Question about Homelite Plumbing
Have a homelite AP-125 - UTO1709 F, want to know how far it can pump water uphill
    President:
  • Homelite Master
  • 1,378 Answers
Your best bet is to ask Homelite directly for the pump curve. Since Homelite does not appear to offer it anymore I could not find anyone who published the information, hence the referal to Homelite. A typical pump curve for a small pump like this will show GPM or GPH based on several discharge heights. You do not need to consider the overall run of pipe or hose but only the total change in height. In other words, pumping thru 150' of 3/4" hose up an incline that has a total rise of 12' would end up delivering the GPM for 12' on the curve or something very close anyway.
Contact Homelite here.
John
Posted on Jan 04, 2011
Ap-125 homelite gas watwer pump pull cord replace
few years late but here: guessing your problem area is the impeller blade? remove impeller blade by turning clockwise ( i put a screwdriver in the pull cord fin to stop shaft). Then remove spring around rubber gasket behind blade (then rubber gasket pulls off shaft. everything else just UN-bolts. Just figured it out myself today.
Jan 01, 2013 | Homelite Plumbing
Parts for AP 125 water pump (Homelite ) that is no longer being manufactured.
Homelite still has some parts for this pump
go to http://hcpi.arinet.com/scripts/EmpartISAPI.dll?MF
search for AP125 with no space
pick your model
parts list will come up
Jun 27, 2011 | Homelite Plumbing
I have a homelite ut20585 string trimmer that i have put a new primer bulb, fuel lines and fuel filter on. i have checked the spark plug and it is good. i cannot get it to fire and run.
Ok you have to be 100% certain that you reassembled those hoses correctly, if any one of them is incorrect you are dead in the water as far as getting fuel properly. Tell me 2 things, Why did you feel they needed to be changed? and now that you've done it does the new primer bulb pump fuel at all, and maintain a full bulb of fuel after 15 min?
May 11, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
How do i fix my yz 125 1989 water pump the water comes out the over flow pipe aswell as air
1989, Your kidding me right?. I'd hazard to guess that you"ve blown a head gasket and there ain't nuthin' wrong with the water pump , seems to be pumping fine. Time to spend a bit of cash on the old girl hopefully a new head gasket will get you by but how far can you go before something else packs it in.I mean if youve been replacing piston rings,big ends and little ends then all is good but if you don't know about the service history well.............Goodluck.Hope i've been helpful to ya skeff .
Dec 01, 2009 | Yamaha YZ 125 Motorcycles
I have a Homelite recirc pump AP-125. Motor runs
usual if the pump is dry you need to try bleed get some water to the pump. either pouring some in the lift pipe some pumps have a bleed screw to pour into to get it pumping. if it still wont could be the fins in the pump that are not working proper
Sep 26, 2009 | Homelite Garden
Motor will not start
For some reason the engine is flooded. To make it start do the following: turn the choke off, hold the throttle wide open and crank it until it starts.Do not push the primer bulb first. It already has more fuel than it can burn. It will smoke more than usual until it burns out the excess fuel. You may also have a carb problem but this should allow the engine to start so it can be diagnosed.
Please rate this solution if it helps-
Mar 19, 2009 | Homelite Garden
Homelite AP 125 two stroke motor will not start after replacing fuel lines. There is fuel coming into the carb and into the cylinder as well. Motor will not attempt to start. Spark plug is new and has...
If you have a two line fuel system make sure the lines didn't get crossed. If they are you could still get gas to the cylinder but not enough. I hope this will of some help to you. Donnyb60
Mar 18, 2009 | Homelite Garden
Plumbing Logo
443 people viewed this question
Top Homelite Plumbing Experts
richie46
Gil Shultz
Robert Dean
Robert Dean
Level 1 Expert
Are you a Homelite Plumbing Expert? Answer questions, earn points and help others
