Question about Sony Playstation 3 (PS3) Console
An error has occured, the error code is 800F828
  • 839 Answers
Don't worry i will tell you a easy and efficient idea to fix this..... First download repair guide and go through it, it has many solutions......
Click here to download PS3 repair guide
Posted on Jan 04, 2011
What is Error Code:59.A0 for Hp laserjet 400 M401d?
A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation errorA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error HP LaserJet Error Codes 50 59 Looks like a motor error check the fuser unit and drum are seated properly.
Mar 09, 2015 | HP Office Equipment & Supplies
Tip
LG UNIVERSAL SPLIT AIR CONDITIONING FAULT COEDS Error Indicator: # The...
Error Indicator:
# The function provides self-diagnosis and displays an error code if there is any trouble.
# Error codes are displayed on the Indoor unit's Wired Remote as CH**, and/or Fascia Display. In
addition, the code is indicated via LED's on the outdoor unit control board.
# If more than two troubles occur simultaneously, the lower number of error code is displayed first.
# After an error occurs, if error is released, error LED is also released simultaneously
for more check the link bellow
http://electro-medical.blogspot.in/
on May 10, 2015 | LG Heating & Cooling
Tip
Kenmore Elite, Whirlpool Duet, Maytag Epic series Error Codes
The following are common error codes, with general definitions, associated with Whirlpool Duet series, Duet Sport series, Steam series, Kenmore Elite series and Maytag Epic series FRONT LOADING washing machines. The error codes pertaining to the washer you have, will be determined by the specific model number. All error codes are listed in the technical data sheet associated with the appliance.
F/H/F20 - NO WATER DETECT ERROR. No water detected entering the machine, or the pressure switch has not tripped after 6 minutes.
F01/F14 - EEPROM ERROR. Communication problem between the Central Control Unit (CCU) and Motor Control Unit (MCU), or inability to read the EEPROM data on the CCU.
F02/F21 - LONG DRAIN. Commonly associated with a drain pump failure or clog in the drainage system. Occurs when the drain time exceeds 8 minutes.
F03 - HEATER SHORT CIRCUIT TO GROUND. Occurs if there is a short circuit to ground detect on the heater.
F05/F24 - WATER TEMPERATURE SENSOR ERROR. Associated with NTC sensor out of range or heating circuit failure.
F06/F25 - DRIVE MOTOR TACHOMETER ERROR/STEAMER DEFECT. Occurs when the motor speed cannot be detected by either the MCU or the CCU. Or, for steam models, the steamer temperature has not reached the correct value.
F07/F15 - MOTOR CONTROL UNIT ERROR. An internal failure with the Motor Control Unit has been detected by the Central Control Unit.
F09/F27 - OVERFLOW CONDITION. Occurs when the Overflow Contact on the Pressure Switch is closed for more than 60 seconds. When an overflow condition is generated, the door remains locked and the drain pump will run constantly. Pressing PAUSE/CANCEL will clear the display, but often will not shut off the pump. UNPLUG washer to service.
F10/F31 - MOTOR CONTROL UNIT HEAT SINK TRIP. Occurs when the thermal protector on the MCU gets too hot.
F11/F28 - SERIAL COMMUNICATIONS ERROR/MOTOR CONTROL UNIT ERROR. Caused by either a communications problem between the Central Control Unit and Motor Control Unit, or Motor Control Unit internal failure.
F13/F30 - DISPENSER CIRCUIT ERROR. Occurs when the dispenser motor is not in the proper position.
Fdl/F22 - DOOR LOCK ERROR. Occurs when the door fails to latch after 6 attempts.
F23 - HEATER FAILURE. Occurs when the water temperature increase is less than 86 degrees F during the first 40 minutes.
F26 - DOOR SWITCH ERROR. Occurs when the door has not be opened for three consecutive cycles. Or, if the door switch remains open for more than 5 seconds while the door is locked.
Fdu/F29 - DOOR UNLOCK ERROR. Occurs when the door fails to unlock after 6 attempts.
F32 - PRESSURE SWITCH FAILURE. Occurs when no electrical supply from the CCU to the pressure switch is detected. Or, if the pressure switch contacts are worn out.
F33 - PUMP DRIVE SYSTEM ERROR. Occurs when the connection between the pump and the Central Control Unit (CCU) is lost.
F34 - UNLOAD. This failure is only for information purposes and is displayed in the error log history during diagnostics. Occurs when a load was detected in the drum during a clean cycle and the cycle had to be interrupted.
F35 - ANALOG PRESSURE SWITCH FAILURE. Occurs when there is a malfunction of the steamer component detected by the steamer electronic control board.
F42 - MOTOR CONTROL UNIT ERROR, REPETITIVE UNDERVOLTAGE. Occurs when 4 under voltage conditions are detected by the MCU during the wash cycle.
