Question about Proform CrossTrainer Treadmill
I cannot get it to incline. It will say it goes from .5 to 10 and not incline at all
    Novelist:
  • 129 Answers
First perform an incline calibration. The procedure is outlined in your users manual.
It is a simple procedure. Insert the safety key and start the machine in motion. Press the incline up button. While the numbers are increasing remove the safety key.
Now reinstall the safety key, the machine should incline to maximum then lower back down to minimum.
Now you can operate the treadmill, the incline should work.
Posted on Jan 04, 2011
I wanna know how to change a fuse for a saturn aura 2007.
What fuse ? Regular mini fuse ? Just pull it out with the fuse puller tool located in the fuse box compartment . Replace with same number fuse . 5,10 , 20 , 25 etc.. what ever it is . How To Safely Change Blown Fuse
Feb 02, 2017 | Saturn Cars & Trucks
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 | Dryers
Precor 9.23 Treadmill Inclines Randomly
most prob one of sensor / connection gone bad
Mar 30, 2014 | Precor 9.23 Treadmill
Continuous incline with no lights on display except 2 lines on the incline
RUN the software calibration, for easy diagnose, troubleshooting, and fix it.
God bless you
Sep 04, 2012 | Icon Epic T60 Treadmill
My proform 360p treadmill is stuck on full incline - can it be fixed and if so how???
try thisSometimes incline motors will get frozen in position and need broke free. Try this:
take the motor cover off and take the screw out of the bottom of the incline motor that is attached to the screw assembly. Once you remove the screw you should be able to break the incline motor free. run the incline up and down with the screw still off( laying the treadmill on its side may make this easier). Once it goes up and down (hold the screw so it goes in and out) reattach it then run the calibration described below. If it was just stuck it should work fine.
1. remove safety key
2. press and hold the speed+ and stop keys at the same time
3. Put the safety key in/on and release the keys
4. press stop once
5. hit the incline + arrow and let the incline go the whole way up and down
6. remove safety key and try
If these instructions do not work to fix the incline motor
check your main harness running down the right leg for breaks in the wires or a loose connection if nothings found you can switch the red and black wires on the incline motor terminal block and see if it goes down. If it does you know you are only getting voltage to one side of the motor. There is a schematic under the motor hood that tells you what the voltage should be when you press the up or down keys. Use a multi-meter to see if you are getting the correct voltage coming from the console to the motor control board and then from the board to the motor. If no voltage from console-replace console if you have voltage from console but not from board - replace board and finally if you have voltage from console and from board replace motor. You will need to test the voltage both when pressing the up key and the down key.
Jul 14, 2010 | Proform Exercise & Fitness
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Incline on treadmill is acting strange
Open the motor cover. There should be a service sheet in there.
Read Option 2 & try it.
May 12, 2009 | Proform XP 542S TREADMILL Drive Motor
Proform CrossTrainer Treadmill Logo
494 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
