Question about Brother MFC 420CN All-In-One InkJet Printer
Where do i plug my wire into my printer? - Brother MFC 420CN All-In-One InkJet Printer
  • 449 Answers
Lift up the scanner bed, the connectors are under the scanner.
See manual
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057875.pdf
Posted on Apr 12, 2011
How to connect a Ricoh Aficio 3228c to my computer as a printer
There should be different input and out put plugs on the printer somehwere. Like a fire wire plug or ehternet plug. Once you find the plug and cable, youll need to download the driver for the printer. You could just search your printer name and then driver on google.com.
Apr 19, 2012 | Ricoh Aficio Office Equipment & Supplies
My computer and HP C6180 shut down overnight. Nothing else in the house was affected. My computer turned on normally, but I cannot get the printer to power up. I've unplugged it several times. Both are...
I am using an HP printer but a different model. Disconnect your printer connection to your PC first. You can then check "power brick" light if it on (normally green in color). The power brick is the small box between the wire connecting your printer on one end and the power surge. Check first if there is a light. If its off, you may want to unplug the connection on the printer and check if it will turn green with the wire connected to the wall. If it does turn green, it is a problem with your printer. If it doesnt, it may be a problem with your wire. If your printer wire does not come with this power brick, you can plug the printer directly to the wall bypassing the power surge and see if it will work. If that does not work, try to reseat your wirings and try again. If it still does not work, you need to contact your printer manufacturer for repair/replacement. Don't try opening your printer, it may void your warranty.
Oct 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printer wont power up, 3 lights flashing on main panel when plugged in, including power button. photo,copy & the scan lights. How can i recover from this?
1. Check your wire for a possible short.
2. Reinstall your printers software.
3. Update your printers software.
4. Update your drivers
Check into the 4 of them first
Jul 26, 2010 | Dell 922 All-In-One InkJet Printer
I press power button and does not start up I've
check out let for power -plug in light it works then u need voltage testor and test plug at printer and compair to settings on transformer if it matches bad printer if it does match bad transformer, bad printer do not repair costs more to fix than getting cheap printer transformer no good then check prices first, maybe till cheaper to buy printer , if outlet doesn't work check main fuses and see if one is tripped if yes reset if not bad outlet or wire, replace outlet $1 to buy if bad wire need and electrician or use extension cord to another outlet
Jul 07, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Printer is not working.
Your computer should pop up and tell you that you've installed a new piece of equipment anytime you plug something into the USB port, since most peripherials are plug and play. If not, then it doesn't recognize the printer. You may have a bad USB port. Try plugging the wire into a different USB port during the installation process.
With Brother, you have to use their installation CD and follow their instructions. You can't hook up the wires till *after* the CD has walked you through their installation process.
Try reinstalling using their CD and a new USB port to see if it will work now.
Jan 06, 2009 | Brother HL 1440 Laser Printer
Printer will not turn on
You have already answered you own question. The ribbon wire holds about 30 wires in it. they all have to be seated in perfectly or it won't work for you. Take it to a computer store and see if they can re-seat it for you. Probably 30 bucks for labor to fix.
Jan 05, 2009 | Lexmark X75 All-In-One InkJet Printer
Faxing
The phone wire from your wall jack gets connected to the jack marked "line" on your printer. If you are also are connecting a separate phone to the printer connect a phone wire from the jack marked "ext" to your phone. Just in case you need a manual here is where you can download one. Please rate if this helped. Thanks. Have a nice day. http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Mar 21, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
22 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
