Question about Sport & Outdoor - Others
Re: transducer installation should the transducer on a Elite 5 be in line with the bottom of an aluminimum hull or the bottom of the ribs running along the hull thanks
  • 784 Answers
Try and mount the transducer at the lowest point on the hull and on the flatest part,, with the direction arrow facing forward.
c...
Posted on Jan 04, 2011
What can i do to stop the flashing of the depth finder at times it will not show the current depth
Hey Joe,
Wow.. where to start.. there are so many things that will cause the issue you are describing.What type of electronics do you have? Does this happen at all speeds? Where is the transducer mounted? I need more info about when it stops reading.
1.Wrong setting on the unit
2 Bad transducer
3 Bad transducer mounting (either inside the hull or outside the hull.)
4. (In hull) Turbulence going under the boat (mine quits reading at about 55 mph @ half trim...the boat is lifting so much it causes air pockets so the transducer loses contact with the water)
5. (Outside hull) Turbulence around the bottom of the boat where the transducer meets the water.
Good luck,, when you get the info.. reply to me..
Jun 03, 2017 | Boating
My elite 7 won't read depth when boat gets on plane
The transducer MUST be in contact with the water for it to operate properly. Check and make sure (if it is a thru-hull) that the ducer isn't in the air when you're planing. I've read that wiping the transducer with Dawn dish detergent speeds up the "wetting" of the transducer and makes for a better contact with the water.
Hope this helps.
-Steve
Feb 26, 2015 | Lowrance Elite-7 HDI...
Installing transducer
I assume you're talking about a transom mount transducer. Best if the leading edge of the transducer is even/level with the hull and tilts slightly down in the back or trailing edge of the transducer. Also try to eliminate a gap between the leading edge of the transducer and the hull.
Mar 25, 2014 | Hummingbird Boating
Lowrance Elite 4X fish finder that reads between 1.5' and 2.5'
Hey Anon
The transducer installation is more important than anything.. next to correct wiring! You must make sure the mounting is good,,, if its outside the hull, make sure its sitting 1/16th below the hull with no obstructions.. if its inside the hull, the medium you used to fix the puck to the hull must be porosity free and the puck sitting as level with the WATER as possible..
Now, take the manual to the lake with you and DO NOTHING but read the manual and apply what you read to the unit,,, read -repeat - read-repeat.. forget about fishing... now read-repeat and learn... IF nothing seems to be reading correctly.. its probably the transducer installation.. YOU DID use a/the transducer specifically for this unit!!
Jun 24, 2017 | Lowrance Elite-4x Fishfinder
I was told that the Uniden QT-206HP depth sounder will not work thru an alunium hull is this true or false
Hi!
The transducer for your depth gauge will not work through an aluminum hull. A drilled through-hull transducer or a transom mount transducer are your options here.
Just in case you require it, your Owners Manual can be viewed/downloaded at:
http://ca.binnacle.com/pdf/Uniden-QT206-manual.pdf
Hope this helps..
Jun 20, 2011 | Uniden Qt206hp Digital Depth Gauge With...
Does this transducer mount in the floor of the boat,or on the bottom of the hull?
Hi!
This transducer requires a hole to be drilled in the bottom of the hull and the unit installed from the outside, using a caulk/adhesive such as 3M 4200 or 5200. Nice choice. Furuno is a good manufacturer!
Hope this helps!
Dec 24, 2010 | Furuno 520 5psd Plastic Thru Hull...
My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Jan 21, 2010 | Humminbird Boating
A65 Transducer
jmiller,
Sound like your getting turbulence from the hull or your angle is allowing cavitation under the transducer. Look under the hull where the traducer is mounted and look for a part that has no obstruction including saltwater pickups, hull relieves, etc. The other thing to check is to take a strait edge on the bottom of the transducer to ensure the angle is slightly forward than the hull.
Bob
Sep 11, 2008 | Raymarine A65 Combo GPS...
Depth finder problem
The problem is not so much the flat bottom, although they are prone to this problem. The way the sonic waves have to travel through the water is affected by turbulence, especially by air bubbles and cavitation, and by the transducer actually leaving the water, which happens frequently on flat bottomed boats. The best solution to this is to have the unit mounted through the hull so it is completely flush with the hull surface - often they are mounted with a surface flange on the outside of the hull which although thin still causes cavitation around the transducer at higher speeds. about 14 knots will usually interfere with the accuracy of the readings on most hull shapes - forward looking sonars perform usually better. Another thing to check is that the transducer is actually seating right in the housing, if it is not flush with the flange then you have problems - even half a millimetre is too much. check no muppet has painted the transducer with antifouling paint - that never helps, also check if there is a build up of marine growth on or near the transducer - a smooth hull will always keep your depth working until a higher boat speed. if the transducer is growing stuff itself then gently scrape it off - be really careful not to scratch the surface. There are now available non-sonic depth sounders, especially ulf radio signal devices, but I have heard no good reports about them, last i saw they were very expensive and maybe they experience other problems at high speed. there also have been towed devices available that may suit your needs better, although probably a lot of trouble in shallow waters. If you can borrow a waterproof video camera, you could mount it behind (not too close) the transducer, this would be a pain to do, but it may give you an insight into what part of the hull if any is causing the problem (tie the camera to the top of the boat securely in case the mount fails) Hope this helps, sorry but your dealer is not totally wrong :)
Sep 25, 2006 | Lowrance M68C GPS Receiver
Sport & Outdoor - Others Logo
89 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
