Question about Avanti BCA4422BL (4.4 cu. ft.) Compact Wine Cooler
Avanti fridge 440yw stopped running. suspcious of power relay. where can i find it if this is the prob?
Avanti platinum wine fridge. Makes a loud sound when turned on. How can we fix it and quiet it down
This can be due to the compressor turning on and off. this is common in old wine fridges
Mar 17, 2017 | Avanti Refrigerators
The display stopped showing temps and displayed a "6". The actual temperatures dropped to freezing. I unplugged the unit a few times for up to 2 days but the same issue developed.
Whirlpool Refrigerator Error Code: Flashing 6 on the fridge display
Condition: The 6th Sense technology is activated - If you put warm food in the refrigerator or leave the door open, the 6th Sense technology kicks on to return the refrigerator to the set temperature. The flashing 6 should go away once it gets back to the right temperature.
Part or Parts: Allow fridge to get back to temp on its own (no parts required)
Whirlpool Refrigerator Error Code: 6 on the fridge display
Condition: Computer error
Check: Remove power for 5 minutes
Part or Parts: If code returns replace mother board
Apr 29, 2016 | Avanti Refrigerators
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Runs but not cooling
If the compressor is running but the fridge is not cooling it will be one of 2 things.
1. Thermostat/defrost element
Your model may have a defrost element, if the thermostat is faulty it could be supplying power to the element to it will be fighting against the cooling, Check if it has 2 wires running behind the cooling plate and if it does you have to disconnect one of the wires from the thermostat and see if it helps.
2. The fridge could have a leak and may have lost it's gas, This is pretty much fatal and means a new one.
Mar 06, 2012 | Avanti SHP2403B
My freezer is working fine but the fridge is not cold at all. Not sure what could be the problem. Its an Avanti FF501W
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 11, 2010 | Avanti FF501W Top Freezer Refrigerator
I have Maytag plus side by side fridge. The freezer part stopped working, everything is defrosted and water was all over. I can hear the air blowing but it's not cold. What can I check before I call...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 25, 2010 | Avanti 2.2 cu. ft. / 62 liter Chest...
My Avanti refrigerator (about 12 cubic feet) is freezing everything in the refrigerator section.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 07, 2010 | Avanti 248Y Compact Refrigerator
Temperature began to warm up daily until now it just stopped cooling
Hi, I tried to cross the model number you gave with Avanti and it did not do an exact cross reference.
Usually when a cooler slowly warms up the causes can be
1. The Compressor is not running at full speed or has stopped running
2. The PTC start / run relay / Klixon assy mounted on the Compressor has failed
3. The run capacitor has failed.
4. The temperature control has failed.
If the compressor is running and it is NOT cooling then there is a coolant leak or the coolant system had become blocked usually in the capillary tube area.
The current model numbers for parts are here:
http://www.avantiproducts.com/parts-accessories/current/yes
And the Discontinued model parts are here:
Just note there are many aftermarket (like part) sources that will be much cheaper than Avanti sourced replacement parts. Most repair techs would advise you to use locally sourced replacement parts.
Feb 04, 2010 | Avanti WC42 Wine Cooler
2 mos old. simply stopped working. no power at all to lights, motor ,etc.
check if you get power by the motor if no power change the thermostat
May 13, 2009 | Avanti WCR683DZD Stainless Steel Wine...
Avanti EC15W-2 Thermoelectric - stopped cooling. Purchased on August 3, 2006.  Has always been quiet. Still is, but I can hear that something's running if I put my ear to it. Light works.  Any suggestions?...
I think the circuit board is nothing more than a power supply converting the 120 volts ac to dc. If that goes then there is no way for the solid state device to cool,
Is there dust under the back cover? Is there frost/ice build up in the fridge fan compartment. I suggest to unplug for a day and try again. Hope this helps.
Oct 22, 2007 | Avanti EC15W-2 Compact Refrigerator
Avanti BCA4422BL (4.4 cu. ft.) Compact Wine Cooler Logo
218 people viewed this question
Top Avanti Refrigerators Experts
John Tripp
John Tripp
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
