Question about HP Pavilion a1120n (PX759AA) PC Desktop
My HP Pavilion a1120n is running very slow I re formated it a few time over the years. Recently I added more ram and ran great till i clean it with air may , then ran very slow, so I remove some ram then re formated it It got slower so I put back in the rest off the ram and still very slow I was told to replace my hard drive and that might be the problem I had this computer for over 5 years now with all the stuff i added and deleted over the year would that make a diference
    Champion:
  • 331 Answers
Did you replace the hard drive? It is quite possible there is an issue with the drive at that age. YOu could try an application called "SpeedFan" or "HD Tune" and run a S.M.A.R.T test on it. This will help you determine the drive status. You can run a benchmark with "Hd Tune" and determine the speed of the drive. If you want to post your results, I will certainly help out further.
Posted on Jan 04, 2011
  • 560 Answers
First check your total hard drive free space. The little memory space can cause for slow system. You can perform 'Disk Cleanup' utility to delete temp files & allocate free hard disk space. For perform 'Disk Cleanup' utility, go to 'Start -> All Programs -> Accessories -> System Tools ->Disk Cleanup'.
Perform disk defragmentation in your HP system to manage saved file memory location in a single place so that it can access faster.
You can perform 'Error Checking' utility to check for any issue in your Dell Inspiron hard disk. These hard disk errors are generally not noticeable but it can cause for slow hard disk or slow computer.
It is recommended to perform virus removal program to scan your system at daily basis to check for any virus and malware in your HP system.
You can also increase your RAM if you are not satisfied by the general performance of your Dell Inspiron.
Get HP technical assistance at http://www.vtechsquad.com/hp-support/ to fix all kind of HP system problems..
Posted on Sep 06, 2012
What would be some more powerful motherboard upgrade on a a6700f HP with 630watts and dual monitor graphics card from ATI?
Try to scan it for malware or viruses. Run combofix:
http://www.bleepingcomputer.com/download/combofix/
For virus scan, boot to avg rescue cd/usb flash:
http://www.avg.com/ww-en/avg-rescue-cd
Then fix it using Windows Repair All in One:
http://www.tweaking.com/content/page/windows_repair_all_in_one.html
Also, try updating your drivers particularly the video.
Uninstall or disable any unnecessary program that loads at startup.
Use ccleaner, to clean up disk space and registry.
Apr 25, 2014 | HP Pavilion a6700f PC Desktop
My HP Pavilion a820n pc desktop fan runs constantly. I don't think it always ran this much. Previously ran then shut off then ran. We vacuumed the visible dust. Does this signal a problem? Thank you. ...
Fan is inteligent, has sensor when cooldown is reached auto slow down to fix needs to be replaced,will not hurt anything system running cooler is always a good thing i would run it till it dies unless noise is an issue
Jan 20, 2011 | HP Pavilion A820n (PP165AA) PC Desktop
Hp Pavilion a1120n will not power up.
Yes it needs a power supply. You can get a cheep one on eaby or get one off of the HP site
Hope this works,
Luke Wilcox
Dec 28, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Initially, my fan would run fast and then slow. Then, it began to shut off frequently by itself; the monitor would state "monitor sleeping." Now, the CPU will not power on at all. Even after having a...
Fixing the problem would have been to change the fan when it started to fail. The bearings were probably going out and causing it to labor and slow down. When the fan quit altogether that was the big flashing warning sign "Do not run till you fix me" type of warning. CPU's develope tremendous amounts of heat. Without a fan there to cool it, it could have damaged something.
1. Get a new fan
2. Unplug all add on cards
3. Unplug hard drives, floppys and cdrom
The only thing that should be plugged into motherboard is the video and ram and keyboard. Unplug power supply for 1 minute. Make sure the power supply master switch on the back is on. Try to start the computer. If it starts then start connecting your drives back one at a time and any addon cards. If it doesn't start you may be looking at replacing motherboard or CPU. I've never seen an Intel CPU fail even from heat but there is a first for everything.
Dec 07, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
My compaq is and has been running extremely slow and sometimes freezes. I had multiple music programs on it, I removed them all to see if it helped but its still happening, what do you think is the...
check your system RAM speed , if it is low, change it, or the other options can be virus on the system, or software confilct which is recently added..check out all these problems, defragment your hard disk, if it is lower in space...
Oct 24, 2009 | HP Pavilion a320n PC Desktop
Slow laptop dv 9208 w vista
If you're having Vista, you will need 1gb RAM minimum. Vista is resource intensive, concentrated more on graphics, and a lot of Hardware compatibility issues. Windows XP is fine and better as of now which runs great with 1GB of ram and a pretty processor of 2.0 ghz ...If you think of speeding up ur lappy better go for XP .increasing ur RAM will increase the number of apps that you can run productively at a time.
Mar 28, 2009 | HP Pavilion dv9000z Notebook
My computer is very slow - not responding
Sounds like you have some spyware on your system.. Recomend that you download adawre (free from lavasoft), spybot (free software) and c-cleaner (also free)
Run c-cleaner first , then adaware (keep running till it is clean, sometimes it takes up to 4 times to get them all) -then run spybot, run it till it is clean (again sometimes it takes several runs to clean it all)
Then run c-cleaner again.
Try this first. If does not help, write back and we can go from there.
Jul 17, 2008 | Packard Bell Computers & Internet
Need help
You are confusing Hibernation, where the RAM is written to the HDD and power is turned off without unloading the OS, with Screen saver (control panel - display).
Mar 18, 2008 | HP Pavilion a1120n (PX759AA) PC Desktop
HP Pavilion a1120n (PX759AA) PC Desktop Logo
177 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
