Nothing works no audio no menu no volume - Computers & Internet
  • 67 Answers
Reinstall the proper audio driver.
Posted on Jan 04, 2011
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
My gps has not audio
www.garmin.com/us/support/
1 (800) 800-1020
May 19, 2015 | Garmin Refurbished nuvi 50LM GPS...
No sound
  • 1 Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2 Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3 Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • Read more : http://www.ehow.com/how_7498064_troubleshoot-vizio-sound-problem.html
    Mar 08, 2014 | Vizio Televison & Video
    RCA 60921 rear projection tv. Everything worked perfectly until today. It sometimes made a hissing noise on and off but nothing very loud. Today I turned on the TV and the audio works but there is no...
    Bad FBT Flyback Transfomer.You need to also check the Hori output Transistor,chances are if FBT is bad then Hori output will be shorted.
    Mats Electronics should have FBT 1-800-628-1118
    ACME 1-800-575-9833
    Jun 28, 2011 | RCA P60921 60" Rear Projection Television
    I cannot unmute my microphone. I've looked in my control panel-sounds and everything is functional. When do a test message on Skype I hear nothing. Please help!
    On your Skype menu go to "Tools" at the top of your menu.
    Select "Options" and then select "Audio Settings".
    There is a drop down menu for "Microphone".
    Try selecting each option until you see the "Volume Bar" start indicating that your mic is working.
    Jun 18, 2011 | Computers & Internet
    I have a Hannspree 25" flat panel LCD and I can't get the volume to work.
    Most monitors/TV come with a remote. Although the remote offers full funtionality, there are usually basic controls on the set itself. Usually these buttons are present; Menu, Volume up/down, channel up/down, input, and the ever popular ON/OFF.
    Depending on the type of connection you have going to your display, you may additionally need audio.
    HDMI: No separate audio needed.
    Component (Red, Blue, Green) Audio L/R needed.
    S-Video (Round 5 pin cable) Audio L/R needed
    Composite (Yellow RCA) Audio needed
    However you did mention the VOLUME did not work, if it is too high, a setting in the TV's menu to select a different output. either STATIC (ONE LEVEL, the you can not adjust), or DYNAMIC, one that you can adjust.
    Check the Menu options ofr your audio.
    Good luck and don't forget to vote!!!!
    Oct 08, 2010 | Hannspree Televison & Video
    Audio Jack of NEC VT47 (using external speakers)
    go to your menu find the volume settings. i think your volume is 0 or muted.
    Oct 07, 2009 | NEC VT47 Multimedia Projector
    Have external gateway speakers
    First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
    Thanks & Regards,
    Shiva
    Sep 11, 2009 | HP (ZD929AA) Computer Speakers
    Internal speaker not working
    There's an actual internal speaker, and there's the audio out jack, either at the back or front, or sometimes at both locations.
    It seems to me you're getting no sound from the audio out jack, where you normally connect powered, amplified speakers. Have you checked the volume setting on these speakers? Turn the volume up as high as it goes.
    Check in the system tray area (bottom right corner of your desktop, in Windows) for an icon that looks like a speaker cone.
    If found, and if you hover your mouse over the icon, in Vista, it should display your audio card name and model. If you click over the icon, the volume bar shows up. Slide the volume up as high at it goes and try playing some music from your PC. Does that satisfy you?
    If not, right click over the icon and you may be shown a menu of different options to do with your audio system. There should be one for a "mixer", where you would turn different things on or off, or where you can boost your volume or microphone sound level.
    If there's no icon in the system tray, try going to the Device Manager, from the Control Panel window, and see whether your audio component is enabled and working Ok. A yellow icon, or red, over any component is an indication that there's a problem with the device. If that's the case, try right clicking on the device and uninstall it from the ensuing menu.
    Next, reboot your machine and Windows should reinstall it with the proper drivers and your Pc should be back to normal.
    Aug 10, 2009 | ASUS P5GC-MX/1333 Motherboard
    Surround sound not working through ordinary tv
    Try connecting the red and white audio cords to your system from your cable box/satellite receiver instead of your tv. Worked for me.
    Oct 01, 2007 | Audio Players & Recorders
    Computers & Internet Logo
    12 people viewed this question
    David Payne
    David Payne
