Question about Car Audio & Video
I haave a sony xplod 600w 3and4 channel amp. all wires are correctly installed and it works for like half a second then the protector light comes on (goes green to red) and stays red. ive checked the ground with a rest light and double checked every thing do i need to just get a different amp or wut? thanks
  • 88 Answers
Well as far as getting a different amp depends on what kind of subs or speakers you are trying to push. Also it depends on how much you are asking the amp to do. If you are asking a 600w amp to try and do 1000w job its just not gonna work and it will shut down.
Posted on Jan 04, 2011
Red power/protector light
The amplifier has gone into protect mode and will stay in that mode until the cause is corrected.
Nov 17, 2013 | Sony Xplod 800W Class AB Bridgeable...
I have a Sony Xplod 800w Amp running a 10' Sony Xplod Amp....i unhooked the amp to do some moving and i tried to put it back in today and it didnt have any sound coming from it! I did notice the power...
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
May 11, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Sony Xplod Amplifier Problem
First make sure you are using at least a 12 guage speaker wire for sub connections. Second make sure you have plenty of breathing room in your mounting position, these things need air badly. Third of all, Xplods are not very friendly if they are cranked all the way up on your dB boost knob. Only crank it about 3/4 of the way up, then use your equalizer settings to tweak the thump.
Oct 20, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
My 600w power amp XM-554ZR wont turn on.Its an Xplod 4/3 channel, and it was working fine...until yesterday that i checked it. the green light was off.
open it n there is a red wire look at the end of it n u would see a black celinder with a with a white strip on it change that part if it is burn
Jul 14, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Xplod amp will not get off of power protection mode
if the protect light stays on the amp is blown or has flawed components and is only repairable by expirenced sony tech
May 18, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xplod 1200 watt
i had the same ploblem with my amp then i found out i didnt have a good enough ground. Make sure you groung it to your weel well or some part of the frame. Or you mite be running with a fuse thats pushing to much power i use a 100a fuse 5 gage power cord to power my 1200w xplode and my 2 12" kicker comps. Or if your using two diff kind of subs then you amp is confused in why your asking for 500w on one side and 600w on the other this will also make your amp light come on.
Jan 19, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
1000w Sony Xplode car amp
Sounds like the power supply is shutting down because of it sensing a bad output channel. I'm assuming of course that you have checked all your battery, ground, and trigger wires to see if they are OK. Good luck.
Apr 05, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony Xplod 1000 watt car amp quit working.
Almost all after market amps use 12v at very very low amperage to trigger the amp on. A temporary jumper from the battery plus terminal on the amp AFTER the battery and ground wires are attached should cause the amp to turn on. I would check to see if you have attached your speaker load correctly ESPECIALLY if you are bridging. Most of the blown amps that come into my shop are due to incorrect bridging loads from the speakers. Note that a 4ohm load bridged across both outputs of an amp will deliver a 2ohm load to each of the channels. When you parallel wire two 4ohm speakers together and then attached them to a bridged amp you will be putting a 1 (one) ohm load to each channel of the amp. Please don't make this mistake. It will fry your amp in about a month. Hope this helps. Good luck.
Feb 03, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Car Audio & Video Logo
128 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
