Husband tried to grease the fan. It's really annoying!!!! Thanks for your assistance!
  • 122 Answers
A broken fan blade can cause a noisy motor. or a buildup of ice can cause some noise. If thes aren't the case you will need to have the fan motor replaced.
Posted on Jan 04, 2011
Had my LG Fridge for five years with no problems. Then, yesterday, lots of fan noise that stopped when door opened. I googled a bit, and found in many cases it's due to ice build up around the fan. I peered into the back of the freezer, and indeed, lots of ice. Melted it, and problem solved.
You can find that info lots of places - but my theory is that I CAUSED the problem. A little over a week ago I came home with more frozen groceries than would fit easily. Instead of carting some downstairs to the second fridge, I jammed it all in - effectively blocking ANY airflow within the freezer compartment. I'm sure that's what led to the first ever ice buildup in the back.
So my suggestion is, once you've cleared the ice and solved the problem this time, be sure to leave plenty of room above the top shelf in the freezer drawer for air to move. If the air can't move, the evaporation fan can't work, you'll get ice build up, and thus noise. Free moving air in the freezer prevents the problem.
That's my theory, anyway. :)
Posted on Nov 25, 2013
  • Steve McAdoo
    Steve McAdoo Nov 25, 2013
    Sniper:
  • 66 Answers
This could be an ice buildup that reached the fan. Look at Avi's fix page that might help though it is not on same model. have fun Avi
Posted on Jan 15, 2011
LG fridge making loud noise
Bonjour,
jeepers are we talking about a wheeze, a clunk, a whirr, a buzz, a rattle, a hum, random modulated or cyclic, low or high frequency, persistent or intermittent? Or could you just be hearing fan noise.
If it sounds like tin pieces clinking against something metallic. The fan blades may be striking ice or frost or the shroud.
Could be a bad or worn fan motor bearing, or a defrost problem causing frost build up.
Just a FYI
Some LG models have been reported online as having many many operating issues.
Hope this helps
Jul 11, 2012 | LG Refrigerators
My fridge is making a loud nosies and it is not stopping
that is the auto defrost fan working,nothing to worry about.
Apr 09, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
My 2003 kenmore elite french door fridge made noise for several days, then died. Repairman said it was compressor...expensive repair, so I bought new fridge. Old fridge came back to life 48 hours after...
I bet the bearings in your compressor are bad. The compressor will run and heat up but after getting hot it won't always restart. Most of the time it happens with Tecumseh compressors.
Sep 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer frost buildup; fan constantly running; water filter
Just had mine repaired. Tech told me that the tempearature settings on the display panel are not EXACT science. The fridge is cooled by blowing air from the freezer to the fridge and when the sensor in fridge reached approx desired temperature, the damper is closed.
The noise you hear periodically (water dripping) is the heating rod melting the defroster (hence frost freeze), which unfortunately sometimes spills into the blower motor to fridge, causing frozen motor, causing the infamous ER FF error code and fridge failure.
I reluctantly had LG to do the energy saver fix (recall) and it replace everything that the internet users are complaining about.
Jun 27, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
HISSING SOUND FROM FRIDGE FREEZER
I poked a hole in the freezer with my knife while trying to defrost it. Now it is making a constant hissing sound. what should I do? is this dangerous?
Jan 23, 2009 | LG LRFC25750 Refrigerator French Door
LG refrigerator NOISE
I have the sam eproblem...another site I went to said it is ice build up on the fan. Unplug the frig for an hour (don't open the doors or everything will spoil) and then plug in...it may defrost a bit and allow the fan to turn freely.
Sep 10, 2008 | Refrigerators
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Jul 31, 2008 | LG LRFC25750 Refrigerator French Door
LG LRFC22750 Bottom freezer french door refrigerator
6343ed3.jpg The problem is ice build up on the back wall. The noise you hear is the fan blades hitting the ice. On the back wall water gets trapped, it then builds up over time, and a big ball of ice forms and blocks the fan. Take off the back wall, defrost the build up and cut the insulation off as above. The water will no longer get trapped and the problem will not come back.
Sgt 48
Feb 13, 2008 | LG LRFD25850 French Door Refrigerator
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
LG LRFD25850 French Door Refrigerator Logo
597 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
