Question about Marathon DJ-2000 Amplifier
Marathon dj speakers are thay any good? Please answer
    President:
  • 2,246 Answers
Marathon ENT-12P ACTIVE LOUD SPEAKER BURNING FUSE WHEN POWER ON, WHAT'S WRONG?
there is a dead short after the fuse
check for a failed/ burnt item
Aug 21, 2015 | Marathon Audio Players & Recorders
How do I stop vibration sound from the L1??
Try asking your question in the Bose forum (there's a DJ section).
Bose L1 Musicians
Jul 12, 2014 | Bose L1 Speaker
I have 2 Mtx PA speakers with Brand new Stereo cables plugged into the back of them then the other end is going to my amp. But When i turn on my dj program and try to test them It is extremely quiet. Even...
This is a car stereo amp or DJ Amps and speaker set up? I think your question is in the wrong area. It sounds like you have something switched in the wrong position like monitor or record possibly using the wrong outputs or incorrectly figured signal routing. Possibly check the amp out signal selector on the mixing board? This question could be answered much better by a DJ in one of the many problem solving forums they have at other web sites. I have visited a number of them researching equipment I was selling. Just Google DJ Mixers forums.
Aug 16, 2013 | Car Audio & Video
What type of battery is needed for the Timex Marathon T5G811 Stopwatch?
The obvious answer is to look for the numbers on the battery that is in it. If it doesn't have a battery then that gets a little tougher and you could probably contact Timex through the internet. Good Luck!
Oct 30, 2009 | Timex T5G811 Marathon Stopwatch
Both clip led light stay on and amplifier is switched on
If the clip lights are on the unit has detected too high an input level. With nothing connected, this indicates a problem in the pre-amp section. Since this happened right out of the box, don't waste time on it. Return this for a warranty exchange.
Dan
Jun 30, 2009 | Marathon DJ-2000 Amplifier
Setting up my bands new pa!!!
You can work forwards from the mic to the speakers, or backwards from the speakers back to the mic.
The mixer and the amp both should have lights to indicate when there is signal present -- if you don't have lights at the mixer, then you won't have any sound downstream at the speakers. In this case, the problem is with the mixer or the sound source (mic or instrument)
If you *do* have lights at the amp, then the signal is getting that far, and the problem must be with the amp or the speakers.
Jun 02, 2009 | Marathon DJ-2000 Amplifier
What speaker can i use?
Joe, the simplest solution <and least expensive> is to remove the ripped speaker, google "speaker re-coning" in your area and have it re-coned by someone local. It's much less expensive then replacing it. Please rate my answer, thanks.
May 31, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
What does parallel mean on my marathon 3050 power amp?
parallel mean that you connect speakers wire together to amp(positive side with positive side and negative side with negative side)in this situation you got less resistance from speakers and more current.
i mean more sound level.
Apr 11, 2009 | Marathon DJ-2000 Amplifier
Marathon 2000 amp... PROT light
Ok this means the AMP is in protection mode!..most likely the cause is a short in your wireing from the speaker wires! check all wires going in and out of amp! Look for stray wires touching metal or other contacts! (If this does not fix it the short may be inside of amp!
(This has nothing to do with a fuse!)
Please rate this FREE response!
THANK YOU!
Jan 19, 2009 | Marathon DJ-2000 Amplifier
Marathon DJ-2000 Amplifier Logo
106 people viewed this question
Top Marathon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marathon Audio Player and Recorder Expert? Answer questions, earn points and help others
