Question about Panasonic PV-M2079 20 in. Combo
Why can't I use my dvd player without having a cable hookup? The blue screen keeps saying "connect antenna cable and if you use a cable box, tune it to your local PBS CH then..." I am stumped....
2 Suggested Answers
acutrek1997
  • 15 Answers
SOURCE: How do you fix this problem, a blue screen comes
it sound like your blue background is on! I not familiar in your t.v. model but try to turn off the blue background in channel settings I think!
Posted on Feb 18, 2010
Screen on Philips Flatscreen HD has turned green there is sound on all Freeview stations only, no picture but DVD player works perfectly well and in full colour Why is this and what needs fixing. Freeview...
If the hookup is HD from a box you have Green(video) Blue and red--check first they are connected properly at both ends. Component would also use two more cables for audio.
If HDMI maybe a bad cable or issue there. HDMI has issues with and creating no sound problems.
If a DVD player does work fine it means a hookup issue of some kind or a very odd problem in the set(unlikely).
SD TECH
If using HDMI at least attempt a component hookup.
Apr 22, 2012 | Televison & Video
Can I record DVDs from a Sharp 13VT-N100? The only connection source is the coaxial antennae port. There are "In" sources so I can watch DVDs from a DVD player but how can I reverse that so I...
Recorded from tv shows to DVD Disc have to hookup AV RCA component cables to both to Tv and DVD recordable player model connections together.Yes,u will able to recordable VHS tapes to DVD Discs.But ur DVD player model u have it is must be a recorderable DVD player model?Not just a DVD Discs and VHS tapes player only model.Check ur owner manual all are in there.
Aug 20, 2011 | Sharp 13VT-N100 Combo
I have rca STB7766G1 converter box can I connect my dvd player
Trial and error. There is no list of products that will work together and how, so when you have situations that come up such as these you have to connect the electronic devices and see what happens. What's worse is that the combination will not always work with the same brands and even if you do get this to work today it might not work tomorrow.
Ok connect the DVD player to the television. Where it says out on the DVD player you connect the connecting cables either yellow, white, and red or green, blue, red, white, red. You connect the other end of them to the television. Put the television on the correct input. Try playing a movie to make sure the dvd player and television are connected properly.
Ok now where it says IN on the DVD player. Connect a yellow, red, and white cable. The other end of that cable connects to the converter box where it says out.
You can also connect the converter box and the dvd player in this way if applicable. If the dvd player has an RF (coax) IN connect a coaxial cable there and connect it to where it says OUT on the converter box.
Then you connect an antenna to where it says ANTENNA IN on the converter box. Now you will have to be able to put your dvd player in input (aux) or turn it to channel 3. You will always leave your dvd player in input (aux) or on channel 3. You will only change channels on the converter box with its remote control or the buttons directly on it. Good luck!
Apr 23, 2011 | Televison & Video
Model ds31520. I've had it for years working like this: no antenna, no cable, just DVD (connected to non-S input ports) watching movies. Somehow I hit a button sequence on the remote and now only this: ...
Sorters -
Re-connect to me on the chat and we'll get this sorted. I'm really sorry - I got disconnected and the system would not allow me to reconnect to you. I have some ideas but chat would be easiest. If you don't want to chat, post a message here and I'll message back with some things to try.
BElectric.
Jan 22, 2011 | Sanyo DS31520 31" TV
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
No visable way to connect to cable antenna
Yes this model is used mainly for viewing and recording from the TV source
Please rate my responce and help keep this site Free
Jan 03, 2009 | Philips DVP3345V/17 DVD Player/VCR
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Panasonic PV-M2079 20 in. Combo Logo
27 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
