Question about Cuisinart CBK-200 Bread Maker
First time using. We have all ingredients added. Switched on and we cannot see the display panel(blank). There are two lights on, the 'mix in' and 'start' light. Tried reseting but lights still on and no display. We also received no manual/recipe with this item
    Genius:
  • Cuisinart Master
  • 1,280 Answers
Here is what you do: 1) plug the machine in 2) push "select" 3) choose your program 1,2, or 3 etc.etc,................4) push "start"
Posted on Jan 04, 2011
What could be the problem with my machine if it is not mixing the bread ingredients at all?
with the machine unplugged for safety turn the machine it on its side and take the bottom panel off my removing the screws. Look in there and see if your drive belt is broken. If it is let me know.
Jan 09, 2015 | Breadman TR888 Corner Bakery Bread Maker
Cuisinart DLC-10S food processor leaks when liquid is above blades
Yes. It's the basic physics of all liquids.
Perhaps a blender might be a more suitable tool?
Generally you would use the food processor for mixing/blending/chopping all the dry ingredients (and maybe the butter if you are making something like cookies).
Separately mix all the really wet ingredients together in a mixing bowl/large measuring cup.
Then combine the dry ingredients from the food processor with the wet ingredients in a mixing bowl (you can fold the dry into the wet if you used a bowl to mix the wet ingredients together. If you used a measuring cup for the wet, then it's usually better to put the dry ingredients into the mixing bowl first, making a depressed area in the center, and then add the wet into the dry.)
Nov 28, 2013 | Cuisinart DLC-10S Pro Classic Food...
Breadman ultimate bread won't rise
Ensure you are using the right ingredients, fresh yeast, a little salt and maybe a crushed vitC tablet. Don't use standard fine flour you need a courser flour. help it mix by putting ingredients in evenly, liquids first. melt any butter you use in a microwave before adding. most breads use artificially improved flours. if you grind your own flour it will end up a much heavier loaf.....i like it that way.
If nothing i have said helps then it might be time to give up on your breadmaker
Jan 11, 2013 | Breadman Tr2500bc Ultimate Plus 2-pound...
I added the ingredients as per instructions, switched the machine on. After 5 mins, it stopped and went blank.No power to the machine. What do I do?
Give it back to your son. Just kidding! Try plugging it in somewhere else. And make sure the cord is connected good.
Dec 30, 2011 | Breadman TR875 Bread Maker
How do you put the ingredients in order for the bread machine???
First measure your liquids, add the dry ingrediants next then sprikle the yeast on top. I've mixed the liquid and dry SLIGHTLY before adding yeast and it seems to work best.
Dec 29, 2010 | Oster Kitchen Appliances - Others
When I first got my breadman I made several loves of the basic white recipe using Pamela's gluten free bread mix. They all turned out fine. Then I started experimenting with the other recipes provided. ...
Without knowing the specific ingredients in your recipe and having no experience with gluten free flour I am basing this on what I know about bread makers in general. I have owned dozens!
1) If the onion spice you are adding is something like a mix (onion soup mix for example) then you may get better results if you cut back on the salt by about 1/2. Also, next time when your machine starts the rapid knead (after the beginning slow knead) if the dough looks like batter instead of a dough ball add about 1 tablespoon slowly trickled in over about 10 seconds. Watch the dough ball and see if it starts to look a little dryer. The goal is to not have the gooey batter on the bottom of the pan. The slow addtions of flour will do that for you. If this works please leave a testimonial. I like helping fellow bread machine makers and getting feed back! Best of Luck with your next effort!
Oct 31, 2010 | Breadman TR875 Bread Maker
Making regular white or whole wheat works fine but as soon as a recipe calls for flaked onion, garlic, dill etc. the loaf does not rise very much. Should threse ingredients be added later?
due to the general acidic properties of these ingredients, the living organisms in yeast may be partially killed off in these recipes. To increase the rise of these breads using a small amount of warm water to activate your yeast (place the yeast in a small dish and add a tablespoon or more of warm, not hot water), until it's a little foamy, helps. If the directions call for the ingredients to be added at a later time then I would follow those instructions, if not, and you're feeling a little adventurous, try adding those ingredients near the end of the 'resting' cycle of the bread maker, this allows the dough to rise before the yeast is submitted to the more acidic ingredients, and you would be adding them before baking again. If your bread maker does not mix again after the resting period this will not work though.
Yeast are little organisms that when revitalized, excrete gases into the dough, giving it little pockets of air, that when baked expand and allows for more even cooking and those little bubbles in your bread that make it fluffy and more tasty. Higher quality east are typically more resistant to acids, and the older the yeast is the lower the gaseous production is.
Dec 03, 2009 | Black & Decker Kitchen Appliances - Others
Why doesn't the ice cream freeze?
It depends upon which techniques you are using to make an ice cream.
If you are using a maker to make an ice cream then it will take hardly 30 to 45 minutes, not more then that.
For making a delicious ice cream right amount of ingredients should be added and should be mixed in a proper way, if it is not mixed in an appropriate manner then possibly you will not get the real taste that exactly you want.
Aug 14, 2009 | Ice Cream Makers
Need to know how to use the breadman tr440
The Breadman:
In the Breadman, you always add all the liquids ingredients first. If your recipe calls for salt, you add the salt to the liquid because it will ruin the yeast if they get mixed together. Then you all all dry ingredients except the yeast which is added last. You make a small indention on top of the dry ingredients then add the yeast.
Kat
Dec 15, 2008 | Kitchen Ranges
Recipes Are wrong in instruction booklet
I had a similar problem when I switched machines. It seems that most recipes will work in same size machines (1 or 1.5 lb loaf size). My issue was that my old machine had to have liquids in first and then dry ingredients (new machine is the opposite). I ruined several loaves before I figured out the issue. I would have never imagined the order of ingredients would make a big difference.
Oct 16, 2008 | Black & Decker B2250 Bread Machine
Cuisinart CBK-200 Bread Maker Logo
115 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
