Question about HP Photosmart 945 Digital Camera
Screen and pictures pink or green or strips of many colors, sometimes right sometimes just smeared
    Guru:
  • 91 Answers
Solution to pink or rainbow image; screen and pictures pink or green or strips of - icon_exclaim.gif Warning: By opening your camera there is a risk from electrical shock - be sure that your camera has had the batteries removed for at least 24 hours for the capacitor that charges the flash to discharge. While generally not capable of injury or death, it will definitely get your attention if you touch the wrong part of the camera if it has been recently operated. I'm not responsible if you electrocute yourself. YOU DO THIS ENTIRELY AT YOUR OWN RISK.
icon_arrow.gif Caution: The procedure that is mentioned here WILL violate your warrantee. The HP850 & HP945 cameras are not designed for the average user to disassemble and repair. These cameras are quite fragile on the inside. If you elect to do this procedure, you do this completely AT YOUR OWN RISK. If you take proper precautions and have good eyes and a steady hand, you can reasonably expect to complete this repair with success - however, NO guarantees are made and/or implied.
Note: This procedure was not developed by me. I am not an electronics guru by any stretch of the imagination even though I am quite capable of doing this procedure having assembled several electronic kits (if anyone remembers those Heath Kit short-wave radios among other projects). A friend, who shall remain anonymous, and is very good with electronics, owns a 945 and compared it to the 850 which is very similar on the inside and was successful in fixing it.
This "rainbow" condition can affect both the 850 & 945 cameras. I personally suspect it will occur more frequently as these series of cameras get older in age and the cameras fatigue with age. The cause of the "rainbow" coloring is actually caused by a micro-fracture in a solder connection on a connector strip insscreen and pictures pink or green or strips of - normal_hpim9019.jpg />
Tools required:
1 set of micro-screwdrivers (Philips and Flat-Blade)
1 soldering pencil, with the finest point you can find with stand and cleaning sponge (unless you happen to have a microscopic soldering station then use it instead)
1 tube/can solder flux
1 small tube/jar of rubber cement
1 set of watch-maker's magnifying glasses or a stand mounted magnifying lens
2 small trays for small parts, especially the small screws
Step 1
Remove all removable items
1. Batteries - do this 24 hrs in advance to prevent electric shock
2. Memory Card
3. Rubber Eye Piece - this falls off many cameras, it is held on by rubber cement, just peel it off.
4. Open battery door and data/power door (leave open).
5. Unscrew all Philips screws around the back of the case.
Step 2
Gently pry off the back cover using flat blade screw drivers - kind of like opening a can.
Step 3
Once the back cover is off, remove the board assembly that holds the LCD (it has several screws holding it to the main board). The problem connector is directly under the LCD board. There are two types connectors used. The connectors are relatively robust but do use care when opening and closing-lifting the little bar (brown) in the photo [one type] and sliding the brown bar up along the cable [on the other type]. Release the connector on the LCD board cable. Release the connector on the lescreen and pictures pink or green or strips of - connector.jpgh the cable aside and you are ready for the re-soldering.
Step 4
Once you have located the connector assembly (indicated in yellow), The easiest method to resolder and probably the only way to fix this is to flux all the connections on a side then reflow each joint by heating each lead in turn across the connector while gently pressing on each of the contacts to close any microfracture (the cause of the problem). Let it cool completely, repeat on the other side. Take your time, as you will be applying a lot of heat to this small area of the board -- allow plenty of time to cool between each lead.
Step 5
Once the board has cooled to the touch reassemble by reversing (Steps 3 through Step 1) the process of disassembly, carefully making sure that the two connectors are seated correctly, and all screws are correctly placed. One of the final steps is to glue the rubber eyepiece back on with a very small amount of cement - take care not to add too much or get any on the eye piece lens. Insert batteries and card, and hopefully you will have a working camera.
Posted on Jan 04, 2011
This is Jon Baker from Sacramento, CA have a TV LG 50PZ55-UA have a lot of PICs that show model of the TV /boards - can you help on which board maybe the problem?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 21, 2016 | LG Televison & Video
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
I HAVE THIS TV AND I TURNED THE TV ON ONE DAY AND THE SCREEN WAS PINK. I COULD STILL HEAR SOUND BUT IT WAS A PINK SCREEN. ANY IDEAS WHAT WENT WRONG?
The tv have three colors guns Green,Red,Blue.Pink pictures mean there no blue color.Take another tv tries that incomming broadcasting signal cable,see if u getting all three right colors for that tv?Yes,than that tv have a pink pictures have a dead Tuner signal board,no than u have a bad incomming broadcasting signal cable or pay cable box.If it the tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 13, 2010 | Westinghouse LTV32W6HD 32 in. LCD...
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
TV KOLIN 21"
hello.... do you have any speakers near your television? what color is the circle your talking about? Do the green,pink colors are scattered all over the screen and specially on the corners?
If you have or had speakers near your tv? then do this try to get a magnet.a magnet on a speaker would do.what you have to do is to place the magnet near the screen of the tv approx. above the green,pink color (turn it on first).you will notice the that the color will react with the magnet try to pull it on the side you will notice that the green,pink color is moving on the same direction do it until its gone.NOTE make sure youll not scratch the screen ok.email me what happened. jaredreyesbalderama@yahoo.com GOODLUCK
Jan 21, 2009 | RCA 20F512T 20" TV
Screen has green corner at first and may changeto pinks and green
It sounds like the De-gauss circuit isnt working. It demagnetizes the TV tube.
It's something only a tech can fix though.
Jan 02, 2009 | Zenith C27V36 27" TV
Color seems to be pealing up from the bottom of screen
If the screen is bouncing...expanding/shrinking you need to get a repair kit from www.TvRepairKits.com
If your screen looks 3d in color, has a stationary bow, or if you can't adjust one or more colors from the "convergence" menu you need to buy a convergence repair kit. You can get one from the same site listed above.
Hope this Helps,
Nov 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
HP Photosmart 945 Digital Camera Logo
42 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
