Question about Xerox Office Equipment & Supplies
XEROX WORKCENTRE XL 2120 ERROR CODE L4 - Xerox Office Equipment & Supplies
    President:
  • 2,072 Answers
L4 can be 3 things. If your lucky, look and see if the lamp is moving properly. Something may just be catching it.
If not, then either the laser or the main board have failed.
Remove the glass first and see if you can slide the lamp carriage without binding or hitching.
Posted on Jul 09, 2008
Xerox workcentre 6015 ni error code 092-651
Printer CM205 b error code 092-651
Options My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
Thank you for the help.
Apr 12, 2014 | Xerox WORKCENTRE 6015/Ni Color
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Dec 02, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Nov 08, 2009 | Xerox WorkCentre M128 Copier
J2 error on xerox xd 100 copier
hello there:
here is a link that will be able to help you out
  1. XD100 Style: Trouble Shooting Xerox brand models: XD100/102/103/104/105, XD120/122/125/130/155, XL-2120/2130 ... Next month, we'll hit the J1 & J2 codes as well as the L codes...www.enxmag.com/OLD SITE/bhorvat2304.html - Cached
Sep 14, 2009 | Office Equipment & Supplies
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
L4 code on workcentre xd 155 df
TABLE 1
Summary: 'L4' Product: * Copiers & Multi-Function Copiers
  • XD Series
  • Description: XD100 Family
    - Main motor problem.
    - The main PWB sensed a main drive motor problem. Solution: document.write(ParseIncidentLinks("01 - Switch off the power and wait for 5 seconds.\n 02 - Switch on the power. If the status code persists, Please .", 'Hold down Shift while clicking to open this link in a new window', '(Click here)', 0)); 01 - Switch off the power and wait for 5 seconds.
    If the status code persists, Please see Table 2, below.
    TABLE 2
    Summary: Service Call Product: - Communication Technologies
  • Telecommunications
  • Description: A service call is required when the solution requires a Xerox engineer to rectify.
    Service will be provided in the form of an onsite engineer, repair or replacement of the machine depending on the warranty held for your specific product. Solution: document.write(ParseIncidentLinks("Please contact your local Xerox Help Line arrange a service or further assistance over the phone. You can also e-mail us a question.\r\n\r\nTo find your Xerox Support line locate the contact button at the bottom right of the Screen.", 'Hold down Shift while clicking to open this link in a new window', '(Click here)', 0)); Please contact your local Xerox Help Line arrange a service or further assistance over the phone. You can also e-mail us a question.
    Jan 08, 2009 | Xerox WorkCentre M20i All-In-One Laser...
    Xerox XD 130 L4 code
    That is an issue with the main drive motor.
    There is a small plastic gear on the shaft of that motor that cracks and even though the motor spins, it does not drive anything.
    Often you have a whirring sound when you power on the machine.
    L4:The Main PWB sensed a Main Drive Motor MOT1 problem.
    Feb 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
    286 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