F61 - STEAMER COMMUNICATION FAILURE. Occurs when incorrect communication is detected between the CCU and steamer electronic board. Error should reset after running diagnostics.
F62 - STEAMER ELECTRONIC BOARD RELAY ERROR. Occurs when one of the steamer board relays (K1, K2, K3, K4) fails. Error should reset after running diagnostics.
F63 - TOTAL STEAMER FAILURE. Occurs when the steamer will no longer function and needs to be replaced.
F64 - STEAMER INLET VALVE FAILURE. Occurs when the steamer valve or flush valve becomes blocked. Error should reset after running diagnostics.
F65 - STEAMER TIMEOUT. Occurs when there is no communication between the CCU and Steamer Electronic Board. Error should reset after running diagnostics.
F70 - CENTRAL CONTROL UNIT (CCU) HEARTBEAT FAILURE. Occurs when no communication data is detected from the CCU to the front panel user interface.
F71 - USER INTERFACE HEARTBEAT FAILURE. Occurs in conjunction with F70 error due to no communications detected from the User Interface to the CCU.
F99 - NOT SUPPORTED. Mismatch of the User Interface and Central Control Unit (CCU). Or, corrupted EEPROM.
rL - WASH LOAD DETECTED INSIDE WASH TUB DURING CLEAN CYCLE. Detects any garments (by weight) that may be left inside the wash tub during a clean cycle. NOTE: Wash tub is to remain empty during a Clean Cycle.
Sd/SUD - SUDS LOCK ERROR. Occurs when too much detergent is used. Or, occurs in conjunction with F02/F21 error (Long Drain) due to obstructions in drain cycle.
The first step in troubleshooting any error code is to press PAUSE/CANCEL twice to clear, and verify your installation. Make sure the water inlet valves are turned on and connected correctly. If the error code remains, UNPLUG the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit. In many cases a simple CCU reset will correct any momentary glitches or erroneous errors. If the error returns following a CCU reset, a legitimate error condition exists and must be corrected in order to return the appliance to normal operation. For more specific information and troubleshooting advice on how to remedy most problems, refer to the technical data sheet.
NOTE: EACH ONE OF THESE APPLIANCES COME WITH A TECHNICAL DATA SHEET INSIDE. THIS IS THE SAME SHEET AN APPLIANCE REPAIRMAN WILL REFERENCE ON A SERVICE CALL. REFER TO THE TECH SHEET FOR MORE DETAILED TROUBLESHOOTING INFORMATION.
The tech sheet contains troubleshooting data, wiring diagrams, diagnostics procedures, component illustrations and all error code definitions.
To access, you will need to remove the lower toe panel directly below the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access to the screws (a 2x4 works well for this). With the screws removed, the panel should drop down, and come off. If the tech sheet isn't directly behind the toe panel, it will be affixed to one of the interior cabinet walls.
It is recommended that the tech sheet be placed back inside the appliance when repairs are completed in order avoid losing and to keep this pertinent info for future use.
on Apr 20, 2011 | Washing Machines
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
What is error statemant?
The try...catch Statement The try...catch statement allows you to test a block of code for errors. The try block contains the code to be run, and the catch block contains the code to be executed if an error occurs
Syntax:
try
//Run some code here
catch(err)
//Handle errors here
}try
catch(err)
Apr 03, 2010 | ArcMedia JavaScript Source Code 3000 Pro...
Flip Ultra is not recognized by FlipShare!
make sure all your computers drivers are up-to-date. If they are then make sure you have the latest service pack for your particular OS.
Dec 28, 2009 | Pure Digital Flip Mino Digital Camera
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
Hi, my ps3 wont read bluray discs. I was getting an 800 series error code on the disc startup but now it won't even see the discs. It does see ps1 and ps2 discs, as well as cd's and dvd's. I ordered an...
Hello sir
Here The 800 Series Error Codes :
80029945 - Can’t playback burn BDr movie (error in picture above)
80029946 - Attempting to play burnt Dual layer NTSC disc on a Pal ps3
(workarouns is to transfer files to ps3 via TVersity)
(added 24th Sept 2007)
80029301 - An error occurred during the delete operation (attempting to delete
some ps2 homebrew from virtual mem card) (added 15sept2007)
80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3
processes - have to sign in to use them) (added 04-sept-2007)
80710A06 - An error occurred during the install operation (error when downloading
game from PSN - network error occured (added 30thAug2007)
8003041F - An error occurred during the copy operation (using media server) (added
27aug2007)
80010006 - An error occurred during the start operation (added 22aug07 - corrupted
folding install)
80010007 - An error occurred during the start operation (added 17aug07 - during
disc swap tests)
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
183 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
