Question about Sony KP-65WS500 65" Rear Projection Television
Blue background with "rainbow" like
  • 2,336 Answers
Check the info from this link to see it it applies to the rainbow lines from your TV.
Posted on Jan 04, 2011
Testimonial: "finally was able to get to the blue screen potentiometer. Took about half an hour. TV is working great. No need to replace now. Thanks alot. "
  • 11 more comments
  • Jaime Hernandez Jan 04, 2011
    Slightly adjust the blue screen potentiometer counte clockwise until the rainbow lines go away.
  • mac9497 Jan 04, 2011
    Im not to savvy with where thats located or how to access it. Any help?
    click where it says this link on my first post to open another window, You will see the instructions on how to get access to the adjustments.
    Let me know if you need further assistance.
    The link from Jaime867 keeps taking me to an advertisement.
    Look where it says to skip this advertisement.
    try again: http://www.somelifeblog.com/2007/06/sony...
    Im sorry but the link only comes up for a second and then is routed to some advertisement site.
    Highlight and copy this http://www.somelifeblog.com/2007/06/sony... to your browser and if you see the advertisement on the upper side it should say to skip this advertisement.
    I can send you the guide via email if you're unable to open the link.
    thanks for the help, but the advertisement comes up before I can even find the skip button.
    My appologies for the inconvenience that this link has caused but is the first time the ad has come out and I have place that link several times.
    I can email you the guide if that helps.
    please. mac9497@hotmail.com
    The guide has been sent to your email inbox.
    Thank you for the feedback mac9497.
    I'm glad we could help you fixing your TV.
I have a hisesense 40" lcd lked tv.i grabbed it fron the top and my finger touched the screen.now its has about 12"black uneven spot and in the spot i have rainbow lcolor lines..plus one blue vertica
It sounds like you cracked the screen. If it is cracked, you cannot fix it. Your only options are to replace the screen (BIG $$$) or buy a new set. If you can email me a pic of the TV I can tell you for sure if the screen is cracked. LCD screen are very thin, about as thick as a dime and it doesn't take much to crack them.
info@back2lifeelectronics.com
Nov 25, 2012 | Televison & Video
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
Sony KP-46WT500 Red, green and blue lines appearing on screen
your convergence IC;s are out, they cost about $40, if you know how to solder, you can do it your self, if not , I would try to find somone that can, service centers charge about 4 or 5 hundred, after you get the new ones, there easy to find on the board in the back of the tv
Nov 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Blue rainbows lines
I can help you out because I have circuit details of KP-65WV600but let me know what does it mean of blue rainbow lines?
I would appreciate if you post picture of those blue lines to understand problem of TV.
Thank you.
Nov 24, 2008 | Sony KP-51WS500 51" Rear Projection...
1/2" yellow line appearing in the middle of a background colored page
sounds like you need a replacement drum as it sounds like it is faulty, this is a replacable part and needs to ber replaced from time to time, this is a common symptom of this fault
Oct 03, 2008 | HP LaserJet 4600dn Color Printer
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Line across top of screen
If the picture is ok otherwise then only thing that probably needs to be done is a vertical height adjustment. That is if the lines never changes position from cold to hot.
Feb 27, 2007 | Sony FD Trinitron WEGA KV-32FS16 32" TV
Sony KP-65WS500 65" Rear Projection Television Logo
427 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
