When i turn on my computer it says monitor is fine and under that it says check pc signal cable. what should i do!
    Scholar:
  • 155 Answers
I guessing your talking about a desk top. check the cable that comes from your monitor and make sure one of the pin inside aren't missing or bent. if bent you can try straightening it out but make sure you unplug the monitor. (i usually use a steak knife or a flathead screw driver). hope this helps. please rate if this helps. thank you.
Posted on Jan 04, 2011
I have a e machines desktop that will not boot up. I turn it on and the monitor says no signal. I think it might be stuck in hibernation mode. The fans on the tower start but thats about it. If some one...
No Signal means you Display or Monitor is not getting signal from Video Card.
In this case:
1. Check if all the cable are properly plugged in. Check on both monitor and computer back. 2. Check if cable is not broken. 3. Try unplugging cables and plug them back. 4. Try some other monitor or cable. 5. If cables are fine than problem could be with your video card.
As you are getting No Signal that mean your monitor is working fine. Problem is either with cable or video card.
Jul 06, 2011 | Computers & Internet
Monitor has no signal
have you tried you PC with another Monitor?
I'm expecting that you still have same problem.
Is your PC making any audible noise, beep sounds?
May be you should have your PC checked
Mar 15, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
Tried installing samsung syncmaster monitor and get and error message check signal cable dialgoue and can't do anything, previous monitor works fine
Does the new monitor work correctly when installed to some other computer (notebook or desktop) ? If it, you have a "dud" that should be replaced, under warranty.
Try changing the data-cable between the monitor and your computer.
Oct 10, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
When i turn the computer on the monitor says it is in power saver mode and to activate using the pc please help
Sounds like your monitor is not getting any signal. The monitor is probably working fine its the video card or connection that is having the problem. Check all cables, then check to make sure video card is working. Does your computer POST without any problems when you turn it on? Do you have an onboard video port and a AGP/PCI-e/PCI video port? If so, is your video connected to the onboard or the AGP/PCI-e/PCI
Jul 08, 2009 | Dell E773C 17" CRT Monitor
Message: check your PC and signal cable
That Means the Monitor Does Not Detect Your PC..Check The Video Cables And See If they Are Fully Connected
Apr 01, 2009 | Computers & Internet
Monitor not getting signal
Check your cables.
If the cables are fine then there is something
wrong with your comuter.
Do you hear any beeping sounds?
Mar 07, 2008 | HP Compaq d530 SFF PC Desktop
Monitor no signal
Check to see if there is more than one 15-pin monitor connection on the back of your computer. If there is, try plugging the video cable into the other one.
Is this a new monitor? Was it working before this? Does your computer sound like it is starting up normally?
Feb 01, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
