Question about KitchenAid Artisan Series Tilt-Head Stand Mixer
How to attach a icecream maker KICA0WH to KitchenAid Artisan Series KSM156 that has a cap on the beater shaft. In the manual it shows how to attach it to the mixer with spring and no spring but does not show what to do when there is a spring and a cap. It is not clear how to remove the cap which would probably solve the problem.
Hi chuckster57 did you have the solution to Marzenna's problem? I have the same problem but kitchenaid model is 5KSM150!
Posted on Feb 20, 2011
  • 1 more comment
  • marzenna Feb 20, 2011
    I'm afraid you will have to buy a new attachement which I did. The US ice cream makers don't work on all models distributed internationally/or just newer models :(
  • alex889 Mar 10, 2011
    what is the part number or name?
    Thanks
    Hi, I have the same problem what is the part number or name? Thanks
    President:
  • 1,102 Answers
After the bowl has been frozen you attach it to the base. Then you take the part your asking about and attach it where you would put a beater or whip. The trick is to make it spin and the notched part stay in the "center of the circle". You don't use the top front of the mixer. I had to practice without the bowl and beater bar to make sure I had it right.
Posted on Jan 04, 2011
  • 1 more comment
  • marzenna Jan 04, 2011
    Thank you for that but what I mean is- I cant attach it where I put beater as there is a round cap that will not go through the Ice cream driver
  • Chuck
    Chuck Jan 04, 2011
    Give me a minute to get mine out and take a picture
  • Chuck
    Chuck Jan 04, 2011
    I can't
    post a picture in my response. If you E-mail me at drinchu@sbcglobal.net I can send it to you. Be sure to put mixer in the subject line.
Beater is hitting bowl
You can find the User's Manual (which shows how to adjust beater-bowl clearance) for your model at:
https://www.kitchenaid.com/customer-service/manuals/
Apr 22, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
A gasket type rubber ring is coming out of the assembly that the beater is attached to? it will not stay in place. where does it go? in the PLANETARY UNIT?
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Somehow the O-Ring is coming off of the Vertical Center Shaft (11)
That rubber ring prevents Oil from the transmission gears dripping down
to the Planetary into your mix.
Aug 03, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I cannot remove the mixer attachment from the mixer. It will not move, or twist to the side to release.
Use a small amount of vegetable oil to lubricate the beater shaft and
the beater. Slightly tap the beater up and sideways with a rubber mallet
until you can move the beater easily along the shaft.
Jul 31, 2011 | KitchenAid Artisan KSM150PSAQ Stand Mixer
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I lost the directions/recipes for my kitchenaid ice cream maker. I can I replace it?
Hi BMILLARD55, yes, you can replace your directions and recipes for your icecream maker. You can download the KA Ice Cream Maker Use & Care Manual in PDF format from the KA website by clicking on the following link: http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KICA0WH_Use%20and%20Care_EN.pdf
Save it to your computer and print what you need to print.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it. hslincoln
Jul 09, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Having trouble removing beater from shaft... HELP
These are held on with a bayonet attachement. You need to rotate the beater to disengage from the shaft.
I would recommmend using a brass pin punch against the tang on the beater and tapping it with a SMALL hammer to rotate the beater.
Once the bayonet is disengaged, it should walk off the pin. If it doesn't you might have to use some penetrating oil like PB Blaster.
IN THE FUTURE put a light coat of mineral oil or food-safe grease on these mating parts to avoid the probllem in the future.
Dec 22, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
The beater shaft seems jammed. I can't push it up to remove my beater.
best returned to service centre as these are very hard to get apart.
Sep 15, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Black stuff wiping off beaters of kitchenaid mixer
If it's just the wire beater attachment, then it's possible it's oxidation from the metal/aluminum. Did you put it in the dishwasher? The manual says not to put the wire beater in the dishwasher. Hope that helps.
Dec 21, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid stopped working Modle KSM150PSER
Hi Phyllis. Unplug the mixer, lay it down on one side and look for the pin that holds the planetary shaft in place next to (where you attach beater). The pin may have worked itself loose. If this pin is not all the way through it's opening, the shaft will not turn the planetary unit. Hopefully the pin did not come all the way out and you can tap it back in. If the pin is gone, It's in one of your cookies and hopfully you'll find it before anybody else does. Hope this helps. Ricardok45.
Dec 17, 2008 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid Mixer Squeaking
I would first get some canned air. Spray out the area around the Shaft. This is to make sure no harden food is up there. After that is clean spray some cooking spray "PAM"in the Shaft area. This should help. Good Luck
Feb 11, 2008 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid Artisan Series Tilt-Head Stand Mixer Logo
271 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
