Question about HP Pavilion p6116f PC Desktop
I updated my bios with the wrong version, i need to redo my bios flash. I Get a black screen on my monitor, and the motherboard beeps 2 short and 1 Long. Please help
  • 67 Answers
Http://www.duxcw.com/dcforum/DCForumID5/519.html
Try the link .................
Posted on Jan 04, 2011
Bios Beep
Motherboard BIOS Recovery Jumper
  • Install the bootable BIOS upgrade disk which you previously created to do the original flash upgrade into drive A: and restart the system. If the update failed because you used the wrong BIOS update you should get the correct one and repeat this step. When the computer reboots there will most likely be no video prompts, however you can monitor this procedure using the floppy drive light and the PC speaker. When the PC speaker beeps and the floppy drive light is lit it means that it is currently copying the new BIOS onto the motherboard.
  • When the floppy drive light goes off and the PC speaker beeps (twice in most cases) the recovery should be complete. During the update procedure there might be pauses that looks like your computer is doing nothing, if so be sure to wait at least a minute to make sure the update is complete. When you are sure the BIOS update is complete and there is no more activity, power off the computer.
  • Change the jumper you changed before back into the original position so the computer can operate normally.
When you turn your computer back on your BIOS will be functional and you should be able to use your computer normally again.
Apr 30, 2012 | Acer VL460-UD4500C WINDOWS VISTA BUSINESS...
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
My computer works normaly with an single core athlon 3200+ but when I use an Athlon 4400+ or 4000+ dual core, it just wont boot. The fans are running and lights are on but there is no signal on the monitor...
take a look at the motherboard manufacturers website and see if your motherboard will accept a 4400. You may need to update the bios on your board to accept the faster processor. You need to be careful if you flash the bios. do it wrong and you can write the board off.
Good luck
Aug 11, 2011 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
My bios speaker will beep on startup but nothing more. What avenue should I approach to get past this part of startup?
First you need to know which BIOS you have and how many beeps it is producing... these beeps are the POST - Power On Self Test. They tell us if there are problems such as missing keyboard, video card not working, memory faults etc...
Then you need to go to the appropriate BIOS site and see what the number of beeps mean.
If it is a single beep - it means all is well...
As you are not getting anything more you should check to see if the Hard Drive (HD) light flashes - if so - the HD is probably operating ok and loading your system but there is either a problem with your monitor or video card... borrow another monitor and see if that helps...
But it all depends on the number of beeps you get and what kind - long and short beeps (like morse code).
If this helped you at all please vote!
Oct 06, 2009 | Asrock M266A Motherboard
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
Bios wont start. 1 long beep 2 short
You are going to need to lookup your BIOS version and manufacturer and find the Beep codes list. each BIOS has non beep codes and beep codes. the beep codes are bad. find out what this code means and do as they say if you dont know how to find what BIOS version your running Goole "What BIOS am i runninng?"
Once you have that like i said google it and its beep codes and if you cant find it ill help
Apr 09, 2009 | ASUS M2N-E SLi Motherboard
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Blank sreen after bios update
Update BIOS with Boot Block Error Code/Beep:
Definitions Error Beeps Error Code (Port 80H)
BIOS updated successfully. 2L-1S-1L F1h
The BIOS file size is not equal to the BIOS ROM size; wrong BIOS file. 1L-1S F1h
The BIOS file can't be read; it is defective. 1L-2S F2h
The model ID is mismatched; wrong BIOS file. 3S F3h
The BIOS ROM has failed to be erased. Try to flash again. 2L-1S E1h
The BIOS ROM has failed to be programmed. Try to flash again. 2L-2S E2h
No diskette, or cannot locate the BIOS file.
Try to use a new formatted diskette and copy the BIOS file again. 2S D1h
Mar 27, 2008 | Acer Aspire 1640Z Notebook
HP Pavilion p6116f  PC Desktop Logo
51 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
