Program codes for techwood reciever. using a universal remote
SOURCE: Code to program universal remote
You can select between tv, AV, dvd using the buttons on the front (second from the left I think)
Posted on Aug 25, 2008
SOURCE: Codes to program an RCA remote control
my remote will only work the volume. i need to program the remote to use menu to adjust the picture.
Posted on Oct 08, 2008
  • 21 Answers
SOURCE: Programing Code for RCA Universal Remote Control
It does not have any code.
Posted on Oct 22, 2008
SOURCE: i lost my manuals to my philips universal remote how do i program it wthoout using the code
I lost my instructions to program my tv with the remote can you help me
Posted on Nov 13, 2008
  • 6 Answers
SOURCE: Kenwood VR 209 Reciever, Remote Problem
http://blog.moertel.com/articles/2007/05/25/repairing-my-kenwood-a-v-receivers-remote-control-sensor
this worked on my kenwood vr-209. 10 others fixed their kenwood as well from the posts.
Jay
Posted on Jan 18, 2009
I have a duraband ht395 reciever and need the universal onn remote model ona12av058 code.. All the ones in the manual do not work? Anyone know this?
[PDF]Instructions - ONN Universal Remote Support
myonnremote.com/.../ONB13AV004%20Manual%20Version01.pdf
Mar 28, 2014 - will retain the codes you have programmed for up .... TV/DVD Combo, you might need to set up one ... Point the remote at the audio receiver,.
Faq - ONN Universal Remote Support
myonnremote.com/onn-faq.asp
How do I manually enter codes for my ONN Universal Remote? ... (You haveapproximately two seconds after the device shuts off or begins playing to lock-in the code.) ... so if you need to start the search again, it will pick up where it last left off.Missing: duraband ‎ht395 ‎reciever
RC: Durabrand codes one for all (Page 1 of 2) - Remote Central
https://www.remotecentral.com/cgi-bin/mboard/rc-one4all/thread.cgi?...
May 4, 2006 - 15 posts - ‎9 authors
Jan 25, 2016 | Televison & Video
Onkyo remote control codes
Your Vizio universal remote should be able to search for an appropriate code. If a thorough search produces no result, you may have to try another universal remote.
Sep 09, 2014 | Televison & Video
I need the remote code for a Techwood twd fv2a. The remote died and I have a universal remote, but no codes to programme it with. I've looked everywhere online but can't find anything.
In this case, you need to post both the brand names and model numbers involved in your request.Simplest would be to buy a new replacement remote and you can start here:
Remotes.com
Also, there is no such thing as a 'universal' remote; they are programmed with known codes available at the time of manufacture and sets that come on the market later than the remote will not be covered at all or only incompletely.
Some (expensive) remotes allow downloading of later code sets for newer models.
Jan 13, 2012 | Televison & Video
Universal Remote
are you programming the remotes with the codes for the TV manufacturer, as most Universals have to be programmed to the manufacturers remote codes to function, or Most if not all universals have a scan for the code function, refer to the manuals did theTV originally come with a remote, I am assuming so, if it didn't the TV may not have an IR reciever for the remote to work.
If this helps, please give a fixya rating, every one helps
May 27, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Lost instruction manual for URC-3426 All In One
User manual for ONE FOR ALL USC3426 lost require code for Baird television
May 05, 2009 | One For All URC-3300 Remote Control
Codes for universal remote
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 25, 2008 | RCA Universal Remote Control
RCA Universal #RC402A
Jun 21, 2008 | RCA Universal Remote Control
124 people viewed this question
 Grubhead
Grubhead
