Have a printer and now I am getting a 49.420c service error message. Any help would be appreciated.
  • 134 Answers
That is formatter issue. Reset your printer and clear your print que. If not, then reinstall your printer driver.
Posted on Jul 09, 2008
Hi I bought a Lexmark X204N and now it is showing the following error message: error message: 931.01 service no first Hsyncs I am unable to print from this printer at the moment and it is causing a lot...
This error indicates that it cannot communicate with the laser printhead. Please click on the link below and follow the recommended steps. http://bitly.com/o51ckY
If you need further assistance, please contact Lexmark Technical Support Center.
Apr 05, 2011 | Lexmark X342n All-In-One Laser Printer
Canon IPF700 error message E161-403E, how do I fixt this?
Welcome to FixYa
Error message E161-403E is a print head over heat indication.
Turn off and turn on the printer see what will happen. If error still exist then you have to replace the print head.
Before you have to update the firmware to the latest version.
Try to access the service mode in order to update the firmware
Error will be removed.
If you have already tried above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
So go to the Canon Service Center. If you want to get support on Call then Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
Your Rating As Four Thumbs which are given below to this solution will appreciate me
Thanks
Mar 11, 2011 | Canon imagePROGRAF IPF710 Printer
What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
Try this:
The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
Also:
Based on the problem description provided, we have determined that your printer needs service.
Please turn your printer off and use one of the methods below to make arrangements for service:
If using the local service provider website, please perform the following steps:
  1. Enter your zip code in the space provided.
  2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
  3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
The printer is "stopped" and when I click on
I believe the print service spooler service had stop. here the software to fix it automatically. http://www.out-of-warranty.com/print-diagnostic-utility-for-hp-lexmark-canon-dell-xerox-and-everything-else/. Download the print diagnostic utility, unzip it and install it to your computer.
I will helps you a lot. regards
Feb 09, 2011 | Epson Stylus Photo R1800 InkJet Printer
Error message 5200 on Canon printer i965
Sent the printer for repair to the local Canon Service Centre.
Apr 14, 2009 | Canon Office Equipment & Supplies
Okie C5400 giving 162: Fatal Error
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
931.01 Printhead Service Error
there is a Printhead error - No first sync
Dec 21, 2008 | Lexmark X342n All-In-One Laser Printer
Error message on lexmark printer
900 Service RIP errors are usually a firmware failure. Upgrade to the latest firmware from Lexmark. This link is for the C52X network model:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Aug 07, 2008 | Lexmark C522n Laser Printer
Not responding
The E000019-0000 error message simply means the waste toner is full. There is an optical beam that passes through the top of the waste toner container and when the beam gets interrupted, you will get this message. If you have the same model printer/copier (Canon IR 3300) series, unplug the machine for your safety and you will need a screw driver to remove the lower left side panel towards the back to pull out the waste toner receptacle. Dump, Clean, and replace. That should clear up the error message. Hope this helps. ~Angela~
Feb 14, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
143 people viewed this question
jasbo
jasbo
