Question about JVC AV-32D305 32" TV
AV-32D305 video 2 input no longer works when hooking up a blue ray dvd player
    Novelist:
  • 129 Answers
It is very possible that the solder connections on the printed circuit board are damaged from repeatedly plugging in and removing different devices. You may find that by wiggling or slightly flexing the plugs that they work intermittently.
Posted on Jan 04, 2011
How do I hook up my Toshiba DVD player to my old Daewoo Tv /vcr combo
what inputs does the old Daewood / VCR combo use is it RCA and Video cable on an AV input? How many Av inputs are there in TV ? Does the DVD player have AV out audio out (Yellow) RCA (Red and White). If you do not have enough AV inputs on the Tv use an AV switch box . and Switch two AV RCA inputs /DVD and VCR and into one output to the TV. You may be able to feed the AV out RCA out into the VCR AV in and switch the input on the VCR.
May 25, 2015 | Toshiba Televison & Video
BDP5012 Philips bluray dvd player
Hello
You are done the connections right. But look to the socket colours of both the devices, TV & DVD, so match. Yellow, is meant for video, and one among white is for audio. You have to select the input of the tV to [AV], to get the DVD connected to TV. When the input selection comes right, you will see the Logo of the DVD company on the screen of your tV. Some TVs will have AV-1, and AV-2. Try both SV selections. NB: You must power ON the DVD to get its Logo on TV screen. The wire you connected will look like this I assumes.
Feb 27, 2012 | Philips BDP5012 Blu-Ray Player
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
Im trying to set up my tv, it was given to me as a gift, my uncle was using it it works i can change the channels but when i try to work my dvd player with it, only the audio comes on the screen stays...
Please few things...
1- Make sure audio and video wires are hooked correctly in AV input of tv and you selected that AV input in tv with its remote.
2- Also check your dvd has not been set on progressive mode if you hook dvd player through yellow-red-white wires with tv.
3- if dvd player is set on progressive mode, then hook it with tv by component video input, red-green-blue for video and red-white for audio.
Hope this info will solve your problem.
Thanks.
Mar 17, 2010 | Toshiba TP55H60 55" Rear Projection...
Sound but no picture
Your player has several outputs and you might want to start with the basic Video Audo Left Right output first.
Set your with your plazma to see if you can change the input types to accept the video and audio input which will probably be labeled AV 1, AV 2 and so on.
My guess is that you have it set for Component Red Blue Green which his a high def (just before HTMI) and requires a separate audio cable. Your player, depending on the age of the unit, probably will not have Red Blue Green picture output.
Next if you have an HTMI output from your player hook that to your Plazma in the HDMI 1 position and select it on the TV's setting. Audio and Video are both carried in the HDMI cable.
Good luck, my name is Eric Kirkhuff
Feb 23, 2009 | Toshiba D-VR4 DVD Recorder/VCR
DVD is playing in black and white
check the norm pal or ntsc,or video format
Feb 17, 2009 | Pioneer DV-333 DVD Player
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
Hook ups
use a video splitter for the audio and video, or go out of the DVD player in to the DVR, out of the DVR into the TV (WARNING!!!! Trying to hook a DVD player to any recording device may trigger the copyright protection, causing blue flashes, and distorted pictures)
Aug 22, 2008 | Memorex MVD2042 DVD Player
Hooking up external DVD player
if you tryed to hook up into another video input you also have to switch the inputs on the remote in the input menu from input 1 or 2 to the same.
May 27, 2006 | Toshiba MW20FM1 20 in. Combo
JVC AV-32D305 32" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
