Question about Sony KP-41T35 41" Rear Projection Television
The box on the back of tv that the coax cable turns onto is broken. Can we go buy a cable peice and just solder it back on or do we need to order the whole little box?
    President:
  • Sony Master
  • 1,779 Answers
You can buy the RF jack and solder it back onto the tuner as long as the tuner has not been damaged beyond repair. Inside the tuner the center conductor from the jack solders into the printed circuit board. If any small parts are broken or missing then you will have to replace the tuner.
Posted on Jan 04, 2011
  • aroon74 May 01, 2011
    where can i buy this new part or is there a name for this part if i order thru tv repair place?
  • Jim Krause May 01, 2011
    Most all tv shops keep them in stock. A common problem. " RF Cable Jack"
How do i replace the vhf/uhf connector so i can hook up the cable?
You can get a cable box that has coaxil and RCA or HDMI cables. You can run cable to box and RCA's to tv. Or use a vcr or converter box instead.
Or you can dismantle the tv, take a soldering iron and heat up the old solder joints. Then insert new connection and re-solder it in..
Sep 21, 2009 | JVC AV-32F485 32" TV
Antenna/Cable Connector partially ripped... Hi, everybody. Does anyone know how to fix a ripped antenna/cable connection? Thanks for the help. My TV Model is a Daewoo DTQ-13P3FC 13" TV for more details....
The cheapest way i can think of is open the tv and solder the ripped peice back on. That should work. If not you can go to radio shack and buy a new peice for it and install it by soldering the connections back on. Hope I could help.
Wayne
Jun 26, 2009 | Daewoo DTQ-13P3FC 13" TV
I have plenty of old TV's that have a standard cable input, but no AV input (The white and yellow plugs that modern TV's have). Do they make a converter that turns the yellow and white AV plugs into a...
these are not cross compatible an rca hook up is a base band signal basically raw data, and coax(cable line) is a frequency with a carrier best suggestion I have is to buy a vcr with a coax out put and rca input that way the vcr can pick up the video signal then remodulate it onto a channel frequency and send it to the tv
Apr 14, 2009 | Televison & Video
Broke the piece where the cable wire goes in...what's it called?
Unfortunately, that coax connector  is almost certainly crimped onto a cable inside.  You might want to pull off the back panel to see if that internal cable is screwed onto another jack on the chassis. If so, you can disconnect that end and substitute another cable, they come in several different lengths and are not critical. Any electronics store will have them.
If it isn't equipped with a connector inside, you will need to have someone unsolder the defective cable and install a new one.
Dec 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Broken cable tv port on Mitsubishi CS-27209
Yes but repair shop charge alot
for this , and it's easy repair .
You can buy some solder , 40 watt soldering iron , Male coax plug from Radio Shack and
resolder two connections and save 100.00
RADIO SHACK HAS THEM
IT ,
Dec 16, 2008 | Mitsubishi CS-27209 27" TV
EWF TV ANT IN BOKEN
It can be soldered back on. With that particular model, I don't know if the connector is connected to the tuner or if there is a litte square anteena box which then feed a cable to the tuner.
Nov 26, 2008 | Televison & Video
Trying to hook up your DV220SL8 DVD/CD Video Cassette Recorder. I have an antenna coming in coax but there are no places to plug any of the jacks on the tv.
There are two ways of solving this problem
1.It seems to me that you need an RF Modulator Box. What this does is convert the RCA cables (Yellow,White,Red cables) into coax. You buy the box then plug you antenna and RCA cables into the box. The box has a coax output that goes to your TV. You can then switch from VCR\DVD to antenna.
2. I dont know if your VCR/DVD has it but try hooking up your antenna to the VCR coax INPUT and then hook up your TV to the coax OUTPUT. Both Coax INPUT and Coax OUTPUT should be on the back of the VCR/DVD device. Your going to need an extra Coax wire for this.
Hope this helps
Thanks for reading!
hope this helps
May 01, 2008 | Televison & Video
Broken cable connection inside board
No need to buy a PC board. Have professional tech solder leads back and tighten connector
Apr 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
EWF TV ANT IN BOKEN
ANGLS186-YES YOU CAN RESOLDER THE ANT. IN COAX CONECTION BUT KNOW YOU MUST FIRST SOLDER THE CENTER WIRE OF COAX TO TUNER BD. THEN CAREFULLY INSERT COAX BACK INTO ORIGINAL POSITION.THE EASIER SOLUTION IS TO USE A VCR OR CABLE BOX HOOKED TO YOUR SETS' VIDEO IN PORT AND CHANGE CANNELS W.THAT COMPONENT.JOE TV
Nov 19, 2007 | Emerson EWF2004 20" TV
Snow on screen/wiggle the coax
SOUNDS LIKE BAD SOLDER CONNECTIONS IN SIDE THE TUNER. TAKE THE BACK OFF AND TRY TAPPING AROUND WITH YOUR DRIVER HANDLE THIS WILL LEAD YOU TO WERE THE PROBLEM IS. THEN WE TAKE THE TUNERS APART AND RE SOLDER THE CONNECTIONS,BUT YOU HAVE TO BE VERY GOOD OR YOU WILL MAKE MATTERS WORSE.
Apr 11, 2006 | RCA P52830BL 52" Rear Projection...
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
