Question about Honda Water Pump Honda Engine
Hi There, I've been using my machine and it stops (runs out of petrol), so i left it for Two days and put Petrol but unfortunately I can't start it at all. it's almost brand new one
  • 5,603 Answers
Probably the last of the fuel ingested MIGHT have been contaminated. I would purge the fuel system getting clean gas into the system. You should probably remive the spark plug and check the condition. If there was a bit of water in the fuel, it could wet the plug and prevent starting. Safe thing is to repllace the plug and save old one for a spare.
Posted on Jan 04, 2011
Zero turn RZ 4621 2012 ran out of petrol stopped put petrol in now won't start dead is there a reset switch etc? if so were
you ran out of petrol when using it
the normal thing is to get off it and refuel
so with it not starting check that you have reactivated all the safety switches by
applying the brake
sat in the seat
disengaged the drive and cutters
all that you have to do when initially starting the machine
there will be no reset button for running out of fuel
Oct 29, 2016 | Cars & Trucks
Hi, I recently ran out of petrol on a run, I managed to get a little which got me close to home and I ran out again and had to push it. Now I've put more in and she refuses to start. The ES works
running the tank so low drags all of the rubbish in the bottom of the tank into the fuel system...doing it twice pretty much guarantees a blockage...
Oct 19, 2012 | 2008 Enfield Bullet Electra
I have an aprilia rx125 2008 & the oil petrol mixing system has been blocked off and now petrol & oil are mixed in the petrol tank, but the bike starts for 3-5seconds then stops & petrol comes out of
Hi Steve, and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue please visit the websites below. Good luck and have nice a day.
DOWNLOAD 2008 Aprilia Rx 125
Dec 04, 2011 | 2008 Aprilia RX 125
Mcculloch t 240 petrol will not start
If your petrol has been sitting in the machine for a long time then yes it is your petrol. Mix a new batch usually you cannot let that sit around for more than 30 days, I always try to use fresh mixes, usually that means making smaller batches unless you use your trimmer quite a bit, most people do not though and that's when problems arise.
Jul 04, 2010 | Garden
I have a xj 750 it starts ok but when i ride it starts back fires and run not wiveell and cut out and stops it will start again ok but runs not well again ive had it standing over the winter it was ok the...
You will need to clean your carbys to remove the natural wax that occures in petrol when it is left standing in the machine for any length of time unused
Apr 12, 2010 | 1981 Yamaha XJ 650
Hi i have a 2008 R1, i had cleaned my throtle body a day ago now as i have have fitted every thing back now my bike is not starting, the problem i have put petrol on the fly my bike got started just for a...
Unfortunately these newer bikes operates just like a car system and has a computer which controls everything here.You may need to connect the bike to a proper diagnostic tool in order to read or reset error code.
Oct 28, 2009 | 2008 Yamaha YZF-R1
Ford fusion 1.4 tdci will not start unless the hand pump is used
HAVE YOU CHECKED THE FUEL LINES WHERE THE FUEL PRIMING PUMP IS CONNECTED FOR ANY CHAFFING THEY ARE COMMON FOR CHAFFING BESIDE THE FUEL FILTER WHICH WOULD EXPLAIN WHY FUEL IS RETURNING TO FUEL TANK.
Sep 11, 2009 | 2004 Ford Fusion
Seam to run out of petrol, but did'nt. now wont start,
Make sure you are getting spark at plugs. Coil may be going.
Jan 26, 2009 | 1997 Subaru Legacy
Petrol car not start on gas
are there any fuses to check why my car wont start on gas...?
Oct 21, 2008 | 1988 Daihatsu Charade
Honda Water Pump Honda Engine Logo
57 people viewed this question
Top Honda Tools & Hardware - Others Experts
John Loiselle
Level 1 Expert
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Honda Tool and Hardware - Other Expert? Answer questions, earn points and help others
