Question about Tappan Kitchen Ranges
The digital numbers on the control panel are faded out
  • pm1959 Jul 09, 2008
    Thanks. I was hoping to avoid that since the part is over $200 and the stove is 12 years old
  • 770 Answers
You will need to replace the control panel also before you do that clean the ribbon connectors with an pencil eraser
Posted on Jul 09, 2008
I have a PROFTECH HD set top box remote and all
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Sep 17, 2014 | Televison & Video
How do i find the year my a/c unit was made ?
Find the name plate data and look at the serial number. It is normally a 9 or 10 digit number. The first two number is the year the unit was made and the next two numbers is the week manufactured. for example 0615xxxxxxxxxx is the year 2006 and the 15th week. If the name plate data is fades, look at the paper posted inside the control section. If it is still there you should be able to get the model and serial number.
Aug 23, 2014 | Goodman Heating & Cooling
Pentair Easytouch 8 loses low voltage power to contol panel
if while it fades check voltage from transformer if ok bad control board if fades bad transformer
Feb 17, 2018 | Pentair EasyTouch 8 System Pool and Spa...
How do you find out your model number on an old unit when it is faded out, need to replace the limit switch on a 1995 ruud 4ton 10 seer. The limit switch is also faded.
If you can find the wiring diagram pasted on one of the panels you may find the model number printed on it. Even if there are a few different numbers on it, most parts for all those models are interchangeable.
Feb 16, 2010 | Ruud Central System Air Conditioner
PICTURE SUDDENLY DARKENED AND IS FADING AFTER 4 DAYS
you may have just put it into fade out. find thee fade out control and reverse it the mode. hope that works.
DFD
Apr 11, 2009 | Televison & Video
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Feb 19, 2009 | Thermador C302U Electric Double Oven
Temp/clock display faded
its the display that is going out on the ovenlike everything else things just fad away. Actually I have had LED meter displays do the same thing.
Dec 23, 2008 | Thermador SC302T Electric Double Oven
Display panel slowly fades out, then comes back on.
This is due to a bad connection which is interrupting power to the control panel. It may be a loose wiring connection prior to the control panel, a failing door switch, or a problem on the control panel. We repair the control panels for $32.50 nationwide. If you or a friend decide to check the wiring, the unit has a technical sheet inside which contains a wiring diagram similar to the one I linked here: http://207.234.2493.73/mwd/JVM1331W_wiring.jpg Also, you can find an exploded view and parts list by entering your model number in the repair parts section here: http://www.geappliances.com/shop/prts/
Dec 16, 2006 | GE JVM1653 Microwave Oven
Kitchen Ranges Logo
76 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
