Question about Amana ABD2533DES Stainless Steel Bottom Freezer Refrigerator
Compressor stopped working..had a booster put on 5 months ago
  • 122 Answers
You most likely need a new compressor.
Posted on Jan 04, 2011
What to do with a brake booster out and the ABS light came on? 1998 Isuzu Trooper
Hi Rebecca,
Since the AntiLock Braking System utilizes the power (vacuum) boost to operate normally, the ABS indicator should come on if the booster fails. Yes, this means your ABS system is not able to function correctly, but neither are your standard brakes (as the extra pedal effort required to stop will tell you). however, your brakes DO WORK, so driving it to get the codes scanned shouldn't be too dangerous - just be ready to stand on the brake pedal with both feet and leave yourself plenty of room to stop by driving slowly and looking well ahead for stopped traffic. Once your booster is fixed, the ABS light should go off without any special reset or clearing of ECM memory. Good luck and happy motoring!
Jun 14, 2014 | 2000 Isuzu Trooper
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
L have a ford explorer 2002 4.6ltr A/C blows hot air when turned on it has been gased 4 months ago compressor is ok.Compressor don't turn on when A/C is on how do you check the solonoid near radiator and...
what i think the solenoid you says are not solenoid, it is just high and low pressure switch. just by pass the switch to see the switch working or not.
Nov 23, 2010 | 2002 Ford Explorer
Problem with Brakes
Listen under the dash where the rod goes into the back of the booster if noise is from there, it's leaking.
Jun 07, 2009 | 2006 Saturn L300
AC not stops working when compressor starts.
how many amp service do you have in the house
May 17, 2009 | Heating & Cooling
Compressor bad
its not DIY stuff to replace compressor. here is my video how i do it. replacing little compressor. pretty similar to any residential refrigerators.
Feb 02, 2009 | Frigidaire FRS26R4A Side by Side...
Water dispenser in my Maytag french door refer has suddenly stopped working. We use it every day and the filter seems to be fine. It almost sounds like it is frozen. Please Help!!!
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Brake issue with ABS
they put one of the self adjuster in backwards.
Jul 14, 2008 | 1993 Ford Thunderbird
Open Questions:
Amana ABD2533DES Stainless Steel Bottom Freezer Refrigerator Logo
151 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
