Question about Microwave Ovens
Need a power cord for GE Model TKSP-S020A-15
Where do i locate the fuse
Although you have not mentioned the model/make, take a look at the video here for replacing a Thermal fuse. Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
on traditional fuse see
How to Fix Microwave Oven Simple Fuse Replacement
Mar 08, 2016 | GE Microwave Ovens
How do you change the power level and what are they called?
Not all microwaves have the option to change power output but if the do, Full Power, Half Power and Defrost. The Defrost setting provides half power for about 15 seconds and then pauses for about 30 seconds before giving another 15 seconds and carries on doing this until the timer ends. It can also be used for keeping food warm once cooked.
Google
Make model manual
Jan 17, 2016 | GE JVM1790 Convection / Microwave Oven
GE JEM25GY Spacemaker died. No lights and won't turn on. Power from recepticle is OK. Shall I just buy a new one. Probably had this one for at 15 years. Thanks
Jerald,
It may just be a blown fuse. At 15 years old it might be a good idea to consider a new one but replacing the fuse is not real expensive and fairly easy to do. Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 07, 2015 | GE Microwave Ovens
How to find fuses on my GE Spacemaker XL microwave model# JVM1340 WW
First thing is make sure you unplug the power cord. Turn the microwave around and remove the screws that hold the cover on. Remove the cover and look for where the power cord goes through the back of the unit. Follow the black wire coming from the power cord and that will take you to where the fuse is located. It might be on a small circuit board or mounted in a fuse holder or it might have an inline holder. Make sure that you replace the fuse with the same amperage fuse as you take out. You will find the amp rating stamped into one of the collars on the fuse. Good luck!
Feb 27, 2015 | GE Microwave Ovens
GE Microwave Model JVM1860 burning smell
check 1) power cord for burn 2) wires 3) connector, 4) motor 5) switch, etc see the photo attached. and replace it.
God bless you
Nov 22, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Replace power cord
Definately replace power cord. I work with these microwaves all the time and if you don't it will cause a chain reaction and the fuses will explode into tiny sparks. This is coming from an expert
Jul 25, 2013 | GE Microwave Ovens
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    Hi! Our GE Spacemaker microwave (JVM241BL) stopped working..... nothing on it works at all. We have checked the breaker box in the basement and made sure it is plugged in. We are assuming it is a fuse...
    Turn off the power before starting this process. If the oven is dead, the fuse is probably blown. Remove the two screws that hold the touch pad and control board in place to access the fuse. Once inside, look towards the back and follow the power cord that enters the rear of the microwave to the fuse. It should be a 15 amp ceramic fuse.
    Dec 04, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
    Have a GE model JVm1650bh05 Microwave. I put in
    Check the fuse in the bottom of the oven ... near where the power cord enters.
    Oct 19, 2009 | GE JVM1630 Microwave Oven
    GE Microwave - Power Cord Appears to be Dead
    Most microwave ovens are equipped with an internal fuse. This is typically located where the power cord enters the cabinet. The cabinet will have to be opened to verify the fuse.
    The magnetron is not directly attached to the power source, it has to be stepped up in voltage significantly, either through a transformer or inverter.
    It is usually best to have professional tech check the fuse for operation. Most shops will do this for a small fee if you drop the unit off yourself.
    Jul 28, 2008 | GE JE1860 Microwave Oven
    Microwave Ovens Logo
    162 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
