Question about Boating
We removed all the wood trimming/doors inside our Catalina 30 sailboat. We want to do a clean/revive type job on it. The wood is teak. How do we proceed?
  • 784 Answers
If the teak is bare teak --- a light sanding with a sanding block should be good and then follow that with a good rub down of teak oil ( sea-fin teak oil is a good brand ).
if the teak is finished teak --- and you want to remove the old finish and sand out any stains(?) then you will need to use a more aggressive sand paper and finish off with a lighter sand paper,, clean up with acetone, use a good tack cloth and start applying varnish -- the best varnish that I have ever used is a brand called ' Epiphanes ' and you will either want to use a ' matte ' finish or a ' gloss /semi-gloss ' finish. personally I have found the 'matte ' finish to look better and it brings out the true beauty of the teak itself. ( make sure you follow the sanding instructions between coats as this will give you a nice smooth and sharp look ).
enjoy the water ---
c...
Posted on Jan 04, 2011
Im getting a strong fuel smell from my bilge followed by fuel in the water when the bilge turs on. the sailboat is a 1984 catalina
obviously you have fuel leak and a major fire hazard. find the leak before a fire happens.
Jul 10, 2017 | Cars & Trucks
How do I remove black water stains from normally oiled teak wood?
well 1st you need to determine what stains are made from ? if there a food stain then there most likely made from a grease of some sort , if this is so then denatured alcohol will take them off (with a bit of rubbing ) if there a rust or mildew stain then you'll have to use something stronger like muriatic acid (diluted w water 50/50) also note never add water to acid but instead add acid to water (yes it makes a huge difference) , this is dangerous stuff and all safe precautions need to be taken with it , this will also require all the teak oil finish to be reapplied after acid is neutralized with say baking soda and water (paste) and dried in air as this rough chemical will remove all the woods natural oils
while teak is a nice wood to have (beautiful looking) when something like this happens to it , it sure is a expensive wood to maintain
Oct 30, 2015 | Home
Is teak oil sticky like paint when applied to wood
yes it will be especially in sunlight !
are you doing the teak decking ?
i only did this once and never again because became sticky and marked the inside carpets ! only clean teak decking with the special cleaner then apply brightner fluid !
Jul 30, 2014 | Star Brite Premium Teak Oil
Can not get rear passenger door panel off
there should be a screw behind the handle to open the door and a few more behind the wood trim panel. then the panel pops off.be sure not to loose the gaskets that are on the retaining clips.the wood trim pops off too. be careful. the wood is delicate.the shade assy should bolt to the inside of door not interior panel.
Jun 30, 2012 | 2005 BMW X5
I need to replce the drivers side mirror. Just seeking instructions on how to.
Remove front door handle bezel screw cover Remove inside handle bezel screw Remove inside handle bezel Lift upward on the rear of the front door inside handle bezel Disconnect electrical connector Remove handle screw cover
Remove handle screw Remove door trim panel upper screw Remove door trim panel lower screw Remove door trim panel (pull the door trim panel outward to release the pin-type retainers)Remove front door sail panel
Disconnect mirror electrical connector Remove 3 exterior mirror nuts and exterior mirror
Mar 07, 2011 | 2009 Ford Fusion
02 jaguar xtype how to manually open doors if handle is broken
Hi
if the door is locked and wont open from the inside or outside then you have to remove the interior door trim, this can be tricky as the seat is in the way, you can often just remove al the top brackets holding the door trim on and get your hand down inside the door to pull the metal bar than opens the door.
Do you need a step by step guide? you can do this your self, quite an easy job just takes a little patience.
Regards
Dan
Dec 30, 2010 | 2002 Jaguar X-Type
Install instructions for new window switch module
Drivers side. Pull back the trim inside the door handle pocket, uner the trim there is a philips screw, then the window switch with wood trim pops out, disconnect the connector, swop the sprung wood trim and your good to go.
Nov 18, 2008 | 1998 Jaguar XK8
How do i take the door panel off of a 2002 sonata to repair a window that is off track
Remove the door window regulator handle and then remove clip using a piece of cloth (Manual type only). esac050a.gif 2. Remove the quadrant inner cover and the rear view mirror. esac050b.gif 3. Remove the front door inside handle housing. esac050c.gif 4. Remove the front door trim panel. esac050d.gif 5. Insert a trim panel remover between the trim fasteners and the door trim panel to pry off. Disconnect the door lamp connector. esac050e.gif
Jul 25, 2008 | 2000 Hyundai Accent
Stereo installation
There are 2 types of wood trim on the s-class. One is a solid piece and the other is split in the middle. Remove the ac pushbutton panel, remove the shifter trim and remove the cigar lighter insert. If it is a solid panel, then you will unscrew two screws underneath where the ac panel was and I believe that with the ac panel out of the way you can reach in and pull the radio head out. If you need to remove more, then be very careful with the wood-very costly. If it is the split wood, look for a screw on the back of the cigar lighter wood trim(you've already removed the insert, right). You need a 1/4 in. ratchet with a screwdriver bit to access. You only need to loosen it up and slip it off. With the wood out of the way, look for two hidden screws on the inside front edge of the center console wood panel-right behind the wood cover you just removed. These will have to come out as well. Once they are out, pull up gently on the front of the rear wood panel(around the shifter) and slip out, There are likely two more screws underneath this panel. Take them out to remove upper wood trim.
Jun 05, 2008 | 1994 Mercedes-Benz S-Class
Boating Logo
164 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
