Question about Whirlpool Washing Machines
I have a LSR7010PQ1 whirlpool washer and when I turn it on it just keeps trying to fill up. It seems as if it gets stuck there. Don't know what to do.
I have the same problem. Have you found anything out yet?
Posted on Jan 12, 2011
Wont start
it seems that the lock is stuck or broke. Try to see if u can move it by hand. if not u may need to remove the switch while doing this make sure the wires were connected and not loose. your ? does not say the type of washer u have. mine is a whirlpool deut and I took off kick panel on front bottom of washer and was able to reach the switch when I replaced mine. u can get a new switch at applianceparts.com
Apr 10, 2014 | Washing Machines
Whirlpool washer keeps filling beyond fill and does not agitate - timer has been replaced
More then likely the soleniod valve has dirt stuck undr the seat and it cannot close....
When a washer just keeps on filling with water it is
Kind of the opposite of this problem that I wrote about in these tips...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 19, 2010 | Whirlpool Washing Machines
Washer will not spin clothes "dry".
Lgm0923, we're sorry to learn of the experience that you've encountered with your Washer. Have you tried the troubleshooting suggestions on page 5 of your User Guide? The link is below. https://www.whirlpool.com/content/dam/global/documents/200311/owners-manual-3955869-RevB.pdf
If further assistance is needed, please email us your name, address, contact number, model and serial number at Whirlpool_Reviews@Whirlpool.com.
Oct 24, 2017 | Whirlpool CAP2761K Top Load Washer
Hi. My water level knob is very hard to turn and the water level is not correct when filling the washer. Any thoughts?
if it has been quite some time since you turned the knob it is possible that it is starting to sieze up, you may have to replace the switch behind the knob
May 09, 2009 | Whirlpool WTW5560SQ Top Load Washer
WASHER WILL NOT STOP FILLING UP WITH WATER
Sounds like the pressure switch is stuck or the fill valve is stuck. If the pressure switch is not satisfied of the water level, it won't agitate, this is most likely cause. If it DOES agitate, then the fill valve is stuck. A kink in the pressure switch line or a pinhole can also cause this problem. The pressure switch is located in the console, it's white with a little clear hose going to it. It connects to the tub close to the bottom.
Mar 25, 2009 | Whirlpool 3.2 cu. ft. Washer
Washer will not turn on
You have some scale or something keeping the water fill valve open most likely. If it still tries to fill unplug the machine if it still tries to fill do the following. Remove the fill valve and disassemble it. If you see the dirt or rust flush it out when it looks clean reassemble it and before you attach the hoses put them in the washer and turn them on to flush out the lines then reattach hoses and try it.
If this helps you please rate me with as high a retign as possible. If not please restate your problem and help me understand better what trouble your having. Thnks for using fixya and good luck.
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer Drum Off Center
To my knowledge most washers have transfer bolts or retainers that keeps the position of the drum firm while in storage or in transit. there would be 3 or four of them. Please verify that all the transfer bolts were removed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 25, 2008 | Washing Machines
Washing Machines Logo
61 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
