Question about Carrier Heating & Cooling
I have a carrier weathermaker 9100 air conditioner / furnace. When the ac is running, water from the evaporater coil doesn't drain. It builds up around the colil and leaks all over the floor. I took apart the drain tubing sections and blew air through tehm with an air compressor. Some crud came out and I thought it would take care of the problem. It worked for a short time and now does it again. Is there something I am missing? Could there be something else that needs to be cleaned? Any advice would be much appreciated. Thank you
  • 770 Answers
Most likely you will need to pull the coil to clean the drain pan area around the coil
Posted on Jul 09, 2008
Carrier weathermaker 9200 furnace air filter placement
air filter for your model can be found on amazon, click here and take a look: 20x25x5 Electrostatic Washable Furnace and Ac Filter 19 3 4 24 3 8 4 3 8. I hope this was helpful. Cheers
Feb 17, 2013 | Heating & Cooling
Where is the drain pan on a carrier weathermaker 8000?
Hello, the drain line will be located under the unit near the condenser coil. Sometimes it can get blocked and the condensate will settle toward the front of the unit and leak from the unit. Also, make sure the unit is tilted back in the window about a 1/4 inch aswell.
Jul 11, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 38TZA036320 evaporator coil
Hello, sounds like a blocked drain line or cracked condensate pan. Try cleaning the drain line first with a wet/dry vac at the outlet of the 3/4 inch pvc line, if this does not help you will need to have the drain pan repaired or replaced.
Jul 04, 2012 | Heating & Cooling
Condensation in the furnace, as a result of which air is not being circulated. Air conditioner is Carrier Model#38CKC036340. Is there any place where I should be removing the condensed water??
The coil for the AC sits above the furnace. Two refrigerant lines enter the
plenum, usually the condensate line is on the same side and at the bottom of the plenum. Sometimes they use pvc pipe or a garden hose to drain the condensate.
Your problem is worse than that, it sounds like your indoor coil is froze up, that is why you dont have airflow, either you have a dirty filter or your fan does not work
Jul 08, 2010 | Heating & Cooling
I ve a split ac. but it is throughing water when on. why?
This is probably water, coming from condensation off of the indoor coil. As the coil gets cold, the moisture builds up and drips down into the drain pan, from there is is suppose to be drained out on a drain line.
Sometimes, the drain lin gets plugged and drains in places that it is not suppose to, need to clean the line.
If this has been helpful, please leave me a rating, and contact me if you still have questions.
Sincerely,
Paul
Apr 02, 2010 | Carrier 38CKC036 Air Conditioner
Furnace overload limit switch
Here is the service manual with wiring diagram.
Dec 19, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker won't stay running
Is this a gas furnace if so is it high efficient if so is there an led light on the furnace blinking a code usually seen through a window at the furnace. is the thermostat battery operated if so is it a new battery and are the aif filters new. These would be my first steps to check hope this helps
Dec 21, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Mar 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker SX
If you are running it in the cooling function, your drain maybe backed up. Find your drain outside if you can and suck it with a shop vac.
Nov 25, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
83 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Cris Sparks
Cris Sparks
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
