Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
I can't log in to my router's web interface. I've tried the password as both admin and leaving it blank while the username is admin. The IP adress I'm using is192.168.1.1 and the ASUS router model is WL-520gu. Please help?
  • 591 Answers
If you can not remember the password than the ownly thing you can do is a reset (according to manual) than you will be able to log in using default user and password (YOU WILL LOOSE ALL SETTINGS) so you will have to re configure the router...
Have fun!
Posted on Jan 04, 2011
Unable to log in to web face config. tried every combo for user name and password. nothing works.
Here is the answer from Linksys itself-
The default IP Address is 192.168.1.1. Leave the username field blank and the password is "admin".
Key to this is to leave the username field BLANK.
Jan 26, 2016 | Cisco Linksys E1000 WirelessN Broadband...
After trying to connect my mac laptop to ethernet suddenlink had a failure at the same time. NOWI CAN NOT OPEN THE ROUTER OOR ANYTHING. jim FOUTTY
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Linksys WRT160N Wireless Router
Lynsksy E1200 tried to reset. my passord and network name are of no assistance. After running software, router is not found. Tried using "admin" for both but nothing works. Please advise. ...
Sep 07, 2011 | Computers & Internet
How do i find my wpa2 key for this router? i have tried typing in th ip adress on my adress bar and it wont let me access the page.
What IP address were you entering in your web browser? Were you prompted for a username and password, or was the browser simply timing out when attempting to make a connection? I believe the default IP address for the router is 192.168.0.1 so make sure you're entering http://192.168.0.1 in your browser. If you're then prompted for a username and password then enter 'admin' for the username and try and leave the blank field blank then click 'OK' and see if you're able to login, unless you've changed this information.
Mar 01, 2011 | D-Link DGL-4500 Wireless Router
No set up cd 2 need to setup security
Hi, You can do this without the cd. Connect the router with UTP(lan) cable and enter http://192.168.0.1 Enter admin password and go to the security tab in the web interface. Make your desired settings.
Hope this helps! Don't forget to rate this solution!
Mar 01, 2011 | Belkin (F5D7230-4) Router (587009)
I have forgotten my security key and need to obtain it to set up a new wireless printer. I know my router IP adress
you will need to enter your routers IP in your web broweser (example: http:192.168.1.1)
Log in to your router and reset the wireless security password to something else.
The default login for most routers is;
username: blank
Password: admin
Or some combination of the two
~kenjiFox
Jan 07, 2011 | Computers & Internet
How do I put a password on my Belkin wireless G plus mimo router?
it depends on what you specifically want to password-protect: a. protecting the network from unauthorized users? b. protecting the network's admin interface?
for a. - log into your network's admin interface (usually http://192.168.0.1) - go to the category of wireless security - select the type of network protection you are looking for (strength - i.e. wep, wap, wpa2) and set your password following the steps listed within your router's admin interface...
for b. - log into your network's admin interface (usually http://192.168.0.1) - if you have never done this before, then your username should be filled in as Admin and leave password blank and hit enter.... from there, you are able to change or at least add a password to the interface from unauthorized access (usually under category security)
Feb 17, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't get it configured
Try to reset the router using a paper clip, then try to re-log in to the router with the IP address, If you are still unable to log in , try log as admin as the username and password as admin or admin on the username and password is password.
May 26, 2009 | Buffalo Technology AirStation G54...
Open signal!
You have to log in to the router using a web browser. Simply connect to the router's IP address. Typically, it's http://192.168.0.1 or http://192.168.1.1. You will probably be prompted for a username and password. Unless you've changed it, the default is either:
Username: (leave blank)
Password: admin
or
Username: admin
Password: admin
If you changed the password on the router, log in with your updated password instead.
Jun 18, 2008 | Linksys Wireless-G WRT54G Router
Password not working
Do the following: on your computer open internet explorer, in the address window type the IP of the router "example" http://192.168.2.1 your router IP should be on the bottom of the router. If not click start/run, type ipconfig at the > the router ip is listed at "default gateway".once you get to the routers logon page enter one of the following: username "leave blank" – username " admin " -or- username "admin" - password 1234 –or- leave password field blank. once logged on the router you can make your configurations. BPCS
Dec 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
665 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
