Question about Dell 3100MP Multimedia Projector
Hello, I am having problems with my Dell 3100MP projector. When I try to turn it on buttons on top start blinking green but projector's bubl is not turning on. Lights are blinking until the cord is removed from socket. I am can not turn off projector using ON/OFF button on top or with remote control. I am not sure if the actual problem is with bulb. Thanks Igor
SOURCE: Dell 3200 Projector color green instead of yellow on VGA not on S-Video
I changed the setting for color heat and got the right colors on the screen. The color is now perfect!!!
Posted on May 09, 2008
SOURCE: dell 2300mp projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
Posted on Jun 27, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Dell 3100MP Projector - No Signal Check Cable
Make sure you have the right input source selected. It may be looking for a signal from some input other than the one you're connected to. Beyond that, if it truly isn't seeing the input then you'll need to have the projector serviced.
Posted on Dec 17, 2008
futurework
  • 70 Answers
SOURCE: No power to my dell 2300mp
The fuse is a short round maroon colored part to the left of the power plug looking at the power supply module from the direction that you would connect the cord to. it is labeled F1 and it is a 4a 250v. This is not the problem with my power supply though. I suspect one of the components under the heatsink is bad.
as you all know don't bother calling dell.
Posted on Mar 23, 2009
SOURCE: Dell 1800mp will not turn on
I have a DELL 1800MP projector & when I try to turn it on the light blinks for a while then turns off??? Any idea of how to fix this??
Posted on Aug 12, 2009
Hi, is Dell 3100MP Projector is compatible with windows 7 laptop. I am Having message " NO SIGNAL, CHECK VIDEO CABLE" with Windows 7 but with Windows xp, the same projector works fine. Can anyone...
In most cases this problem is cured by enabling the external VGA (or monitor) ouput on the laptop. The quickest way is to reboot the laptop with the projector turned on and connected. Usually the laptop will detect an external display is attached and enable the port.
It is also possible to manually enable the external display port. It varies from laptop to laptop but look for the "Fn" key at the bottom left of the keyboard, usually coloured green or blue. You should see a row of icons on the top row of "F" keys which is in the same colour. Look for the one which is either a monitor, or possibly says LCD or CRT.
Hold down the Fn key and press the key you located in the last step. There is usually a delay of a few seconds and then you'll find something may happen. Usually the external output will be turned on alongside the local (laptop) display. Repeatedly following the last step cycles through all available configuration options, including both on, local on, local off, external on, and external off.
This should fix it. Make sure that the correct input is selected on the projector whilst doing this. It will be labelled on the projector and it should display the same input message on screen.
Feb 21, 2011 | Dell 3100MP Multimedia Projector
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
Dell 3100MP just powers off
check the heating of your laptop. it more heat chek your fan or cfu fan, if work properly.. shuting down is a lot of cause. over heating, fan not work properly case over heating... processor.. or board..
Jun 19, 2009 | Dell 3100MP Multimedia Projector
No Sound
check the setting of sound.. if its okay check the speaker wire connector or the chips.. but be care full for opening if you can open and fix no problem..
or look qualified technician for projector
Feb 03, 2009 | Dell 3100MP Multimedia Projector
I have a second- hand dell 3100MP projector which I use during church services to project songs and other material. Recently it has been showing a predominalty green image , particularly when showing...
sir
the lamp is not at problem, but the dlp engine is at fault, u may have to replace it.since u bought it 2nd hand,it is not worth changing the same as it will cost u more than ur buying price.when u plan to buy ur next projector, make sure u buy a new one as it will come with a fresh lamp & manufaturers warranty on the unit & at 4000 / 5000 hours of projector usage is guaranteed!
Jan 05, 2009 | Dell 3100MP Multimedia Projector
Dec 17, 2008 | Dell 3100MP Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
Dell 2300MO NOT STARTING UP Problem
Try the remote control.  You may have a problem with the contact switch in the power button.
Oct 02, 2007 | Dell 2300MP Multimedia Projector
Dell 3100MP Multimedia Projector Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
