Question about Whirlpool ET6JTKXK Top Freezer Refrigerator
My freezer motor keeps running and wont shut off.what can i do to fix my problem?
  • 122 Answers
The freezer or evaporator fan runs whenever the temperature controls is closed and the compressor is running. The control may not be getting satisfied and continues to call for cooling or there is a possibility that there is a short in the wiring. If the refrigerator temperature is not below 40 degrees it cold mean there is a problem with the sealed system.
Posted on Jan 04, 2011
My ge freezer wont freeze
Did you lay it down when you moved?, if so you may have oil in the lines . Did you bump any Freon lines and cause a leak?
Aug 31, 2014 | Freezers
Motor wont stay idle need to keep pumping gas pedal to keep motor running.
If it smoothly idles down to shut off it could be the throttle stop screw needs to be ran out a little. If it runs rough it could be a stuck float or needle Lots of times a good soak and cleaning will fix a problem. don't use ethanol gas without some sort of conditioner.
Sep 21, 2013 | Motorcycles
My frigidaire freezer keep running and wont cut off
Turn the control all the way back to the OF position. If the ice box still won't shut off then the control is bad.
Nov 16, 2010 | Frigidaire Freezers
It wont shut off the motor keeps running on my
replace the timer. or the whole kit. defrost timer, defrost terminator, and heater not really expensive. first found the defrost timer. go to the web found a picture. use a screw driver flat turn the timer the midle part. really slow until you hear a click noise. remember really slow. after 2 or 3 min open the frezzer.and listen a sound like the ice breaking. THE ONLY PROBLEM IS THE DEROST TIMER. 35 doll. easy. just be patient. replace the timer. 2 screws. really important. after replace the timer YOU HAVE TO DISCONECT THE FRIDGE AT LEAST 24 HOURS. ALLOW MELTING THE ICE IN THE WHOLE EVAP. REALLY IMPORTANT
Mar 31, 2010 | Refrigerators
Freezer not freezing, and the panel between the fridge and the freezer gets very hot
The condensor fan motor is probably not running. The condensor fan keeps the compresor cooled, if the compresor gets to hot, it shuts down until it cools off and tuns back on, but will not keep temp. Heat exchange lines go in the panel between the doors to serve as a heater so the doors dont freeze shut, but when the compresor overheats, so do those lines. That would be why that panel gets so hot. Both problems will be resolved with a new condensor fan motor ( located by the compresor).
Oct 16, 2009 | Estate TS25AFXK Side by Side Refrigerator
Freezer fan does not come on . Thought that replacing the DC motor would "fix" the problem. It did not. The compressor works as the freezer gets cold, but the fan never works so the refrigerator side does...
You have a bad main control board . The board in back of the refrigerator , behind an 8"X10" panel . Keep your old motor to play with . A small 9 volt battery will run it . I may have found 1 bad dc freezer fan motor in all the time i've worked on the new style G E refrig.
Aug 29, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
ICE MAKER MOTOR RUNS CONSTANTLY AND WONT' TURN OFF ICE IS FULL
It's not too difficult to remove the ice maker. A few screws and the unit will unplug from the fridge. Then you can see why the bar is not turning it off. If it's really broken, check pcappliance.com for parts or a replacement unit. Meanwhile the fridge can keep on working, and you can use trays to make ice.
May 03, 2009 | Jenn-Air Freezers
Freezer
hi thanks for the question first is the compressor running if it is & not cooling . your freezer has lost its refrigerant if so not worth repairing worstthing people do is not use a freezer for a long period of time its ok for fridges as they are built different thanks the appliance doc
Sep 26, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
DIPLOMAT FREEZER MODEL NUMBER APP6403 MOTOR RUNNING CONTINUOUSLY NEW THERMOSTAT FITTED STILL THE SAME MOTOR KEEPS RUNNING
This kind of a problem could be caused by;
The system has a leak and is not reaching the shut off temperature of the thermostat.
The compressor is worn out and not pumping gas fast enough to reach shut off temperature.
Dirty condenser not allowing the system to get rid of the heat.
Jul 31, 2008 | Refrigerators
Whirlpool ET6JTKXK Top Freezer Refrigerator Logo
176 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
