Question about Philips GC 4610 Iron
While ironing a brown deposit settled on the soleplate. I can not remove it using your instructions. It makes ironing difficult. Can you please give me a clear answer of how to deal with this problem. Kind regards, Christine
  • Philips Master
  • 43,501 Answers
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaning a Steam Iron Soleplate
heatman101
Posted on Feb 04, 2011
My stream iron generator tefal and problem some parts outstanding on base of iron , and stream can not get out , how to remove PARTS.
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Oct 02, 2013 | Tefal Irons
WATER HOSE PERISH
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Oct 01, 2013 | Irons
My steam cleaner was working, then when i refilled it, it didnt heat up. its a multipurpose with different attachments. could it be element gone?
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Sep 30, 2013 | Conair Compact Garment Steamer Iron
How to open a steam iron severin
follow this principle.God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Jul 20, 2013 | Severin Steam Iron, 2500 Watt, White...
Breville TECHnique VIN158
if the iron use electronic control, will be a little difficult to adapt or reset .However i recommend follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Jun 11, 2013 | Irons
The steam button is stuck on (pushed in) but there's no steam.
follow this steps. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Nov 15, 2012 | Black & Decker Irons
Water is leaking out of the bottom of my philli[s GC 9240
see the next steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Nov 14, 2012 | Irons
As the steam builds up it constantly comes out of the the blow off pressure valve under the iron. steam will come out of the sole plate when the button is pressed
see this causes and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Oct 02, 2012 | Irons
When I iron my white sheets dirty water comes out and my sheets are dirty
follow the steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Oct 01, 2012 | Tefal Pro Express GV 8120 Iron
BRown water and stuff coming out of iron
Hi, two problems:
DIA' s problem - the brown water is due to poor water quality and debris in the boiler and iron sytem. Rowenta is clear that they do not want anyone to cleaning solutions - only clear filtered drinking water to rinse out the boiler (via the water inlet screw hole) and I have found running the system dry, letting it cool, rinsing and draining the boiler several times before putting unit away works fine.
Guest' problem with brown/black tar substance is likely caused by too hot and iron setting (steam setting may also be too high) for ironing man-made synthetics (like Nylon, Rayon, Polyester or blends are basically petroleum based fabrics) that breakdown or melt, leaving deposits on the iron's stainless steel soleplate. A secondary cause could be bad water or debris in the boiler/iron in which the solution for DIA's problem might provide relief. Cleaning the soleplate is tricky, I use nothing stronger than an old fashioned wooden orange stick to gently scrap of all traces of the "stuff" and dry "Dutch" cleanser w/ a terry cloth or old cotton sock to polish without scratching the soft stainless soleplate...
Apr 01, 2008 | Rowenta DG-980 Iron
Philips GC 4610 Iron Logo
344 people viewed this question
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
