Question about Brandt Microwave Ovens
W@hotmail.comI have a brandt ceramic hob--CH 600 CE which is not working. Power is getting through so it may be the electrical curcuit. I was wondering if it could be replaced or repaired.
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my gas hob works fine,but
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Apr 22, 2011
  • 1156 Answers
SOURCE: I NEED A NARDI ELECTRIC
unfortunately, the manual for your Nardi electric ceramic hob is not available anywhere online. The manufacturers of this Unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of your Nardi electric ceramic hob via phone or e-mail and request for the manual from them. They might give it to you or direct you to a dealer where you can get the manual.
This is the best you can do to get the service manual you are requesting for.
Good luck.
Posted on Jun 15, 2011
I have asked the question why do you keep asking the same questions and don't answer the question I'm asking
there is a ceramic safety fuse inside the unit,to access the control panel or to remove it you need to open the case up and remove the outer cover,careful the h.v. capacitor can hold a charge up to 2000 volts if not discharged
Oct 25, 2012 | Sharp R-820BK Microwave Convection Oven,...
My gas hob works fine,but my electric ovens have gone off,i am getting electric power but they wont come on
heatman101
Apr 21, 2011 | Microwave Ovens
Model no.TI1613BS1 i have somehow caused the 'padlock' (which i've never used) on the bottom righthand corner to activate. now i can't start either of the 2 electric hobs. have followed manuel's...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
Apr 12, 2011 | Brandt Microwave Ovens
I have a problem with both my kuppersbusch ceramic gas hob GKE9851.OM 5 burner which has one burner that only lights on high and will not be turned down and my oven is one of those opthelmic or whatever...
unfortunately the oven is like a non stick fry pan
It still needs you to wipe over the surface after use
make a habit of using oven bags for cooking fatty foods as that saves the cleaning
as for the hob problem , get in a technician to fix the fault
Feb 06, 2018 | Microwave Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
I have a Brandt induction cooktop and 2 hotplates don't work at all and the other 2 now don't appear to be connecting with the saucepan. Heat light starts to flash then turns off completely. Unable to...
Sounds like a wiring problem,take off of course with no power and check it out. No harm if no power,and replace wire and or componet with same.
Jan 11, 2011 | Brandt Microwave Ovens
What is the ceramic fuse to the mains power supply
it is a fuse connected to the start of path of electricity to the power supply inside the m/c so if is burned it will cut the electricity from connectedto m/c > it will cause m/c to stop working >
it will be easy to see it from its material it is from ceramic>
thanks
Jul 13, 2009 | Sanyo EM-Z2100GS Microwave Oven
Microwave Ovens Logo
Top Brandt Microwave Ovens Experts
William Miller
William Miller
Chuck
Bill Boyd
Are you a Brandt Microwave Oven Expert? Answer questions, earn points and help others
